主题:【求助】求元素周期表中各元素的特征谱线
浏览 |回复18 电梯直达
fly-away
大家好,刚接触元素分析,对于元素周期表中各元素的特征谱线知道的较少,所以想问问大家有没有相关的资料。最好是各元素都有的,谢谢
ldgfive
一般这样的信息,在原子吸收仪器软件的专家系统里都是有的
fly-away
悠旸
安老师总结过一张excel表格,可以共享一下。
常测元素谱线及灵敏度比
元素代号谱线(nm)灵敏度比谱线(nm)灵敏度比谱线(nm)灵敏度比谱线(nm)灵敏度比灰化温度原子化温度
Ag328.1nm1.0000338.3nm0.0700
Al309.3nm1.0000308.2nm0.8500396.2nm0.4900394.4nm0.1300
As193.7nm1.0000197.2nm0.7000
Au242.8nm1.0000267.6nm0.1700
B249.8nm1.0000
Ba553.6nm1.0000350.1nm0.0400
Be234.9nm1.0000
Bi223.1nm1.0000222.6nm1.0000306.7nm0.1600
Ca422.7nm1.0000239.9nm0.0040
Cd228.8nm1.0000326.1nm0.0080
Co240.7nm1.0000242.5nm0.9100252.1nm0.4600
Cr359.3nm1.0000357.9nm0.8400360.5nm0.4500425.4nm0.2700
Cu324.8nm1.0000327.4nm0.3800249.2nm0.0400
Fe248.3nm1.0000248.8nm0.3400302.1nm0.2400
Ge265.2nm1.0000271.0nm0.5100259.3nm0.3800
In325.6nm1.0000303.9nm0.2000
K766.5nm1.0000769.9nm0.1300404.4nm0.0100
Li670.8nm1.0000323.3nm0.0010
Mg285.2nm1.0000202.5nm0.0400
Mn279.5nm1.0000280.1nm0.6900403.1nm0.1500
Mo313.3nm1.0000386.4nm0.7800379.8nm0.7600317.0nm0.4700
Na589.0nm1.0000589.6nm0.1900330.2nm0.0020
Ni232.0nm1.0000341.5nm0.3100352.5nm0.2200
Pb283.3nm1.0000217.0nm2.0000
Pd247.6nm1.0000244.8nm1.2100276.3nm0.8400240.5nm0.7400
Pt265.9nm1.0000270.2nm0.2100273.4nm0.1800271.9nm0.1500
Rh343.5nm1.0000369.2nm0.4000339.7nm0.3300
Sb217.6nm1.0000231.1nm1.2400206.8nm0.8800
Se196.0nm1.0000
Sn224.6nm1.0000286.3nm0.5600284.0nm0.2500
Sr460.7nm1.0000
Ti364.3nm1.0000319.2nm0.7000
V318.4nm1.0000390.2nm0.1500
Zn213.9nm1.0000307.6nm0.0010
该帖子作者被版主 ljhciq5积分, 2经验,加分理由:帮助
fly-away
fly-away
ghostermen
现在谁家的原子吸收还要自己设谱线的,太原始了吧
fly-away
秋月芙蓉
原吸上,用次灵敏线的情况也是多见的,使用时不应一概而论
2012/4/7 16:31:57 Last edit by ljhciq
zhaohua8011
一般的原子吸收仪器软件里都会有列出的,供选择
悠旸
这个不同仪器有较大区别,可以参照自己仪器的cookbook
原文由 fly-away(fly-away) 发表:
灰化温度,悠老师有么?谢谢
