【作者】 李秋红; 张丹丹; 李纯; 韩华;
【Author】 Li Qiuhong Zhang Dandan Li Chun Han Hua (Pharmaceutical School Clinical Department,Heilongjiang University of Chinese Medicine,Harbin 150040)
【机构】 黑龙江中医药大学药学院临床药学教研室;
【摘要】 目的:建立测定大鼠体内血浆和唾液中槐果碱含量的HPLC分析方法。方法:采用色谱柱:Diamonsil(R)C18柱150mm×4.6mm,流动相:甲醇-0.1‰三乙胺水溶液(60:40,v:v),检测波长:220nm,柱温:30℃,流速:0.8ml/min。结果:槐果碱血浆和唾液的相对回收率分别为92.7%~96.6%和94.8%~113.0%,日内、日间精密度RSD<10%,血浆和唾液中槐果碱浓度在8~160μg/mL和2~40μg/mL范围内相关系数分别为0.9994和0.9995,线性关系良好。结论:首次建立槐果碱唾液样品检测方法以及用HPLC法同时测定大鼠体内血浆和唾液中的含量方法,为槐果碱的临床药动学研究提供了新的方法学基础。 更多还原
【Abstract】 This is a study to determine sophocarpine in rats’ plasma and saliva using HPLC approach.We made the study under the following parameters:Diamonsil(R)C 18 Column at 150mm×4.6mm,methanol-water containing 0.1‰triethy- lamine (60:40,v:v) for mobile phase,a detection wave length at 220 nm,a temperature at 30℃,and a flow-rate of 0.8 mL/min.The study has produced the following results:a relative recovery of sophocarpine in plasma and saliva at 92.7%~96.6%,and 94.8%~113.0% respectively;the RSD of intra... 更多还原
【关键词】 HPLC; 槐果碱; 血浆; 唾液;
【Key words】 HPLC; Sophocarpine; Plasma; Saliva;
