主题:超高效液相色谱—串联质谱法测定中药材山药中30种农药残留
浏览 |回复2 电梯直达
  张彩凤
(浙江捷岛检测科技有限公司,浙江 杭州 310030)
摘 要:建立了中药材山药中30种农药的超高效液相-串联质谱检测方法。 样品中的农药残留化合物经乙腈提取,BRP固相萃取柱净化,采用 A:缓冲液(0.1 %甲酸溶液含5 mmol/L甲酸铵),B:乙腈-缓冲液(95:5)作为流动相进行梯度洗脱,多反应监测模式(MRM),分段时间窗口采集。30种禁用农药在2.5的线性范围内,线性良好,相关系数在0.9974~1.0000之间。在0.06、0.10、0.12 3个添加浓度水平进行了回收率试验,平均回收率61 %~108 %,相对标准偏差在0.24 %~8.11%(n=6)之间,各农药成分的检出限在0.11~5之间。该方法操作简单,灵敏度、准确度和精密度均符合多农残检测技术的要求,可为中药材中农残风险评估研究提供准确有效的数据支持。
关键词:超高效液相色谱—串联质谱;山药; 农药残留
Detection of 30 pesticides residues in traditional Chinese medicine Dioscorea opposita by ultra performance liquid chromatography-tandem mass spectrometric
Zhang Caifeng
(Zhejiang Jiedao detection technology co., Ltd, Hangzhou city, Zhejiang Province, China 310030)
Abstract:  An ultra performance liquid chromatography-tandem mass spectrometric method was developed for the determination of thirty pesticides in traditional Chinese medicine Dioscorea opposita; The pesticides were extracted with acetonitrile,cleaned up by BRP solid phase extraction column; Gradient elution was carried out using A:Buffer (0.1% formic acid solution containing 5 mmol/L ammonium formate) and B: acetonitrile - Buffer (95:5) as mobile phases, and Multiple reaction monitoring(MRM) model was used, The data of the detector was collected by time windows. The recoveries at 3 spiked levels 0.06 mg▪kg-1、0.10 mg▪kg-1 and 0.12 mg▪kg- 1 of 30 target compounds were ranged from 61% to 108%, with the relative standard debiations(RSD) from 0.11% to 8.11% (n=6), and the detection limit were ranged from 0.11μg ▪ kg-1  to 5.0μg ▪ kg-1  (S/N=3). This simple , sensitive and accurate method can be applied to supplying reliable data for the study of the risk assessment of traditional Chinese medicine.
Key words: ultra performance liquid chromatography-tandem mass spectrometric ;  Dioscorea opposita ;  pesticide residues
山药(Dioscorea opposita),别名怀山药、淮山药、土薯、山薯、玉延等,主要产于中国华北、西北及长江流域的江西、湖南等地。山药味甘性平,归脾、肺、肾经,具有补脾养胃、生津益肺、补肾涩精等功效,现代药理学研究表明,其具有抗氧化、抗衰老、调节免疫、抗肿瘤、降血糖等作用【1】。为患者或体弱者服用,随着人们对药品安全性要求不断提高,农药残留问题成为人们关注的焦点,由于某些农药具有残留周期长、污染范围广等特点,为保护消费者的健康,建立高灵敏度、高选择性的多农残检测方法,是农药残留检测技术的发展趋势【2】。对“绿色中药材”的生产具有重要意义【3】。
农残检测的方法有:薄层色谱法【4】、气相色谱法【5-7】、液相色谱法【8-9】,气质联用法【10-13】、液质联用法【13-18】、免疫分析法【18-19】等。本文通过色谱条件的优化选择,建立了山药中30种农药残留的超高效液相色谱-串联质谱检测法。该方法操作简单、经济实用,灵敏度、准确度和精密度均符合多农残检测技术的要求,可为中药材中农残风险评估研究提供准确有效的数据支持。
1 实验部分
1.1 主要仪器和设备
超高效液相色谱仪:Acquity  UHPLC,含四元梯度泵、样品管理器、柱温箱 ,美国沃特世公司;串联质谱:API 4000 ,美国AB 公司;化学工作站:Analyst,美国AB SCIEX ;分析柱:  Acquity UPLC  BEH C18 2.1 mm*100 mm ,1.7μm 美国沃特世公司;离心机: TDL-40B  ,上海安亭科学仪器厂;氮吹仪: MTN-2800W ,天津奥特赛恩斯仪器有限公司 ;固相萃取仪:ASE-12,  天津奥特赛恩斯仪器有限公司 ;漩涡混合器: XW-80A    上海沪西分析仪器厂有限公司;固相萃取柱:Welchrom BRP 200 mg/6 mL,月旭科技(上海)股份有限公司;电子分析天平:感量0.1mg,上海舜宇恒平科学仪器有限公司; 移液枪:(100-1000)μL、(20-200)μL 、(5-50)μL,美国赛默飞科技(中国)有限公司  ; 微孔滤膜:尼龙 0.22μm ,岛津GL(上海)商贸有限公司
1.2 试剂
30种农药混合标液: 100μg ▪ mL-1(乙腈);上海安谱科学仪器有限公司;乙腈:HPLC级 ,美国天地公司;甲酸:分析纯, 阿拉丁试剂上海有限公司;甲酸铵:分析纯 阿拉丁试剂上海有限公司;超纯水: Milli-Q Element A10  , 德国默克;山药粉:安徽一中药饮片厂
1.3 标准溶液的制备
混合禁用农药标准储备液(1.0 μg ▪ mL-1):移取100 μL浓度为100μg ▪ mL-1的农药混合标液,用乙腈定容至10 mL,摇匀,备用;
混合农药标准储备液(100 ng ▪ mL-1):移取1.0 mL浓度为1.0μg ▪ mL-1的混合禁用农药标准储备液,用乙腈定容至10 mL,摇匀,备用。
基质混合标液的制备:分别精密移取空白基质溶液1.0 mL(7份),置氮吹仪上,40 ℃水浴浓缩至近干,分别精密移取一定体积的1.0 μg ▪ mL-1、100 ng ▪ mL-1的混合禁用农药标准储备液,用乙腈-水溶液(1:1)稀释到1mL,微孔滤膜过滤后待上机。所配系列标准溶液浓度见表1。
表1  30种混合禁用农药标液浓度表
(单位 ng ▪ mL-1)
农 药空白基质浓度1浓度2浓度3浓度4浓度5浓度6
30种
2.5
5
10
25
50
75
1.4 空白基质溶液的制备
  取空白基质样品,同供试品溶液的制备方法处理成空白基质溶液。
1.5 样品的提取和净化
1.5.1 样品提取
取供试品粉末(过三号筛)5g,精确到0.1 mg,加氯化钠 1g,精确到1mg,立即摇散,再加入50mL乙腈,震荡、漩涡混合2 min,离心5min,收集上清液,沉淀中再加入50 mL乙腈,震荡、漩涡混合2 min,离心5min,合并上清液,40℃氮吹浓缩至近干,用乙腈溶液稀释至10mL。摇匀,待净化。
1.5.2 样品净化
移取1.5.1 提取的样品溶液3mL,通过BRP固相萃取柱净化,收集全部滤液,混匀,精密移取1.0 mL,置氮吹仪上,40℃水浴浓缩至近干,用乙腈—水溶液(1:1)稀释到1mL,微孔滤膜过滤后待上机。
1.6 分析条件
1.6.1 液相条件
流动相A: 缓冲盐(0.1%甲酸溶液含5mmol/L甲酸铵),流动相B: 乙腈-缓冲盐(95:5),洗脱方式见 表2
流  速:0.20 mL/min
进样量:10μL
表2  流动相梯度洗脱
时间(min)
A (%)
B (%)
0-0.5
70
30
9 -11
10
90
11.01-14
70
30
1.6.2 质谱条件
离子源: 电喷雾离子源(ESI),正离子扫描模式 ;
监测模式:多反应监测(Schudled  MRM);
喷雾电压:5500 V;脱溶剂温度:550 ℃
气帘气:10 psi ;碰撞气:6
辅助气(GAS1、GAS2): 55 psi
化合物保留时间、监测离子对、碰撞电压等参数见表3
表3    30种农药质谱参数
化合物
离子对
(m/z)
保留时间(min)
DP
(V)
CE
(V)
化合物
离子对
(m/z)
保留时间(min)
DP
(V)
CE
(V)
甲胺磷
142.1 > 94.0 *
1.21
65
20
胺苯磺隆
411.0 > 196.1 *
4.51
80
22
142.1 > 125.1
1.21
65
18
411.0 > 168.1
4.51
80
40
涕灭威亚砜
207.2 > 89.0 *
1.24
65
17
甲拌磷亚砜
277.1 > 199.0 *
4.63
65
15
207.2 > 132.1
1.24
65
10
277.1 > 171.0
4.63
65
19
久效磷
224.2 > 193.1 *
1.39
65
11
内吸磷
259.1 >  89。0 *
5.43
52
11
224.2 > 127.1
1.39
65
22
259.1 >61.1
5.43
52
45
涕灭威砜
223.2 > 76.0 *
1.54
75
12
特丁硫磷亚砜
305.3 > 187.1 *
5.72
65
16
223.2 > 86.1
1.54
75
22
305.3 > 97.0
5.72
65
50
240.2 > 223.1 *
1.54
40
11
甲拌磷砜
293.1 > 171.1 *
5.83
70
16
240.2 > 86.2
1.54
40
25
293.1> 247.0
5.83
70
10
杀虫脒
197.2> 117.1 *
1.98
120
40
水胺硫磷
312.2 > 270.0 *
5.87
70
20
197.2 > 46.1
1.98
120
43
312.2 > 236.1
5.87
70
22
3-羟基克百威
238.1> 181.0 *
2.18
75
17
苯线磷
304.3 > 217.2 *
6.45
100
31
238.1 > 163.2
2.18
75
18
304.3 > 234.1
6.45
100
25
硫环磷
256.1 > 140.0 *
2.84
85
35
灭线磷
243.2 > 131.0 *
6.75
70
30
  256.1 > 168.1
2.84
85
22
243.2 > 97.0
6.75
70
40
苯线磷亚砜
320.3 > 171.1 *
3.11
110
31
特丁硫磷砜
321.2 > 171.0 *
6.77
75
16
320.3 > 292.1
3.11
110
21
321.2 > 96.9
6.77
75
50
磷胺
300.2 > 174.1 *
3.32
80
20
氯唑磷
314.2 > 162.1 *
7.63
80
22
300.2 > 127.1
3.32
80
25
314.2 > 120.1
7.63
80
35
涕灭威
213.2 > 89.0 *
3.4
30
24
蝇毒磷
363.2 > 227.0 *
8.22
100
35
213.2 > 116.0
3.4
30
16
363.2 > 307.0
8.22
100
25
208.2 > 89.0 *
3.4
30
24
甲基异柳磷
332.2 > 273.1 *
8.27
50
8
208.2 > 116.0
3.4
30
16
332.2 > 231.0
8.27
50
17
甲磺隆
382.1> 167.2 *
3.95
100
25
硫线磷
271.1 > 159.0 *
8.28
65
19
382.1 > 199.1
3.95
100
30
271.1 > 131.1
8.28
65
31
苯线磷砜
336.2 > 188.2 *
4.04
100
37
地虫硫磷
247.1 > 137.1 *
8.44
60
15
336.2 > 266.1
4.04
100
30
247.1 > 109.1
8.44
60
25
氯磺隆
358.2 > 167.1 *
4.27
120
25
治螟磷
323.2 > 171.2 *
8.5
77
18
358.2 > 141.2
4.27
120
25
323.2 > 115.0
8.5
77
40
克百威
222.2 > 165.2 *
4.36
70
18
甲拌磷
261.2 > 75.0 *
8.6
45
16
222.2 > 123.0
4.36
70
30
261.2 > 47.1
8.6
50
45
注:标注“*”为定量离子
2  结果与讨论
2.1 液相条件的建立
实验考察了流动相中缓冲盐浓度、梯度条件、流速对30种农药分析效果的影响。不同比例的缓冲盐浓度、梯度条件和流速,对各组分的响应值、分离度、保留时间以及峰型都有很大影响,随着缓冲盐浓度增加,各组分的响应值增加,当甲酸和甲酸铵浓度高于1.6中条件时,各组分的响应值无明显增加;随着流动相比例增加,各组分保留时间缩短分离度下降,部分组分响应值降低,当有机相比列降低,保留时间加长,峰型变宽,灵敏度下降;当增大流速时,出峰太快,组分分离度下降,当降低流速时,保留时间加长,峰宽变宽,灵敏度下降。
综合各因素考虑,流动相及梯度为1.6中条件时,30组分的灵敏度及分析效果最佳。
2.2 质谱条件的选择
  实验考查了GAS1、GAS2、气帘气、碰撞气、DP电压、CE电压等参数对各物质响应值的影响,实验表明,1.6中的质谱参数化合物能够获得更高的响应值;为了消除复杂基质对检测灵敏度的影响,采用Schudled  MRM监测方式,减少基质的干扰,大大提高了各待测组分的灵敏度和定量的准确性。30种禁用农残的加标图谱见图1、多反应监测色谱图见表4
图1  0.06 mg·kg-1 山药加标图谱
表4  多反应监测色谱图
化合物
离子对 (m/z)
色谱图
离子对 (m/z)
色谱图
化合物
离子对 (m/z)
色谱图
离子对 (m/z)
色谱图
甲胺磷
142.1 > 94.0 *
142.1 > 125.1
胺苯磺隆
411.0 > 196.1 *
411.0 > 168.1
涕灭威亚砜
207.2 > 89.0 *
207.2 > 132.1
甲拌磷亚砜
277.1 > 199.0 *
277.1 > 171.0
久效磷
224.2 > 193.1 *
224.2 > 127.1
内吸磷
259.1 > 89.0 *
259.1 > 61.1
涕灭威砜
223.2 > 76.0 *
223.2 > 86.1
特丁硫磷亚砜
305.3 > 187.1 *
305.3 > 97.0
240.2 > 223.1 *
240.2 > 86.2
甲拌磷砜
293.1 > 171.1 *
293.1> 247.0
杀虫脒
197.2> 117.1 *
197.2 > 46.1
水胺硫磷
312.2 > 270.0 *
312.2 > 236.1
3-羟基克百威
238.1> 181.0 *
238.1 > 163.2
苯线磷
304.3 > 217.2 *
304.3 > 234.1
硫环磷
256.1 > 140.0 *
  256.1 > 168.1
灭线磷
243.2 > 131.0 *
243.2 > 97.0
苯线磷亚砜
320.3 > 171.1 *
320.3 > 292.1
特丁硫磷砜
321.2 > 171.0 *
321.2 > 96.9
磷胺
300.2 > 174.1 *
300.2 > 127.1
氯唑磷
314.2 > 162.1 *
314.2 > 120.1
涕灭威
213.2 > 89.0 *
213.2 > 116.0
蝇毒磷
363.2 > 227.0 *
363.2 > 307.0
208.2 > 89.0 *
208.2 > 116.0
甲基异柳磷
332.2 > 273.1 *
332.2 > 231.0
甲磺隆
382.1> 167.2 *
382.1 > 199.1
硫线磷
271.1 > 159.0 *
271.1 > 131.1
苯线磷砜
336.2 > 188.2 *
336.2 > 266.1
地虫硫磷
247.1 > 137.1 *
247.1 > 109.1
氯磺隆
358.2 > 167.1 *
358.2 > 141.2
治螟磷
323.2 > 171.2 *
323.2 > 115.0
克百威
222.2 > 165.2 *
222.2 > 123.0
甲拌磷
261.2 > 75.0 *
261.2 > 47.1
2.3 线性方程和检出限
在1.6分析条件下,对基质混合标液进行测定,对各化合物的质量浓度x(ng·mL-1)和定量离子的丰度y(counts)进行线性回归,用3倍噪声(S/N=3)对应的溶液浓度表示待测组分的方法检出限,30种农药的线性回归方程、相关系数及检出限见表5。
    表5  线性回归方程及检出限
化合物
线性回归方程
相关系数(r)
检出限        (μg ▪ kg-1
甲胺磷
y = 1.11e+003 x + -279
0.9996
5.00
涕灭威亚砜
y = 1.79e+003 x + 9.58e+003
0.9990
2.00
久效磷
y = 1.43e+004 x + -1.29e+003
0.9999
1.00
涕灭威砜
y = 2.3e+003 x + -2.11e+003
0.9993
4.00
y = 2.32e+004 x + 5.87e+004
0.9982
5.00
杀虫脒
y = 2.03e+003 x + -694
0.9997
5.00
3-羟基克百威
y = 4.63e+003 x + -836
0.9998
2.50
硫环磷
y = 1.98e+004 x + -2.12e+003
1.0000
0.42
苯线磷亚砜
y = 1.04e+004 x + -5.92e+003
0.9998
0.87
磷胺
y = 2.73e+004 x + 2.09e+003
0.9999
0.56
涕灭威
y = 282 x + -65.4
0.9983
5.00
y = 1.44e+003 x + -544
0.9983
2.00
甲磺隆
y = 6.92e+003 x + -3.3e+003
0.9990
0.77
苯线磷砜
y = 8.26e+003 x + -4.59e+003
0.9998
0.77
氯磺隆
y = 226 x + -253
0.9980
5.00
克百威
y = 2.36e+004 x + -2.32e+003
0.9999
0.77
胺苯磺隆
y = 3.02e+004 x + -1.35e+004
0.9995
0.54
甲拌磷亚砜
y = 2.43e+004 x + 1.73e+003
0.9999
0.44
内吸磷
y = 310 x + -359
0.9986
4.00
特丁硫磷亚砜
y = 3.62e+004 x + 1.21e+004
0.9995
0.18
甲拌磷砜
y = 5.9e+003 x + 3.28e+003
0.9996
1.67
水胺硫磷
y = 949 x + 175
0.9998
1.67
苯线磷
y = 4.36e+004 x + 3.01e+003
0.9997
0.45
灭线磷
y = 1.78e+004 x + -112
0.9996
1.33
特丁硫磷砜
y = 8.04e+003 x + -2.23e+003
0.9992
0.91
氯唑磷
y = 5.27e+004 x + -1.13e+004
0.9998
0.11
蝇毒磷
y = 1.58e+004 x + -69.3
0.9996
0.49
甲基异柳磷
y = 4.93e+003 x + 2.57e+003
0.9974
0.61
硫线磷
y = 7.77e+004 x + 1.16e+004
0.9998
0.80
地虫硫磷
y = 1.23e+004 x + -4.32e+003
0.9997
1.00
治螟磷
y = 2.39e+004 x + -5.06e+003
0.9995
0.23
甲拌磷
y = 4.98e+003 x + -2.9e+003
0.9997
2.00
2.4 精密度与加标回收试验
按1.5方法对添加一定量30种混合农残标液的山药样品进行处理后,在1.6条件下测定,每个添加水平完成6次平行测定,进行加标回收试验,结果见表6。由表6可知,禁用农残的添加水平在0.06 mg▪kg-1、0.10 mg▪kg-1、0.12 mg▪kg-1时,平均回收率在61 %-108 %之间,相对标准偏差在0.24 %-8.11%(n=6),试验表明除了甲胺磷在低添加水平时回收率偏低外,其他29种农药的回收率及精密度均满足残留的分析要求。
2.5 样品测定
  利用本研究对3个山药样品进行检测,30种农药均未检出。
表6
3结束语
建立了超高效液相-串联质谱法同时测定30种农残的检测方法,该方法前处理简单,分析时间短,专属性强,回收率良好,为中药饮片风险评估研究提供准确有效的数据支持。
            参 考 文 献
邵礼梅,许世伟.山药化学成分及现代药理研究进展.中医药学报,2017,45(2):
    125-127.
佟鹤芳,薛健,吴晓波.中药材农药残留检测方法与标准研究.中国现代中药,2011,13
(6:49-51.
柴连周,郭妮,董寿堂等.中药材中农残检测方法探究.云南化工,2019,46(10):92-93.
胡秋菊,朱若华,苏文斌等.中药材中西维因残留量的薄层色谱法测定.首都师范大学学报,2004,25(2):38-45.
党娟, 杨刚, 李乾. 气相色谱法快速测定红心猕猴桃中9种有机磷农药残留. 农产品加工, 2017(22):43-45.
罗炜, 李自力, 张海央等. 串联柱气相色谱测定蔬菜和水果中19种有机磷农药残留. 浙江预防医学, 2020, 032(004):429-432.
杨秀虾. 气相色谱法测定蒲公英中有机磷农药残留. 粮食流通技术, 2020, 000(006):166-169.
杨景.高效液相色谱法测定蔬菜中有机磷农药的残留量. 农产品加工, 2017(22):43-45.河北企业,2016(2):118-119.
冯岩,祝金,液相色谱技术在农药残留分析中的应用.农业咨询,2018,6:113.
崔如玉,李壹,熊晓辉.食品中常见有机磷农药残留的气相色谱-质谱检测方法.南京工业大学学报(自然科学版),2017,39(1):137-144.
张国莹,朱立蕊.食品中常见有机磷农药残留的气相色谱质谱检测方法探讨.食品安全导刊,2018,27:82-83.
张云, 李登昆, 刘祥萍,等. 气相色谱-三重四极杆串联质谱法测定蔬菜水果中12种有机磷农药残留. 现代预防医学, 2019(11).
中华人民共和国药典  2020年版 四部. 国家药典委员会,2020:275-279.
李娜,邵辉,刘磊等.中药材黄芪中有机磷农药残留量的超高效液相色谱-串联质谱法研究. 药物分析杂志,2012,5:852-856.
李家春, 伍静玲, 秦建平等.基于QuEChERS法-超高效液相色谱-串联质谱法的5种中药材中35种有机磷农药残留量的快速分析. 药物分析杂志, 2016, 036(001):122-128.
孙亮,高慧,李长坤等.岛津LCMS-8060液质联用同时测定人参中129种农药残留.绿色生态可持续发展与植物保护——中国植物保护学会第十二次全国会员代表大会暨学术年会论文集. 2017.
陈楠,马世柱,黎小鹏等. QuEChERS-三重四级杆液质联用仪检测草莓中多种农药残留. 现代农业科技,2018,12:115-117.
祝愿,李俊。蔡涛等.高效液相色谱-串联质谱法检测茶靑中124种农药残留. 食品安全检测学报,2019,10(8):2317-2329.
夏敏,王欣欣,杨文学,等.酶联免疫技术快速测定蔬菜和水果中的农残. 现代科学仪器,2006,1(1):104-105.
欧阳辉.中药中农药残留和重金属的化学花光免疫传感器的构建及性能研究.重庆:西南大学,2017.
用户运营部
lijing320323
sdlzkw007
