with electron-capture (ECD), nitrogen–phosphorus (NPD),flame photometric detection (FPD), mass spectrometric detection(MSD) and high performance liquid chromatography(HPLC) with diode-array detection (DAD) and fluorescencedetection. Before the residues were determined,samples required extraction and purification, and in this respectliquid–liquid extraction (LLE) [9], solid-phase extraction
(SPE) [10], accelerated solvent extraction (ASE) [11],gel permeation chromatography (GPC) [12] and matrix solidphasedispersion (MSPD) [13] served as common methods.MSPD is a sample pretreatment technique based on SPE,thus, with much easier application than that of SPE, MSPD
also helps prevent emulsion from happening in liquid distribution,
reduce the volume of organic solvents and acceleratethe analysis, as SPE does. MSPD was first applied to extractand purify drug residues in animal tissue samples [14], andin recent years its application became popular in pesticidedetection and has been introduced to multi-residual analysis[13–21] on pesticides in vegetal samples such as fruits,vegetables, fruit juices, etc.In previous paper [22] we established a rapid and reliablemulti-residual method based on MSPD for determiningin apple juice the residues of 106 pesticides widely used inagricultural production. Some experimental parameters were
optimized, for example, the pesticide-to-matrix ratio, composition
of organic solvent, elution volume, elution rate, etc.By taking these measures we have reached an optimum experimentalcondition, which determines the ratio at 2:1, thehexane–dichloromethane solution volume (1:1) at 160mLand the flow rate at 5 mL/min.In this paper we will elaborate on the development of themulti-residual method. Two hundred and sixty-six pesticideswere divided into three groups, prepared by the same MSPDprocedure, and detected by gas hromatography–mass selecteddetection under selective ion monitoring (SIM). Theanalysis required three separate injections to cover all of thepesticides. The accuracy, precision, limits of detection, and
linearity of the method were verified according to ResiduesAnalysis Quality Control Guide (RAQCG) [23] as constitutedby the General Administration of Quality Supervision,Inspection and Quarantine of the People’s Republic of China.
