41 容积式--cubage
42 非自动式--non-automatic
43 自动式--antomatic
44 间歇式--intermittence
45连续式--continuous
46 标准--standard specification
47 测力分析--force analysis
48 装配--assembly
49 工业制造--industry manufacture
50 力值保持--force hold
51 质量--quality
52配料--batching
53 电子衡器--electronic weighing instrument
55 防雷击系统--the system of protection against struck by lighting
56 免标定--calibration free
57 量程系数--span parameter
58方管结构--quadrate pipe structure
59 板式结构--the overall steel plate structure
60 移动式结构--movable structure
61 不锈钢防腐型--strainless steel and anti-erosion
62电子钢瓶秤--chlorine tank scale
63 U型电子秤--the U-shaped electronic scale
64电子缓冲秤--the electronic cushioning scale
65移动式叉车秤--the movable fork scale
66带框架结构--have frame
67 电子平台秤--floor scales
68无框架结构--no frame
69 升降移动式结构--movable and with rising and falling structure
70移动式超低台面结构--movable and ultra low floor structure
71 整体U型梁结构--the unitary U-shaped beam structure
72 短面台组合结构--composed by short platforms
73 模拟量输出分辨率--anlog output resolution
74 采样频率--sampling frequence
75零点跟踪范围--zero tracing
76 防抖强度--anti-shaking intensity
77 S型称重传感器--S-beam load cells
78双剪切量称重传感器--double ended shear beam load cells
79 单点称重传感器--single point load cells
80 压式称重传感器--cmpression load cells
