主题:【悬赏帖】IS 15298 : Part 2 : 2016
浏览 回复1 电梯直达
大M
悬赏金额:50积分 状态: 未解决
Personal Protective Equipment Part 2 Safety Footwear
IS 15298 : Part 2 : 2016 / ISO 20345 : 2011 Personal Protective Equipment Part 2 Safety Footwear
ICS 13.340.50                          CHD 19
Reaffirmed 2022
NATIONAL FOREWORD
This Indian Standard (Part 2) (Second Revision) which is identical with ISO 20345 : 2011 ‘Personal protective equipment — Safety footwear’ issued by the International Organization for Standardization (ISO) was adopted by the Bureau of Indian Standards on the recommendation of the Footwear Sectional Committee and approval of the Chemical Division Council.
This standard was originally published in 2002 which was identical to ISO 8782-2 : 1998 ‘Safety, protective and occupational footwear for professional use — Part 2: Specification for safety footwear’. In 2004, IS 15298 (Part 6) was published as identical to ISO 8782-6 : 2000 ‘Safety, protective and occupational footwear for professional use — Part 6: Additional specifications for safety footwear’.
In 2004, ISO amalgamated ISO 8782-2 : 1998 and ISO 8782-6 : 2000 and published it as ISO 20345 : 2004 ‘Personal protective equipment — Safety footwear’. Thus, IS 15298 (Part 2) was revised in 2011 as identical to ISO 20345 : 2004.
The text of ISO Standard has been approved as suitable for publication as an Indian Standard without deviations. Certain conventions and terminologies are however not identical to those used in Indian Standards. Attention is particularly drawn to the following:
a) Wherever the words ‘International Standard’ appear referring to this standard, they should be read as
‘Indian Standard’.
b) Comma (,) has been used as a decimal marker while in Indian Standards, the current practice is to use a point (.) as the decimal marker.
h04206010006
iso 20345-2021
https://www.instrument.com.cn/download/shtml/1085790.shtml
登录后查看全部精彩内容
您需要登录后才可以回帖登录|立即注册
