主题:【第十四届原创】超高效液相色谱-串联质谱法测定饮用水中3种有机锡
浏览 |回复6 电梯直达
hejiahuan
维权声明:本文为hejiahuan原创作品,本作者与仪器信息网是该作品合法使用者,该作品暂不对外授权转载。其他任何网站、组织、单位或个人等将该作品在本站以外的任何媒体任何形式出现均属侵权违法行为,我们将追究法律责任。
  建立饮用水中三苯基氯化锡(TPT)、三丁基氯化锡(TBT)、三环锡(CYT)3种有机锡的超高效液相色谱-串联质谱检测方法。 采用直接进样,流动相 A为甲醇-0.1 %甲酸溶液,流动相B为0.1 %甲酸-5 mmol/L甲酸铵缓冲盐溶液,梯度洗脱,用多反应监测模式(MRM)检测。3种有机锡的质量浓度在1.0 ng/mL ~100 ng/mL范围内与定量离子的丰度值线性关系良好,相关系数为0.9991~0.9998,各有机锡组分的检出限为0.003 ng/mL~0.029 ng/mL(S/N=3)。样品在2.0 ng/mL、10.0 ng/mL、50.0 ng/mL 3个添加浓度水平时的平均回收率为87.5 %~113.5 %,测定结果的相对标准偏差为0.00 %~4.78 %(n=6)。该方法满足水质中多种有机锡的检测要求。
关键词:超高效液相色谱—串联质谱法;饮用水; 有机锡
Determination of three organotins in drinking water by
ultra performance liquid chromatography-tandem mass spectrometry
Zhang Caifeng
(Zhejiang Jiedao detection technology Co., Ltd, Hangzhou 310030, China)
Abstract  A method of determination of Chlorotriphenyltin(TPT), chlorotributyltin(TBT) and cyhexatin(CYT)  3 kinds of organotin in drinking water by ultra performance liquid chromatography-tandem mass spectrometric was established. Sampling direct injection, the mobile phase A was methanol-0.1 % formic acid solution, and the mobile phase B was 0.1% formic acid-5 mmol / L ammonium formate buffer solution. The gradient elution was used and the multi reaction monitoring mode (MRM) was used for detection. The mass concentration of six organotin compounds had a good linear relationship with the quantitative ion abundance values in the range of 1.0 ng / mL ~ 100 ng / mL,  the correlation coefficients were 0.9991 ~ 0.9998, and the detection limit of each organotin component was 0.003 ng / mL ~ 0.029 ng / mLS/N=3. The average recoveries of the samples at 2.0 ng / mL, 10.0 ng / mL and 50.0 ng/ml levels was 87.5 % 113.5 %, and the relative standard deviations of determination results was 0.00 %4.78 % (n = 6). The method can meet the requirements of determination of variety of organotin in water.
Keywords  ultra performance liquid chromatography-tandem mass spectrometry ; drinking Water ;  organotin
有机锡是锡和碳元素直接连接所形成的金属有机化合物,广泛用作聚氯乙烯稳定剂、防污涂料、杀虫剂、杀菌剂以及合成聚氨酯和硅酮等的稳定剂。饮用水中有机锡污染主要来源于输水系统中PVC管材和水源污染[1]。三环锡(CYT)属于金属类农药,具有动物致畸作用[2]2006年5月29日日本实施的“肯定列表制度”规定所有食品中均不得检出三环锡[22]。因此对水中三环锡的监测十分重要。
有机锡的检测方法有液相色谱法[3]、气相色谱法[4]、气相色谱-质谱联用法[5]GC-ICP-MS[6]HPLC-ICP-MS[7] 液相色谱-原子荧光光谱法[8]液相色谱-质谱联用法[9]。液相色谱法检测限高,难以满足痕量有机锡的检测。气相色谱法及其联用技术,样品需经四乙基硼酸钠衍生,正己烷萃取等,操作复杂且费时。液相色谱与ICP-MS联用技术,需配备外加气控制单元、有机排废管的雾化器、铂采样锥、铂截取锥及有机专用矩管。液相色谱与原子荧光光谱联用技术,需使用盐酸、硼氢化钾等强腐蚀性、高毒性的化学试剂。近年来有关甲基锡、丁基锡、苯基锡、辛基锡的测定方法已有较多报道[10-20],但有关三环锡的测定方法报道则较少,张茂强等[21]采用液相色谱-串联质谱法检测蜂王浆中三环锡残留量朱萌萌等[22]乙基溴化镁、四乙基硼酸钠为衍生试剂分别对三环锡进行衍生,自此基础上建立气相色谱-串联质谱法测定水果、蔬菜中三环锡、三唑锡和苯丁锡残留量的方法。笔者采用超高效液相色谱-串联质谱法同时检测饮用水中痕量三环锡(CYT)3种有机锡。旨在探究一种前处理简单,分析速度快,灵敏度高的检测方法,适用于水质中有机锡的日常检测。
1 实验部分
1.1 主要仪器与试剂
超高效液相色谱仪:Acquity  UHPLC型,配有四元梯度泵、样品管理器、柱温箱,沃特世科技(上海)有限公司。
串联质谱:XEVO TQ-S型 ,沃特世科技(上海)有限公司。
化学工作站:Masslynx型,沃特世科技(上海)有限公司。
电子分析天平:FA1004感量为0.1mg,上海舜宇恒平科学仪器有限公司。
移液枪: 100~1000 μL、20~200 μL 、5~50 μL,赛默飞科技(中国)有限公司。
微孔滤膜: 0.22 μm ,岛津GL(上海)商贸有限公司。
有机锡标准品:三丁基氯化锡,质量分数为99.90%;三苯基氯化锡,质量分数为97.10%,坛墨质检标准物质中心 ;三环锡,质量分数为98.00%,德国Dr.Ehrenstorfer公司。
甲醇:HPLC级 ,德国默克公司。
甲酸:分析纯,质量分数为98.0%, 阿拉丁试剂上海有限公司。
甲酸铵:分析纯,质量分数为98.0%, 国药集团化学试剂有限公司。
超纯水系统Milli-Q Element A10型, 美国默克公司
超纯水:电阻率为18.2 MΩ·cm,由Milli-Q Element A10型超纯水系统制备。
氮气发生器:GENIUS NM32LA型,英国peak公司。
脱溶剂气、锥孔气、雾化气: 氮气,体积分数不小于99.5%,由GENIUS NM32LA型氮气发生器制备。
碰撞气体:高纯氩气,体积分数为99.999%,杭州今工特种气体有限公司。
待测样品:杭州市某园区自来水。
1.2 标准溶液的制备
3种有机锡标准储备液:1000 μg/mL,准确称取56.5 mg TPT、56.0 mg TBT、51.0 mg CYT、(精确到0.1mg)有机锡标准品,分别置于3只50 mL容量瓶中,
用甲醇溶解并定容至标线,摇匀,于4℃避光保存,备用。
3种有机锡混合标准1#溶液:100 μg/mL,分别精密移取3种有机锡标准储备溶液各1.0 mL于10 mL容量瓶中,用甲醇定容至标线,摇匀,备用;
3种有机锡混合标准2#溶液:1.0 μg/mL,精密移取3种有机锡混合标准1# 溶液100 μL于10 mL容量瓶中,用甲醇定容至标线,摇匀,备用;
3种有机锡系列混合标准工作溶液:精密移取3种有机锡混合标准2# 溶液1.0 mL于10mL容量瓶中,用甲醇-水( 含0.1 %甲酸)(体积比为1:1)溶液定容至标线,配制成3种有机锡的质量浓度均为100 ng/mL混合标准工作溶液。然后用甲醇-水(含0.1 %甲酸)(体积比为1:1)溶液逐级稀释,得到3种有机锡的质量浓度均分别为50.0 ng/mL25.0 ng/mL10.0 ng/mL5.0 ng/mL2.5 ng/mL1.0 ng/mL的系列混合标准工作溶液。
1.3 样品制备
准备若干干净的500 mL棕色玻璃溶剂瓶,选择不同区域的三家公司,直接在水龙头出水口接取500 mL自来水。在室温下恒温,精密移取10 mL水样,加入10.2μL甲酸溶液,使得水样中甲酸的体积分数为0.1 %,移取1.0 mL样品,再加入1.0 mL甲醇,摇匀,经微孔滤膜过滤后,待上机。
1.4 仪器工作条件
1.4.1 液相色谱
色谱柱:Hypersil GOLD (2.1 mm×50 mm ,5μm,赛默飞科技(中国)有限公司
流动相A:甲醇-0.1 %甲酸溶液,
流动相B:0.1 %甲酸-5 mmol/L甲酸铵缓冲盐溶液;
洗脱方式:梯度洗脱(洗脱程序见表1)
流量:0.25 mL/min;进样体积:5μL。
1  梯度洗脱程序
1.4.2 质谱
离子源: 电喷雾离子源(ESI),正离子扫描模式 ;检测模式:多反应监测(MRM);毛细管电压:3500 V;离子源温度:150 ℃  脱溶剂温度:350 ℃  脱溶剂气:氮气,流量为11 L/min ;锥孔气:氮气,流量为2.5 L/min ; 碰撞气:氩气,流量为0.11 mL/min  雾化气:氮气,压力为0.7 MPa。
3种有机锡的质谱参数见表2。
2    3种有机锡质谱参数
                      注:标注*”为定量离子
2  结果与讨论
2.1 缓冲盐溶液组成的选择
以质量浓度为10.0 ng/mL的混合标准工作溶液为待测样品,考察缓冲盐溶液分别为甲酸溶液、甲酸-甲酸铵溶液、乙酸-乙酸铵溶液对分析结果的影响。以0.1%甲酸溶液为缓冲盐溶液时,峰拖尾,当甲酸的体积分数增至0.5 %时,3组分的响应无明显改变。在0.1%甲酸溶液中加入5 mmoL/L甲酸铵时,3组分峰型对称、分离更优,基线波动较小,当甲酸铵的浓度提高至10 mmoL/L时,分析效果无明显改善,基线波动增大。以0.1%乙酸-5 mmoL/L乙酸铵溶液为缓冲盐溶液时,基线波动大,保留减弱,3组分成驼峰状几乎同时流出。综合各因素,选择0.1%甲酸-5 mmoL/L甲酸铵溶液为缓冲盐溶液。
2.2 梯度洗脱程序的选择
10.0 ng/mL的混合标准溶液为待测样品,在2.1条件下,分别考察缓冲盐溶液体积分数为20 %、40 %、60 %以及洗脱程序为突变式、一阶、二阶渐变式对分析结果的影响。结果表明,当缓冲盐溶液比例为60 %时,各组分保留增强,响应减小,三环锡保留时间为7min左右;当缓冲盐溶液比例为40 %时,响应增加,三环锡保留时间为4min左右,各组分达到基线分离;当缓冲盐溶液比例为20 %时,保留减弱,3组分的保留时间小于3min,各组分未能完全分开,因此选择缓冲盐溶液的初始体积分数为40 %。
在缓冲盐溶液初始体积分数考察结果的基础上,进一步考察洗脱程序对分析结果的影响。在0.10 min内,缓冲盐体积分数由40 %降到5 %的突变式洗脱程序,基线波动的干扰大。4.00 min内体积分数由40 %逐渐降到5 %的一阶渐变式洗脱程序中,体积分数40 %降到15 %时,基线波动小,体积分数15 %降到5 %时,基线波动大,干扰增加,因此缓冲盐溶液的终止体积分数为15 %。在一阶渐变式洗脱程序的基础上,分别考察1.00 min、2.00 min、3.00 min内缓冲盐体积分数由40 %降到30 %、20 %对各峰分离度的影响,试验表明,2.00 min,体积分数降到20 %时,各峰的分离度均大于1.5。综合各因素,洗脱程序选择缓冲盐初始体积分数为40 %,2.00 min降到20 %,3.00 min降到15 %。
2.3流量的选择
2.1、2.2测定条件下,以10.0 ng/mL的混合标准溶液为待测样品,分别考察流量为0.30 mL/min、0.25 ml/min、0.20 mL/min对分析效果的影响,流量为0.30 ml/min时,柱压升高,基线波动大,干扰增加,流速为0.25 ml/min时,基线的干扰较小,流速为0.20 ml/min时,三环锡在基线干扰最大的位置出峰,影响组分的定量。因此选择流量为0.25 ml/min。
2.4 质谱条件的选择
  以标准储备液为待测样品,考察锥孔电压、碰撞电压对3种有机锡响应值的影响,实验表明,采用1.5.2中的质谱参数,化合物能够获得更高的响应值。
自来水样品及3种有机锡加标自来水样的色图谱 见图1、2。
1 自来水样品图谱
2  自来水加标图谱(加标量10.0 ng/mL
2.5 线性方程和检出限
1.4仪器工作条件下,分别对1.2中的3种有机锡系列混合标准工作溶液进行测定,以各有机锡的质量浓度xng/mL)为横坐标,以定量离子的丰度y(counts)为纵坐标,进行线性回归,计算线性方程和相关系数。以3倍信噪比(S/N)对应的有机锡的质量浓度作为方法检出限。3种有机锡的线性范围、线性方程、相关系数及检出限见表3
2.6 精密度与加标回收试验
选取自来水样品,加入质量浓度分别为2.0 ng/mL3种有机锡混合标准工作溶液,10.0 ng/mL50.0 ng/mL 3种有机锡混合标准2#溶液,在1.4仪器工作条件下进行测定,并计算加标回收率和测定结果的相对标准偏差,结果见表4。由表4可知,样品在低、中、高3个加标浓度时的平均回收率为87.5 %~113.5 %之间,测定结果的相对标准偏差为0.00 %~4.78 %(n=6),说明该方法具有较高的准确度和精密度。
4    3种有机锡的加标回收结果
3 结束语
建立了超高效液相色谱-串联质谱法同时测定饮用水中三环锡等3种有机锡的检测方法,该方法不需要经过繁琐的衍生、萃取处理,简化了前处理步骤,灵敏度高,可用于饮用水中多种有机锡化合物的同时测定。
[1] 高俊敏,胡建英,金晓辉,等.水环境中的有机锡污染调查 [J].中国给排水,2004,23(07):76-78.
[2] 余昌申.中国农业百科全书 农药卷[M].北京:农业出版社,1993,325.
[3]王秀嫔,金海燕,陈立钢,等.在线固相萃取富集高效液相色谱法测定水中有机锡化合物 [J].分析化学.2007,32(11):68-74.
[4] 吴珉.气相色谱-电子捕获检测器法测定柑桔和土壤中苯丁锡的残留 [J].农药学学报.2011,34(06):321-326.
[5] 董茂忠,陈冬梅,张金娥,等.气相色谱-质谱法测定塑料制品中有机锡含量的研究[J].山东化工,2017,46(13):79-81.
[6] Peeters K,Iskra J,Zuliani T,et al. The micrb-scale synthesis of Sn-177-enriched tributyltin chloride and its characterization by GC-ICP-MS and NMR techniques[J].Chemosphere.2014,107(19):386-392.
[7] 马安萍. HPLC-ICP-MS法测定生物材料中有机锡化合物[D].广州:广东药科大学:2019.
[8] 邓爱华,庞晋山,彭晓俊,等.高效液相色谱-氰化物发生原子荧光法同时测定塑料制品中的有机锡 [J].分析测试学报.2014,45(08):928-933.
[9] 徐琴,牛增元,也叶曦雯,等.液相色谱-质谱法对电子电气产品塑料部件中有机锡的测定[J].分析测试学报.2009,12(11):34-38.
[10] 邵秋荣,孟昭建,王秀嫔,.微波辅助提取样品-正相液相色谱法测定面粉中有机锡化合物. [J].理化检验(化学分册).2013,49(01):78-80 83.
[11] 邓爱华,庞晋山,彭晓俊,等. 气相色谱/双    柱双检测器测定塑料制品中10种有机锡[J].分析 测试学报,2015,34(01):34-42.
[12] GB 5009.215-2016 食品安全国家标准 食品中有机锡的测定.北京:中国标准出版社,2016.
[13] 蔡琪,陈春瞾,黄清辉,等. 基于被动采样技术的水体中有机锡污染筛查取证研究[J].生态毒理学报,2019,14(02):116-124.
[14] 左莹,施均,刘峻,等.气相色谱-质谱法测定乳胶产品中9种有机锡的含量[J].理化检验(化学分册),2018,54(4):88-94.
[15] 高俊敏,任春蓉,张科,等. 三峡库区次级河流春季水环境中有机锡在水/SPM间的分配特征[J].环境科学学报,2017,37(04):111-117.
[16] EN7132019中文版 玩具安全 第 3 部分:特定元素的迁移 欧洲:欧洲标准委员会,2019.
[17] HJ 1074-2019 水质 三丁基锡等4种有机锡化合物的测定 液相色谱-电感耦合等离子体质谱法. 北京:中国标准出版社,2019.
[18] 李勇,林燕奎,李莉,等.液相色谱-原子荧光光谱联用检测海产品中不同形态锡的研究[J].食品安全质量检测学报.2014,23(11):3467-3475.
[19] 于文佳,卫碧文,张雅婷,等.DLLME-ESI-MS/MS快速筛查轻纺消费品中有机锡[J].印染,2017,43(20):47-51.
[20] 陈金保, 刘英霞, 李绪涛, 等. 高效液相色谱-串联质谱法同时测定使用植物油中多种有机锡化合物[J]. 盐矿测试, 2017, 36(2): 180-186.
[21] 张茂强,刘涛,等.液相色谱-串联质谱法检测蜂王浆中三环锡残留量[J].科技资讯(工业技术),2013,21:68-69.
[22] 朱萌萌,黄亮,周敏,等.气相色谱-串联质谱法测定水果、蔬菜中三唑锡、三环锡和苯丁锡的残留量法[J].食品与发酵工业,2018,44(1):262-268.
该帖子作者被版主 hujiangtao10积分, 2经验,加分理由:鼓励原创
huomiao
m3336169
对于这种有必要进行基线分离吗?另外,不知道这种洗脱程序能否把色谱柱中的脏东西都冲出来,而不影响下一针样品?
hejiahuan
原文由 huomiao(huomiao) 发表:
楼主的基线怎么这么漂啊?
同样的程序,走利血平基线正常。后续还需要进一步查找原因。
hejiahuan
原文由 m3336169(m3336169) 发表:
老师说的没错,对于质谱物质可以不用达到分离或者基线分离,如果能达到基线分离,说明方法可以有进一步优化的空间,色谱图也更好看一些。
从测量重复性来看,对下一针的分析是有没有影响的。
歪果仁zZ
hejiahuan
