质谱 里面的几个参数不会翻译,请求帮忙
Systems
Data analysis any net CDF or .d compatible software
Memory on-board compact flash (1GB)
LTM column (typical) MXT-5.5m*0.1mm*0.4umdf
Resolution less than unit mass to 230amu,nominal unit mass to 500amu
Chemical libraries
Target analysis IFD deconvolution software ,automated on K(产品名):
User defined using
gc retention times and spectral data
