主题:【悬赏帖】求助英文文献
浏览 |回复6 电梯直达
bairuizheng
悬赏金额:10积分 状态: 已解决
【序号】:1
【作者】:Eric M. Schiesser et al
【题名】:Estimating field-dependent nodal aberration theory coefficients from Zernike full-field displays by utilizing eighth-order astigmatism
【期刊】: JOSA A > Volume 36 > Issue 12 > Page 2115    2019
【全文链接】:https://doi.org/10.1364/JOSAA.36.002115
【序号】:2
【作者】:Yinxin Zhang et al
【题名】:Broadband aberration-corrected snapshot spectrometer with a toroidal slicer mirror
【期刊】:Applied Optics Vol. 58, Issue 4, pp. 826-832 (2019)
【全文链接】:https://www.osapublishing.org/ao/abstract.cfm?uri=ao-58-4-826
【序号】:3
【作者】:Zhengxiang Shen  et al
【题名】:Customized design and efficient fabrication of two freeform aluminum mirrors by single point diamond turning technique
【期刊】:Applied Optics Vol. 58, Issue 9, pp. 2269-2276 (2019)
【全文链接】:https://www.osapublishing.org/ao/abstract.cfm?uri=ao-58-9-2269
【序号】:4
【作者】:Qingyu Meng et al
【题名】:Design of off-axis three-mirror systems with ultrawide field of view based on an expansion process of surface freeform and field of view
【期刊】:Applied Optics Vol. 58, Issue 3, pp. 609-615 (2019)
【全文链接】:https://www.osapublishing.org/ao/abstract.cfm?uri=ao-58-3-609
【序号】:5
【作者】:E. M. Schiesser et al
【题名】:Design and alignment of an all-spherical unobscured four-mirror image relay for an ultra-broadband sub-petawatt laser
【期刊】:Applied Optics Vol. 58, Issue 35, pp. 9514-9523 (2019)
【全文链接】:https://www.osapublishing.org/ao/abstract.cfm?URI=ao-58-35-9514
最佳答案:h04206010006回复于2021/01/14
33333333
推荐帖
Last edit by dong3626 举报
h04206010006
h04206010006
h04206010006
h04206010006
h04206010006
zk200512345
