主题:【分享】沃凯超干试剂
浏览 |回复0 电梯直达
小官人
产品特点:
l  低水分含量 Low moisture content
l  高反应效率 High reaction efficiency
l  优异的批次稳定性Excellent batch stability
l  抽取式超干包装设计,有效隔绝空气及水分,确保产品一如既往的超干品质
HySeal Packing can effectively isolate the air and moistureand ensure the quality of extra dry reagents for every use
更多品种和规格,更多选择:
1.  溶剂Solvents
超干溶剂Extra Dry Solvents
存货编码存货名称规格型号包装CAS
XW00562351四氯化碳99.5%, HyDry, Water≤50 ppm (by K.F.),  HySeal(沃凯)100ml56-23-5
XW00562352四氯化碳99.5%, HyDry, Water≤50 ppm (by K.F.),  HySeal(沃凯)500ml56-23-5
XW00641751乙醇99.5%, HyDry, with molecular sieves, Water≤50 ppm (by K.F.), HySeal(沃凯)100ml64-17-5
XW00641752乙醇99.5%, HyDry, with molecular sieves,  Water≤50 ppm (by K.F.), HySeal(沃凯)500ml64-17-5
XW00676851二甲基亚砜99.7%, HyDry, with molecular sieves,  Water≤50 ppm (by K.F.), HySeal(沃凯)100ml67-68-5
XW00676852二甲基亚砜99.7%, HyDry, with molecular sieves,  Water≤50 ppm (by K.F.), HySeal(沃凯)500ml67-68-5
XW00676853二甲基亚砜99.7%, HyDry,Water≤50 ppm (by K.F.), HySeal(沃凯)1L67-68-5
XW00713631正丁醇99.5%, HyDry, Water≤50 ppm (by K.F.),  HySeal(沃凯)100ml71-36-3
XW0071432299%, HyDry, with molecular sieves, Water≤50  ppm (by K.F.), HySeal(沃凯)500ml71-43-2
XW00750581乙腈99.9%, HyDry, with molecular sieves,  Water≤50 ppm (by K.F.), HySeal(沃凯)100ml75-05-8
XW00750582乙腈99.9%, HyDry, with molecular sieves,  Water≤50 ppm (by K.F.), HySeal(沃凯)500ml75-05-8
XW00750583乙腈99.9%, HyDry, with molecular sieves,  Water≤50 ppm (by K.F.), HySeal(沃凯)1L75-05-8
XW00750921二氯甲烷(2~8℃)99.9%, HyDry, with molecular sieves,  Water≤50 ppm (by K.F.), HySeal(沃凯)100ml75-09-2
XW00750922二氯甲烷(2~8℃)99.9%, HyDry, with molecular sieves,  Water≤50 ppm (by K.F.), HySeal(沃凯)500ml75-09-2
XW00750923二氯甲烷(2~8℃)99.9%, HyDry, with molecular sieves,  Water≤50 ppm (by K.F.), HySeal(沃凯)1L75-09-2
XW00756501叔丁醇99.5%, HyDry, Water≤50 ppm (by K.F.),  HySeal(沃凯)100ml75-65-0
XW00792091乙酸甲酯99%, HyDry, Water≤50 ppm (by K.F.), HySeal(沃凯)100ml79-20-9
XW009647912-甲基四氢呋喃99%, HyDry,with molecular sieves, Water≤50 ppm (by K.F.), HySeal(沃凯)100ml96-47-9
XW01099991四氢呋喃99.5%, HyDry, with molecular sieves,  Water≤50 ppm (by K.F.), HySeal(沃凯)100ml109-99-9
XW01099992四氢呋喃99.5%, HyDry, with molecular sieves,  Water≤50 ppm (by K.F.), HySeal(沃凯)500ml109-99-9
XW01099993四氢呋喃99.5%, HyDry, with molecular sieves,  Water≤50 ppm (by K.F.), HySeal(沃凯)1L109-99-9
XW01271843四氯乙烯99%, HyDry, Water≤50 ppm (by K.F.), HySeal(沃凯)1L127-18-4
XW01271951N,N-二甲基乙酰胺99.8%, HyDry, Water≤50 ppm (by K.F.), HySeal (沃凯)100ml127-19-5
XW01271956N,N-二甲基乙酰胺99.8%, HyDry, with molecular sieves,  Water≤50 ppm (by K.F.), HySeal(沃凯)1L127-19-5
XW087250411-甲基-2-吡咯烷酮99.5%, HyDry, with molecular sieves,  Water≤50 ppm (by K.F.), HySeal(沃凯)100ml872-50-4
XW08725043N-甲基吡咯烷酮99.5%, HyDry, with molecular sieves,  Water≤50 ppm (by K.F.), HySeal(沃凯)1L872-50-4
XW16340441甲基叔丁基醚99%, HyDry, with molecular sieves, Water≤50  ppm (by K.F.), HySeal(沃凯)100ml1634-04-4
生化应用溶剂Solvents for Biochemistry
存货编码存货名称规格型号包装CAS
XW00675611甲醇99.9%, HyDry, with molecular sieves,  Water≤50 ppm (by K.F.), HySeal(沃凯)100ml67-56-1
XW00675612甲醇99.9%, HyDry, with molecular sieves,  Water≤50 ppm (by K.F.), HySeal(沃凯)500ml67-56-1
XW00675613甲醇99.9%, HyDry, with molecular sieves,  Water≤50 ppm (by K.F.), HySeal(沃凯)1L67-56-1
XW00676301异丙醇99.5%, HyDry, with molecular sieves,  Water≤50 ppm (by K.F.), HySeal(沃凯)100ml67-63-0
XW00681222N,N-二甲基甲酰胺99.8%, HyDry, with molecular sieves,  Water≤50 ppm (by K.F.), HySeal(沃凯)100ml68-12-2
XW00681223N,N-二甲基甲酰胺99.8%, HyDry, with molecular sieves,  Water≤50 ppm (by K.F.), HySeal(沃凯)500ml68-12-2
XW01108611吡啶99.5%,HyDry,with molecular sieves, Water≤50  ppm (by K.F.), HySeal(沃凯)100ml110-86-1
XW01108612吡啶99.5%,HyDry,with molecular sieves, Water≤50  ppm (by K.F.), HySeal(沃凯)500ml110-86-1
XW01108613吡啶99.5%,HyDry,with molecular sieves, Water≤50  ppm (by K.F.), HySeal(沃凯)1L110-86-1
XW012391111,4-二氧六环99.7%,HyDry,with molecular sieves,  stabilized with BHT, Water≤50 ppm (by K.F.), HySeal(沃凯)100ml123-91-1
XW012391121,4-二氧六环99.7%,HyDry,with molecular sieves,  stabilized with BHT, Water≤50 ppm (by K.F.), HySeal(沃凯)500ml123-91-1
XW012391131,4-二氧六环99.7%,HyDry,with molecular sieves,  stabilized with BHT, Water≤50 ppm (by K.F.), HySeal(沃凯)1L123-91-1
XW01428251正庚烷99%, HyDry, Water≤50 ppm (by K.F.), HySeal(沃凯)100ml142-82-5
2.  有机金属Organometallics
格式试剂Grignard Reagents
存货编码存货名称规格型号包装CAS
XW00751611甲基溴化镁(2~8℃)1.0 M solution  in THF, HySeal(沃凯)100ml75-16-1
XW00751612甲基溴化镁(2~8℃)1.0 M solution  in THF, HySeal(沃凯)500ml75-16-1
XW00751613甲基溴化镁(2~8℃)1.0 M solution  in THF, HySeal(沃凯)800ml75-16-1
XW00751616甲基溴化镁(2~8℃)3.0 M solution  in 2-Methyl-THF, HySeal(沃凯)100ml75-16-1
XW00751617甲基溴化镁(2~8℃)3.0 M solution  in 2-Methyl-THF, HySeal(沃凯)500ml75-16-1
XW00751618甲基溴化镁(2~8℃)3.0 M solution  in 2-Methyl-THF, HySeal(沃凯)800ml75-16-1
XW01005831苯基溴化镁(2-8℃)1.0 M solution  in THF, HySeal(沃凯)100ml100-58-3
XW01005832苯基溴化镁(2-8℃)1.0 M solution  in THF, HySeal(沃凯)500ml100-58-3
XW01005833苯基溴化镁(2~8℃)1.0 M solution  in THF, HySeal(沃凯)800ml100-58-3
XW035213624-氟苯基溴化镁(2~8℃)1.0 M solution  in THF, HySeal(沃凯)100ml352-13-6
XW035213634-氟苯基溴化镁(2~8℃)1.0 M solution  in THF, HySeal(沃凯)500ml352-13-6
XW06765841甲基氯化镁(2~8℃)3.0 M solution  in THF, HySeal (沃凯)100ml676-58-4
XW06765842甲基氯化镁(2~8℃)3.0 M solution  in THF, HySeal(沃凯)500ml676-58-4
XW06772251叔丁基氯化镁(2~8℃)1.0 M solution  in THF, HySeal(沃凯)100ml677-22-5
XW09203981异丙基溴化镁(2~8℃)1.0 M solution  in THF, HySeal(沃凯)100ml920-39-8
XW09203984异丙基溴化镁(2~8℃)3.0 M in  2-Methyltetrahydrofuran, HySeal (沃凯)100ml920-39-8
XW09259061乙基溴化镁(2~8℃)1.0 M solution  in THF, HySeal(沃凯)100ml925-90-6
XW09259062乙基溴化镁(2~8℃)1.0 M solution  in THF, HySeal(沃凯)500ml925-90-6
XW09259064乙基溴化镁(2~8℃)2.0 M solution  in THF, HySeal(沃凯)100ml925-90-6
XW09315001环己基溴化镁(2~8℃)1.0 M solution  in THF,HySeal(沃凯)100ml931-50-0
XW09315002环己基溴化镁(2~8℃)1.0 M solution  in THF, HySeal(沃凯)500ml931-50-0
XW10685591异丙基氯化镁(2-8℃)2.0 M solution  in THF, HySeal  (沃凯)500ml1068-55-9
XW10685592异丙基氯化镁(2~8℃)2.0 M solution  in THF, HySeal  (沃凯)100ml1068-55-9
XW10685596异丙基氯化镁(2~8℃)1.0 M solution  in THF, HySeal(沃凯)100ml1068-55-9
XW10685597异丙基氯化镁(2~8℃)1.0 M solution  in THF, HySeal(沃凯)500ml1068-55-9
XW10685598异丙基氯化镁(2~8℃)1.0 M solution  in THF, HySeal(沃凯)800ml1068-55-9
XW18266711乙烯溴化镁(2~8℃)1.0 M solution  in THF, HySeal(沃凯)100ml1826-67-1
XW18266712乙烯溴化镁(2~8℃)1.0 M solution  in THF, HySeal(沃凯)500ml1826-67-1
XW18266713乙烯溴化镁(2~8℃)1.0 M solution  in THF, HySeal(沃凯)800ml1826-67-1
XW237198041环丙基溴化镁(2~8℃)0.5 M solution  in THF, HySeal(沃凯)100ml23719-80-4
XW237198044环丙基溴化镁(2~8℃)1.0 M solution  in THF, HySeal(沃凯)100ml23719-80-4
XW237198045环丙基溴化镁(2~8℃)1.0 M solution  in THF, HySeal(沃凯)500ml23719-80-4
XW35369671乙烯基氯化镁(2~8℃)1.0 M solution  in THF, HySeal(沃凯)100ml3536-96-7
XW35369674乙烯基氯化镁(2~8℃)2.0 M solution  in THF, HySeal(沃凯)100ml3536-96-7
XW43011481乙炔基溴化镁(2~8℃)0.5 M solution  in THF, HySeal(沃凯)100ml4301-14-8
XW43011482乙炔基溴化镁(2~8℃)0.5 M solution  in THF, HySeal(沃凯)500ml4301-14-8
XW43011483乙炔基溴化镁(2~8℃)0.5 M solution  in THF, HySeal(沃凯)800ml4301-14-8
XW69213421苄基氯化镁(2-8℃)1.0 M solution  in THF, HySeal(沃凯)100ml6921-34-2
XW7450388621异丙基氯化镁-氯化锂(2~8℃)1.3 M solution  in THF, HySeal(沃凯)100ml745038-86-2
XW7450388622异丙基氯化镁-氯化锂(2~8℃)1.3 M solution  in THF, HySeal(沃凯)500ml745038-86-2
有机锂化合物 Organolithiums
存货编码存货名称规格型号包装CAS
XW41115405二异丙基氨基锂(2~8℃)2.0 M solution  in THF/n-heptane ethylbenzene, HySeal(沃凯)100ml4111-54-0
XW41115406二异丙基氨基锂(2~8℃)2.0 M solution  in THF/n-heptane ethylbenzene, HySeal (沃凯)500ml4111-54-0
XW41115407二异丙基氨基锂(2~8℃)2.0 M solution  in THF/n-heptane ethylbenzene, HySeal(沃凯)800ml4111-54-0
3.  即用试剂溶液
胺类Amines
存货编码存货名称规格型号包装CAS
XW01244031二甲胺(2-8℃)2M solution in  THF, HySeal(沃凯)100ml124-40-3
XW01244032二甲胺(2~8℃)2M solution in  THF, HySeal(沃凯)500ml124-40-3
XW76644171氨(2~8℃)7.0 M solution  in MeOH, HySeal(沃凯)100ml7664-41-7
XW76644173氨(2~8℃)0.4 M solution  in 1,4-Dioxane, HySeal (沃凯)100ml7664-41-7
XW76644174氨(2~8℃)0.4 M solution  in 1,4-Dioxane, HySeal(沃凯)500ml7664-41-7
卤化物Halides
存货编码存货名称规格型号包装CAS
XW102943341三溴化硼(2~8℃)17% in Methylene  chloride,HySeal (沃凯)100ml10294-33-4
XW102943342三溴化硼(2~8℃)17% in Methylene  chloride,HySeal (沃凯)500ml10294-33-4
XW102943451三氯化硼(2~8℃)1.0 M solution  in Methylene chloride, HySeal(沃凯)100ml10294-34-5
XW102943452三氯化硼(2~8℃)1.0 M solution  in Methylene chloride, HySeal(沃凯)500ml10294-34-5
XW102943453三氯化硼(2~8℃)1.0 M solution  in Methylene chloride, HySeal(沃凯)800ml10294-34-5
XW102943454三氯化硼(2~8℃)1.0 M solution  in Hexanes, HySeal(沃凯)100ml10294-34-5
XW102943455三氯化硼(2~8℃)1.0 M solution  in Hexanes, HySeal(沃凯)500ml10294-34-5
XW76468571氯化锌(2~8℃)1.0 M solution  in THF, HySeal (沃凯)100ml7646-85-7
硼烷Boranes
存货编码存货名称规格型号包装CAS
XW132928702硼烷二甲基硫醚络合物(2~8℃)2.0 M solution  in THF, HySeal(沃凯)500ml13292-87-0
XW140446563硼烷四氢呋喃络合物(2-8°C)1.0 M solution  in THF, HySeal(沃凯)500ml14044-65-6
XW140446564硼烷四氢呋喃络合物(2-8°C)1.0 M solution  in THF, HySeal(沃凯)1L14044-65-6
其他Other
存货编码存货名称规格型号包装CAS
XW181071813三甲基硅烷化重氮甲烷(2~8℃)2.0M in Hexane,  HySeal(沃凯)100ml18107-18-1
更多缓冲颗粒品规及详情请询国药试剂销售部
地址:上海市宁波路52号
电话:021-63219651
邮箱:sj_office@sinopharm.com
中国试剂网:www.reagent.com.cn
推荐帖
2019/4/19 10:06:57 Last edit by Insm_f06c4b79 举报
