主题:【求助】2002/19/EC中增加了增塑剂的要求,请问:该指令中的增塑剂该采用哪个标准进行测试?
浏览 |回复4 电梯直达
jenny123456
bebuhaha
The official method has not been defined. Since the 5 phthalates also belongs to those for toys, you may try to couple EN1186 with the method for toys with modification.
jenny123456
Thank you very much. According to what you said,I can use EN1186 method to extract sample and test the phthalate content by toy's test method such as EN14372. Is it right what I said?
jiawap
寻求检测2002/19/EC服务
检测条件
distilled water simulant, 30 min under reflux
fatty food simulant, 3.5hr at 60 C ( equivalent to 30 min at 121C in olive oil)
报价,  并提供报告样本
yyzi0127
