主题:【已应助】TOPAS仪器参数
浏览 |回复4 电梯直达
Ins_146cc68a
  lPSD参数
lpsd_th2_angular_range_degrees #
        lpsd_equitorial_divergence_degrees #
        lpsd_equitorial_sample_length_mm #
    Full_Axial_Model(12, 15, 12, 2.5, @ 8),@8这个参数看什么
以下是仪器参数信息,请大佬帮忙看一下
Date=04/01/2021
Type=USER
Flags=0
Value=Lab Manager
[VarInfo]
Type=SAMPLEID
Flags=0
Value=Commander Sample ID
[VarInfo]
Type=COMMENT
Flags=0
Value=
[VarInfo]
Type=UTF
Flags=0
Value=
[VarInfo]
Type=CREATOR
Flags=0
Value=BrmlToV4Converter
EstimatedTotalTime=2013.96
[VarInfo]
Type=CREATOR_VERSION
Flags=0
Value=6.5.0.0
[HardwareConfiguration]
AbsorptionFactor=9999
ActivateAbsorber=0
Alpha1=1.5406
Alpha2=1.54439
AlphaAverage=1.5418
AlphaRatio=0.5
Analyzer=0
Anode=Cu
AntiScatteringSlit=18
BeamOpticsFlags=0
Beta=1.39222
BetaRelativeIntensity=0
DeactivateAbsorber=0
DetectorSlit=9999
DivergenceSlit=10.5
GoniometerControl=0
GoniometerDiameter=560
GoniometerModel=512
GoniometerStage=4
Monochromator=0
NearSampleSlit=9999
PrimarySollerSlit=2.5
SampleChanger=0
SecondSollerSlit=2.5
SynchronousAxis=0
ThinFilmAttachment=9999
WaveUnit=A
[RangeHeader]
ActuallyUsedLambda=1.5418
AdditionalDetectorMask=257
DataRecordLength=4
DelayTime=0
DisplayPlaneNumber=0
EstimatedScanTime=2014
ExtraParametersMask=0
GeneratorCurrent=40
GeneratorVoltage=40
Increment=0.0204806
Increment3=0
NumberOfCompletedData=3175
NumberOfCounts=1
NumberOfDetectors=0
NumberOfDrives=5
NumberOfEncoderDrives=0
NumberOfMeasuredData=3175
NumberOfVaryingParameters=0
RangeStartTime=0
RotationSpeed=0
ScanMode=1
ScanType=Locked Coupled
SimulatedMeasConditions=0
SlitChangerIn=0
SmootingWidth=0
Start=5
Steps=3175
SynchronousRotation=0
Time=115.2
[VarInfo]
Type=PSD_DISCRIM
Flags=0
Value=0.198;0.22
[PSD]
ActualTwoTheta=9999
FirstUsedChannel=0
FixedPSD=0
PSDOpening=2.9492
PSDType=5
[Drive]
DriveFlags=1
DriveName=2Theta
DriveNumber=2
DriveOffset=0
OffsetIndex=0
OscillationAmplitude=0
OscillationSpeed=0
StartPosition=5
[Drive]
DriveFlags=1
DriveName=Theta
DriveNumber=1
DriveOffset=0
OffsetIndex=0
OscillationSpeed=0
StartPosition=2.5
[Drive]
DriveFlags=1
DriveName=Chi
DriveNumber=4
DriveOffset=0
OffsetIndex=0
OscillationSpeed=0
StartPosition=-0
[Drive]
DriveFlags=1
DriveName=Phi
DriveNumber=3
DriveOffset=0
OffsetIndex=0
OscillationSpeed=0
StartPosition=0
[Drive]
DriveFlags=0
DriveName=Z-Drive
DriveNumber=7
DriveOffset=0
OffsetIndex=0
OscillationSpeed=0
StartPosition=0.105
最佳答案:iangie回复于2021/04/09
lpsd_th2_angular_range_degrees #                                  PSDOpening=2.9492
        lpsd_equitorial_divergence_degrees #                        DivergenceSlit=10.5  一般来说发散狭缝开0.3到1度, 不知道你为什么开这么大, 你最好确认下狭缝宽度
        lpsd_equitorial_sample_length_mm #                        这个是你的样品槽长度  机器不可能知道你的样品在X射线方向上的长度 只有你自己填了
你看一下这个帖子: TOPAS仪器参数的设置_X射线衍射仪(XRD)仪器社区_仪器信息网论坛 (instrument.com.cn)
更多
相关课程
iangie
Full_Axial_Model(光管灯丝宽度, 样品宽度, 探测器宽度, 初级索拉狭缝, 次级索拉狭缝)
你的文件头里面初级次级索拉都是2.5 不知道你为什么要写成 @8
Ins_146cc68a
lPSD参数
linear PSD参数怎么看
在上面仪器参数找不到对应的
iangie
原文由 Ins_146cc68a(Ins_146cc68a) 发表:
lPSD参数
linear PSD参数怎么看
在上面仪器参数找不到对应的
2021/4/9 14:58:53 Last edit by iangie
Ins_146cc68a
原文由 iangie(iangie) 发表:
谢谢
