主题:【悬赏帖】ASTM E303 - 93(2018)
浏览 |回复1 电梯直达
大M
悬赏金额:50积分 状态: 已解决
Standard Test Method for  Measuring Surface Frictional Properties Using the British Pendulum  Tester
https://www.astm.org/Standards/E303.htm
最佳答案:liuxilin1215回复于2018/08/17
ASTM E303-93(R2018) Standard Test Method for Measuring Surface Frictional Properties Using the British Pendulum Tester
liuxilin1215
2018/8/17 10:22:23 Last edit by liuxilin1215
