香烟 | 焦油量 | 发尘量(mg) |
长白山 | 焦油量8mg | 66.9 |
中南海 | 焦油量8mg | 85.5 |
红塔山经典1956 | 焦油量10mg | 80.4 |
七匹狼 | 焦油量8mg | 80.1 |
长白山 | Time(min) | 0 | 2 | 4 | 6 | 8 | 10 | 12 | 14 | 16 | 18 | 20 |
自然衰减 | ∑≥0.3 | 5017066 | 4936757 | 4907915 | 4837143 | 4823861 | 4723822 | 4682896 | 4653745 | 4594170 | 4596757 | 4514093 |
(个/L) | ||||||||||||
lnCt | 15.4284 | 15.4122 | 15.4064 | 15.3918 | 15.3891 | 15.3681 | 15.3594 | 15.3532 | 15.3403 | 15.3409 | 15.3227 | |
总衰减 | ∑≥0.3 | 4309923 | 3004479 | 2120927 | 1505483 | 1039344 | 755097 | 526178 | 359884 | 259807 | 184093 | 128996 |
lnCt | 15.2764 | 14.9156 | 14.5674 | 14.2246 | 13.8541 | 13.5346 | 13.1734 | 12.7935 | 12.4677 | 12.1232 | 11.7675 | |
Kn(min-1)=0.0051 | Ke(min-1)=0.1753 | CADR(m3/h)=306.4 |
红塔山 | Time(min) | 0 | 2 | 4 | 6 | 8 | 10 | 12 | 14 | 16 | 18 | 20 |
总衰减 | ∑≥0.3 | 3737066 | 2612934 | 1896911 | 1298533 | 934595 | 641660 | 439691 | 319305 | 219498 | 150386 | 106139 |
lnCt | 15.1338 | 14.7760 | 14.4557 | 14.0767 | 13.7479 | 13.3718 | 12.9938 | 12.6739 | 12.2991 | 11.9210 | 11.5725 | |
Kn(min-1)=0.0051 | Ke(min-1)=0.1784 | CADR(m3/h)=311.8 |
七匹狼 | Time(min) | 0 | 2 | 4 | 6 | 8 | 10 | 12 | 14 | 16 | 18 | 20 |
自然衰减 | ∑≥0.3 | 4781120 | 4713320 | 4623900 | 4566486 | 4515714 | 4476178 | 4427181 | 4371004 | 4333552 | 4288378 | 4232934 |
lnCt | 15.3802 | 15.3659 | 15.3467 | 15.3343 | 15.3231 | 15.3143 | 15.3033 | 15.2905 | 15.2819 | 15.2714 | 15.2584 | |
总衰减 | ∑≥0.3 | 4342008 | 3094402 | 2140656 | 1528842 | 1063475 | 748996 | 522046 | 358378 | 246332 | 177490 | 124865 |
lnCt | 15.2838 | 14.9451 | 14.5766 | 14.24 | 13.8771 | 13.5265 | 13.1655 | 12.7893 | 12.4144 | 12.0867 | 11.735 | |
Kn(min-1)=0.0059 | Ke(min-1)=0.1785 | CADR(m3/h)=310.7 |
中南海 | Time(min) | 0 | 2 | 4 | 6 | 8 | 10 | 12 | 14 | 16 | 18 | 20 |
总衰减 | ∑≥0.3 | 4219498 | 2933127 | 2073205 | 1449575 | 1025946 | 722548 | 505444 | 344749 | 241506 | 169614 | 121737 |
lnCt | 15.2552 | 14.8916 | 14.5446 | 14.1868 | 13.8411 | 13.4905 | 13.1332 | 12.7506 | 12.3946 | 12.0413 | 11.7096 | |
Kn(min-1)=0.0059 | Ke(min-1)=0.1780 | CADR(m3/h)=309.8 |
自然衰减 | ∑≥0.3 | 4913436 | 4830541 | 4765019 | 4699459 | 4602201 | 4576525 | 4524054 | 4481853 | 4437452 | 4376178 | 4321467 |
lnCt | 15.4075 | 15.3905 | 15.3768 | 15.363 | 15.342 | 15.3365 | 15.3249 | 15.3155 | 15.3056 | 15.2917 | 15.2791 | |
总衰减 | ∑≥0.3 | 3475058 | 2267954 | 1451313 | 943089 | 596950 | 391429 | 245135 | 159923 | 105019 | 69691 | 45637 |
lnCt | 15.0611 | 14.6344 | 14.188 | 13.7569 | 13.2996 | 12.8776 | 12.4096 | 11.9824 | 11.5619 | 11.1518 | 10.7285 | |
Kn(min-1)=0.0063 | Ke(min-1)=0.2178 | CADR(m3/h)=380.7 |
自然衰减 | ∑≥0.3 | 4620386 | 4565328 | 4446718 | 4353784 | 4274903 | 4260579 | 4177876 | 4134170 | 4083514 | 4035985 | 4005753 |
lnCt | 15.346 | 15.334 | 15.3077 | 15.2866 | 15.2683 | 15.2649 | 15.2453 | 15.2348 | 15.2225 | 15.2108 | 15.2032 | |
总衰减 | ∑≥0.3 | 4141158 | 2729228 | 1743822 | 1138842 | 732239 | 468649 | 299073 | 192355 | 122510 | 79151 | 50193 |
lnCt | 15.2365 | 14.8195 | 14.3716 | 13.9455 | 13.5039 | 13.0576 | 12.6084 | 12.1671 | 11.7159 | 11.2791 | 10.8236 | |
Kn(min-1)=0.0072 | Ke(min-1)=0.2211 | CADR(m3/h)=385.0 |
总衰减 | ∑≥0.3 | 3568494 | 2313707 | 1479382 | 973012 | 619344 | 390270 | 261429 | 160618 | 104981 | 70927 | 46332 |
lnCt | 15.0877 | 14.6544 | 14.2071 | 13.7882 | 13.3364 | 12.8746 | 12.4739 | 11.9868 | 11.5615 | 11.1694 | 10.7436 | |
Kn(min-1)=0.0072 | Ke(min-1)=0.2185 | CADR(m3/h)=380.3 |
总衰减 | ∑≥0.3 | 3552046 | 2297027 | 1476448 | 952625 | 609073 | 392548 | 253668 | 166062 | 106680 | 69614 | 44981 |
lnCt | 15.083 | 14.6471 | 14.2051 | 13.767 | 13.3197 | 12.8804 | 12.4438 | 12.0201 | 11.5776 | 11.1507 | 10.714 | |
Kn(min-1)=0.0072 | Ke(min-1)=0.2186 | CADR(m3/h)=380.5 |
总衰减 | ∑≥0.3 | 3734633 | 2107336 | 1159459 | 657375 | 347066 | 199382 | 109035 | 59073 | 33745 | 18571 | 10463 |
lnCt | 15.1332 | 14.5609 | 13.9635 | 13.396 | 12.7573 | 12.203 | 11.5994 | 10.9865 | 10.4266 | 9.8294 | 9.2556 | |
Kn(min-1)=0.0051 | Ke(min-1)=0.295 | CADR(m3/h)=521.4 |
总衰减 | ∑≥0.3 | 4070463 | 2269151 | 1257683 | 696602 | 391699 | 210695 | 121815 | 66255 | 38108 | 21737 | 11699 |
lnCt | 15.2193 | 14.6349 | 14.0448 | 13.4540 | 12.8782 | 12.2582 | 11.7103 | 11.1013 | 10.5482 | 9.9868 | 9.3673 | |
Kn(min-1)=0.0051 | Ke(min-1)=0.2919 | CADR(m3/h)=516.3 |
总衰减 | ∑≥0.3 | 3875598 | 2172510 | 1219614 | 682162 | 372896 | 206062 | 112548 | 64633 | 35290 | 20116 | 12471 |
lnCt | 15.1702 | 14.5914 | 14.014 | 13.433 | 12.8291 | 12.2359 | 11.6311 | 11.0765 | 10.4714 | 9.9093 | 9.4312 | |
Kn(min-1)=0.0051 | Ke(min-1)=0.2907 | CADR(m3/h)=514.3 |
总衰减 | ∑≥0.3 | 4966873 | 2804826 | 1595830 | 850849 | 489537 | 270849 | 148958 | 86873 | 45560 | 25135 | 15097 |
lnCt | 15.4183 | 14.8469 | 14.2829 | 13.654 | 13.1012 | 12.5093 | 11.9114 | 11.3722 | 10.7268 | 10.132 | 9.6223 | |
Kn(min-1)=0.0051 | Ke(min-1)=0.2921 | CADR(m3/h)=516.6 |
米家空气净化器2S | ||||
香烟 | 长白山 | 红塔山 | 七匹狼 | 中南海 |
PCADR(m3/h) | 306.4 | 311.8 | 310.7 | 309.8 |
平均值 | 309.7 | |||
标准偏差 | 2.33 | |||
相对标准偏差 | 0.75% |
米家空气净化器MI3 | ||||
PCADR(m3/h) | 380.7 | 385 | 380.3 | 380.5 |
平均值 | 381.6 | |||
标准偏差 | 2.26 | |||
相对标准偏差 | 0.59% |
米家空气净化器PRO | ||||
PCADR(m3/h) | 521.4 | 516.3 | 514.3 | 516.6 |
平均值 | 517.2 | |||
标准偏差 | 3.01 | |||
相对标准偏差 | 0.58% |
