是不是出自这段话: However, the experimentation can be avoided in the case of materials with a thickness greater than 0,5 mm because it is conventionally agreed, except for plasticized polymers and multi-layer materials where the food contact surfaces are different, that for these materials the calculation shall take into account the total surface exposed. 可plasticized polymers and multi-layer materials 除外呀!!
