146.2 HPLC法测定氧氟沙星滴耳液中氧氟沙星的含量
【作者】 王彦厚; 贾雷;
【Author】 WANG Yan-hou1,JIA Lei2(1.Zibo Institute for Drug Control of Shandong Province,Zibo 255086,China;2.Zibo Science and Technology Vocational College of Shandong Province,Zibo 255314,China)
【机构】 淄博市药品检验所; 淄博科技职业学院药学系;
【摘要】 目的建立测定氧氟沙星滴耳液中氧氟沙星含量的HPLC方法。方法采用Dikma Diamonsil C18柱(4.6 mm×150 mm,5μm),乙腈-0.1%三乙胺溶液(14∶86,H3PO4调节pH值至3.0)为流动相,柱温35℃,流速1.0 mL/min,Waters 996 PDA检测器,检测波长294 nm。结果进样量在0.153 9~3.078 0μg范围内线性关系良好,r=0.999 9(n=6),平均回收率99.84%,RSD=0.56%。结论该方法准确、简便、重现性好,可用于氧氟沙星滴耳液的含量测定。 更多还原
【Abstract】 Objective To establish an HPLC method for determination of ofloxacin in ofloxacin otic solution.MethodsThe Dikma Diamonsil C18 stainless steel column(4.6 mm×150 mm,5 μm)was used,the flow rate was 1.0 mL/min with the acetonitrile-0.1% triethy solution(14∶86)(pH was adjusted to 3.0 with phosphoric acid)as mobile phase,the column temperature was 35 ℃,and the Waters 996 PDA detection set wavelength was at 294 nm.ResultsThere was good linearity of the calibration carve between 0.153 9~3.078 0 μg,r=0.... 更多还原
【关键词】 HPLC; 氧氟沙星滴耳液; 氧氟沙星;
【Key words】 HPLC; Ofloxacin otic solution; Ofloxacin;
