主题:【分享】实验室、厂房英语标识词汇对比
浏览0 回复5 电梯直达
仙后婧婧(谭思婧)
冲压课Stamping Section
冲压区Stamping Area
冲压现场办公区Stamping Section Office
点焊区Welding Area
拉钉区Riveting Area
打磨区Sanding Area
拉钉现场办公区Riveting Section Office
废弃物存放区Scrap Area
烤漆课Coating Section
烤漆区Coating Area
液体/粉体Liquid/Powder
烤漆清洗线Degreasing Process
烤漆前处理区Coating Prep Area
超音波清洗区Ultrasonic Cleaning Process
粉体烤漆线Powder Coating Line
液体烤漆线Liquid Painting Line
粉体涂装室Powder Coating Spraying Room
液体涂装室Liquid Painting Spraying Room
烤漆课现场办公区Coating Section Office
集尘室Dust Collector Room
吹尘室Dust Blow Off Room
调漆室Paint Mixing Room
打磨房Sanding Room
煤气房Natural Gas Control Room
预脱脂槽Degreasing Area Stage 1
主脱脂槽Degreasing Area Stage 2
皮膜槽Metal Surface Phosphate Treating Area
清水槽Rinsing Area
沉淀储水池Waste Deposit
小心吊物Warning: Hooks in Operation
小心碰头Warning: Head Injury, Low Shelves
更衣间Dressing Room
闲人免进Warning: Only Authorized Personnel
警告: 须着防静电衣后才可入内.
Warning: Antistatic Clothing is Required
贵宾衣柜/鞋柜For Visitors Use Only
员工鞋柜Employee Shoes Lockers
杂项物料区Miscellaneous Items Storage
不合格品区Non-Conforming Parts Area
废弃物存放区Scrap Area
烤漆制具保养室Masking Maintenance
烤漆卸制具制程De-Masking Process
治具保养室Fixture/Jig/Gauge Maintenance
组配课Assembly Section
组配区Assembly Area
上班入口Entrance
下班出口Exit
组配现场办公区Assembly Section Office
包材作业区Packaging Area
备料区Material Staging Area
不合格品区Non-conforming Parts Area
换鞋间Changing Room
为保持清洁,请您换鞋.
For cleanliness, please change your shoes.
组装线Assembly Line
负责人Line Leader
前置加工线Prep Line
散件大宗线Accessory Part Assembly Line
会议室Conference Room
洗手间Rest Room
茶水间Tea Room
电脑机房MIS Server Room
复印室Copy Room
教育训练室Training Room
仓管课Warehouse Management Section
品管部QC Dept.
品管部资料室document Control, QC Dept.
品管部样品室QC Sample Room
塑料厂Plastic Plant
塑料厂厂长室Plastic Plant Manager
塑料厂经理室Manager
塑料成型课Molding Section
物料室Raw Material Warehouse/Storage
碎料室Crusher Room
模具存放区Tooling Warehouse
成型课现场办公区Molding Section Office
工具区Accessorial Tools Storage
治具柜放置区Fixture/Jig/Gauge Racks
设备维修区Tooling Maintenance Area
柜式烤炉Oven
不良品放置区Non-Conforming Product Area
重工区Rework Area
包材存放区Packing Material Area
塑料喷漆印刷课Plastic Decoration Section
周转包材放置区Recycled Packaging Materials Rack
大宗包材放置区Packaging Material Rack
待印刷产品放置区Silkscreen/Pad Printing WIP Material
待喷漆产品放置区WIP Material
调漆房&治具房Paint Mixing Room & Fixture Shop
重点防火区No Fire Area
喷漆房Painting Room
谢绝参观Authorized Personnel Only
浴尘室除尘Dust Vacuum Room
1.进门灯显示绿灯时开门进入浴尘室
1. Enter the room when light turns green.
2.将进门关上后自动除尘
2.Close door to start vacuum
3.除尘时间约为8秒,听到"啪"一声后开门走出
3.Vacuum time 8 seconds. Exit room at the sound of the "pop".
塑料厂设计课Plastic Molding Design Section
塑料制模课Tooling Fabrication Section
修模区Tooling Repair Area
省模区Polishing Area
制模区Tooling Fabrication Area
EDM加工区EDM Area
CNC加工区CNC Area
检验区Inspection Area
外发区Shipping Area
模具厂/中心Tooling Plant/Center
模具厂办公室Tooling Center Office
五金模具厂Sheet Metal Tooling Shop
五金加工设计课Sheet Metal Tooling Design Section
五金模具维修区Sheet Metal Tooling Maintenance Area
五金模具制模区Sheet Metal Tooling Fabrication Area
线割房Wire Cutting Shop
五金工具室Tooling Parts Storage
CNC加工区CNC Area
样品室Sample Room
试模区Stamping Try-Out Area
会议室Conference Room
厂长室Plant Manager
铁材仓Sheet Metal Warehouse ----Raw Materials
冲件仓Stamping Warehouse ---- WIP
包材仓Packaging Material Warehouse
塑料仓Injection Molding Warehouse ---- WIP
待验区Holding Area
贵重物品仓High value Materials Warehouse
特殊物料仓Special Item Storage
塑料原料区Plastic Warehouse - Raw Materials
不合格仓Non-conforming Parts Area
烤漆件仓 Coating Parts Warehouse
成品仓Finished Product Warehouse
小件仓Small Parts Warehouse
收料窗口Receiving Window
IQC 检验台IQC Inspection Station
QA实验室Quality Assurance
QA量测室QA Measurement Office
模具仓Tooling Warehouse
(来自互联网)
仙后婧婧(谭思婧)
现在的很多实验室、工厂都是跨国的,中英文标识越来越重要啦
wulasisi
还有一些国内的厂房,都是中英文的,有的时候翻译的真是醉了
wulabobo
穿越时空
我们这里没任何英文标识,因为根本没可能有外国人来。
仙后婧婧(谭思婧)
原文由 穿越时空(fscmj) 发表:
穿越大哥你在哪啊?
