主题:【已应助】jade里没有我要的立方结构结构的PDF卡片
浏览 |回复4 电梯直达
Insm_b179373e
    我做的立方相CsPBI3没有标准卡片可以对照,求哪位大佬有没有类似的资源可以分享一下嘛?
最佳答案:iangie回复于2021/06/10
https://doi.org/10.1016/j.jpcs.2008.05.007
iangie
Insm_b179373e
原文由 iangie(iangie) 发表:
感谢回复!但是我看了这篇文章还是得不到立方相的PDF卡啊,我不太明白能再解释一下吗?
iangie
原文由 Insm_b179373e(Insm_b179373e) 发表:
文中发表了立方相的晶体结构
有了晶体结构你可以用软件算出衍射谱来啊
          h        k        l        m          d                    th2                    F^2
1        1        0        0        6          6.28940          14.07000            33.102
2        1        1        0        12          4.44728          19.94863            65.198
3        1        1        1        8          3.63119          24.49487          106.158
4        2        0        0        6          3.14470          28.35790          364.344
5        2        1        0        24          2.81271          31.78863          100.985
6        2        1        1        24          2.56764          34.91553          103.162
7        2        2        0        12          2.22364          40.53619          575.499
8        3        0        0        6          2.09647          43.11402            20.740
9        2        2        1        24          2.09647          43.11402            82.962
10        3        1        0        24          1.98888          45.57343            85.041
11        3        1        1        24          1.89633          47.93340          191.562
12        2        2        2        8          1.81559          50.20867          317.827
13        3        2        0        24          1.74437          52.41101            70.166
14        3        2        1        48          1.68091          54.54999          143.813
15        4        0        0        6          1.57235          58.66833          202.690
16        4        1        0        24          1.52540          60.66003            60.262
17        3        2        2        24          1.52540          60.66003            60.262
18        4        1        1        24          1.48243          62.61352            61.907
19        3        3        0        12          1.48243          62.61352            30.953
20        3        3        1        24          1.44289          64.53310          137.867
21        4        2        0        24          1.40635          66.42250          700.415
22        4        2        1        48          1.37246          68.28509          104.598
23        3        3        2        24          1.34090          70.12386            53.996
24        4        2        2        24          1.28382          73.74057          611.493
25        4        3        0        24          1.25788          75.52329            45.759
26        5        0        0        6          1.25788          75.52329            11.440
27        5        1        0        24          1.23345          77.29179            47.550
28        4        3        1        48          1.23345          77.29179            95.100
29        5        1        1        24          1.21040          79.04807          104.919
30        3        3        3        8          1.21040          79.04807            34.973
31        4        3        2        48          1.16791          82.53132            80.623
32        5        2        0        24          1.16791          82.53132            40.312
33        5        2        1        48          1.14828          84.26177            84.354
34        4        4        0        12          1.11182          87.70856          238.084
35        4        4        1        24          1.09484          89.42805            35.725
36        5        2        2        24          1.09484          89.42805            35.725
37        4        3        3        24          1.07862          91.14705            37.622
38        5        3        0        24          1.07862          91.14705            37.622
39        5        3        1        48          1.06310          92.86707          163.843
40        6        0        0        6          1.04823          94.58968          105.904
41        4        4        2        24          1.04823          94.58968          423.616
42        6        1        0        24          1.03397          96.31647            31.828
43        6        1        1        24          1.02028          98.04903            33.712
44        5        3        2        48          1.02028          98.04903            67.424
45        6        2        0        24          0.99444        101.53822          378.545
46        6        2        1        48          0.98224        103.29838            56.980
47        5        4        0        24          0.98224        103.29838            28.490
48        4        4        3        24          0.98224        103.29838            28.490
49        5        4        1        48          0.97048        105.07141            60.645
50        5        3        3        24          0.95912        106.85935            65.147
51        6        2        2        24          0.94816        108.66437          339.621
52        6        3        0        24          0.93757        110.48881            25.609
53        5        4        2        48          0.93757        110.48881            51.218
54        6        3        1        48          0.92732        112.33523            54.722
55        4        4        4        8          0.90780        116.10555          101.935
56        6        3        2        48          0.89849        118.03602            46.209
57        7        0        0        6          0.89849        118.03602            5.776
58        5        5        0        12          0.88946        120.00179            12.379
59        5        4        3        48          0.88946        120.00179            49.515
60        7        1        0        24          0.88946        120.00179            24.757
61        5        5        1        24          0.88069        122.00732            52.638
62        7        1        1        24          0.88069        122.00732            52.638
63        6        4        0        24          0.87218        124.05775          276.266
64        7        2        0        24          0.86392        126.15905            20.913
65        6        4        1        48          0.86392        126.15905            41.827
66        6        3        3        24          0.85588        128.31827            22.456
67        5        5        2        24          0.85588        128.31827            22.456
68        7        2        1        48          0.85588        128.31827            44.912
69        6        4        2        48          0.84046        132.84601          500.676
70        5        4        4        24          0.83305        135.23743            18.985
71        7        2        2        24          0.83305        135.23743            18.985
72        7        3        0        24          0.82584        137.73410            20.412
73        5        5        3        24          0.81881        140.35677            43.147
74        7        3        1        48          0.81881        140.35677            86.294
75        6        5        0        24          0.80528        146.10214            17.279
76        6        4        3        48          0.80528        146.10214            34.557
77        7        3        2        48          0.79875        149.32036            37.180
78        6        5        1        48          0.79875        149.32036            37.180
Apri2
文中发表了立方相的晶体结构
有了晶体结构你可以用软件算出衍射谱来啊
          h        k        l        m          d                    th2                    F^2
版主,能详细说说这是咋算的不?因为我用的学术版进行多相的定量分析,但是有些物相在Findit中找不到相应的cif文件,前天了解到了VESTA软件,但不明白某一物相中所有原子的详细信息怎么得到(比如:x,y,z,occ,B...这些)。
