主题:【悬赏帖】ASTM D1148 - 13(2018)
浏览 |回复3 电梯直达
大M
悬赏金额:50积分 状态: 已解决
Standard Test Method for Rubber Deterioration—Discoloration from Ultraviolet  (UV) or UV/Visible Radiation and Heat Exposure of Light-Colored Surfaces
最佳答案:liuxilin1215回复于2018/12/14
ASTM D1148-13(R2018) Standard Test Method for Rubber Deterioration—Discoloration from Ultraviolet (UV) or UV/Visible Radiation and Heat Exposure of Light-Colored Surfaces
穿越时空
liuxilin1215
原文由 穿越时空(fscmj) 发表:
沉下去了,帮你顶上来.
穿越时空
版权问题,楼主快来结贴,过几天就删去此贴了.
