主题:【求助】关于进一步推进检验检测机构资质认定改革工作的意见
浏览 |回复13 电梯直达
欢欢
关于进一步推进检验检测机构资质认定改革工作的意见是已经在全国范围生效了吗
该帖子作者被版主 czcdczg2积分, 2经验,加分理由:鼓励发帖
90后检测机构质量菜鸟
此意见已经生效,目前实施的只是自由贸易试验区可以进行告知承诺制度。
先行试点实施告知承诺制度。根据试点工作情况,待条件成熟后,在全国范围内推行。
具体省实施通知:详见各省市场监督管理局
以下为总局链接:http://gkml.samr.gov.cn/nsjg/rzjcs/201910/t20191025_307884.html
http://www.samr.gov.cn/xwxcs/scwfb/201911/t20191118_308596.html
2019/12/13 14:29:42 Last edit by Insp_9533be6f
检测老菜鸟
生效了,你们有想法去做这个?  吃螃蟹不好吃哦
杰8521
承之
GRANT
m3283090
hncx2004
Insp_b6fde894
Amsler测试技术
阳光模拟测试系统执行的标准包括:
GR-487-CORE
Electronic Equipment Cabinets
AECTP 300 Method 305
Solar Radiation
AK LV 01
Airbag Test
ASTM E927
Standard Specification for Solar Simulation for Terrestrial Photovoltaic Testing
BMW PR 306.4
Solar Simulation for equipment parts
DBL 4571
Interior Trim Parts
DBL 5471
Covering and Form Padding Parts
DBL 7384
"Soft Feeling" Paint on Plastic Parts - Interior Components
Dessault Aviation
Solar Simulation Test
DIN EN 60068-2-5
Electrical engineering - Basic environmental testing procedures - Part 2-5: Tests - Test Sa: Simulated solar radiation at ground level
DIN EN 61646 VDE 0126-32
Thin-film terrestrial photovoltaic (PV) modules - Design qualification and type approval
DIN EN 61853-1
Photovoltaic (PV) module performance testing and energy rating - Part 1: Irradiance and temperature performance measurements and power rating
DIN IEC 68-2-9
Electrical engineering - Basic environmental testing procedures - Part 2-9: Tests - Guidance for solar radiation testing
DIN SPEC 18035-7
Sports grounds - Part 7: Synthetic turf areas
DVM 0006-EX
Exterior Lighting-Sunload
DVM 0074-MA
Ageing of interior components by sunload simulation
EN 12975-2
Thermal Collector Testing
EPA 40 CRF Part 86
Control Air Pollution from New Motor Vehicles and New Motor Vehicles Engines
Fiat 9.03141
Instrument Panels
GM 9310P
Variabel Surface temperature heat exposure test
GOST 20.57.406
Testing of Electrical Components
IEC 51345
UV Test for photovoltaic Modules
IEC 61215
Crystalline silicon terrestrial photovoltaic (PV) modules - Design qualification and type approval
IEC 904-9
Photovoltaic devices - Part 9: Solar simulation performance requirements
ISO 12097-2
Road vehicles - Airbag components - Part 2: Testing of airbag modules
JSS 5555-No.25
Enviromental Test for Electronic and Electrical equipments
LH 259001
Electronical Equipments
MIL-STD 810
温哥
已经生效了,就看谁先吃螃蟹,不太建议采用这种方法,风险已经全部转移到各单位身上了,
