主题:【分享】AJC-5S24S AC-DC ITE电源模块ARCH
浏览0 回复0 电梯直达
Ins_53b266b9
ARCH公司是一家来自台湾的电源模块生产商,其产品广泛应用于各种领域。AJC系列是ARCH公司为ITE(工业、科技、医疗)应用设计的一组AC-DC电源模块。
[img=AJC-5S24S AC-DC ITE电源模块ARCH]https://www.leadwaytk.com/public/ueditor/upload/image/20240509/1715216419154627.png[/img]
  AJC系列包括多个型号,例如AJC-3.3S,AJC-5S,AJC-9S,AJC-12S,AJC-15S,AJC-24S,AJC-5D,AJC-12D,AJC-15D,AJC-5S12S,AJC-5S24S,AJC-5S12D和AJC-5S15D。这些电源模块的主要特性包括:
  - 开关电源模块,适用于PCB安装
  - 完全封装的塑料外壳
  - 通用输入范围为90-264VAC,47-440Hz
  - 提供稳压输出
  - 低纹波和低噪音
  - II级隔离
  - 能够在-40°C的温度下启动
  - 尺寸小巧,ASC 30W和40W型号具有更高的瓦数
  - 通过了CE、CB和UL认证
  - 享有3年的产品保修期
ELECTRICAL SPECIFICATIONS
Model No    (Single  Output)AJC-3.3SAJC-5SAJC-9SAJC-12SAJC-15SAJC-24S
Max output wattage (W)26.4W40W40W40W40W40W
OutputVoltage (V.DC3.3V5V9V12V15V24V
Current (mA)max800080004444333326661667
Voltage set accurac±3%±2%±2%±2%±2%±2%
Line regulation (typ.)0.5%0.5%0.5%0.5%0.5%0.5%
Load regulation (1-100%)(typ.1%1%1%1%1%1%
Minimum load1%1%1%1%1%1%
Maximum Capacitive Load (at 230VAC)60000 uF40000 uF7200 uF8600 uF6600 uF1400 uF
Eficiency(typ74%81%82%84%83%83%
Model No    (Dual  Output)AJC-5DAJC-12DAJC-15D
Max output wattage (W)40W40W40W
OutputOutput 1Output 2Output 1Output 2Output 1Output 2
Voltage V.DC.+5V-5V+12V-12V+15V-15V
Current (mA)max400040001666166613331333
Voltage set accuracy±2%±2%±2%
Load regulation (10-100%)(typ.)1%(symmetric  load)1%(symmetric  load)1%(symmetric load
Cross regulation (15-100%)(typ.±5%±5%±5%
Minimum load10%10%10%
Maximum Capacitive Load (at 230VAC)±12000 uF±4400 uF±1000 uF
Efficlency (typ81%83%83%
Model No.    (Dual Output)AJC-5S12SAJC-5S24S
OutputOutput 1Output 2QutputOutput 2
Voltage (V.DC.)5V12V5V24V
Current (mA)max500012505000625
Voltage set accuracy±3%±5%±3%±5%
Line regulation (typ.0.5%5%0.5%5%
Load regulation (25-100%)(typ.)2%(symmetric
load)
6%(symmetric
oad)
2%(symmetric
load)
6%(symmetric
load)
Cross regulation(25-100%)(typ.)±1%±7%±1%±7%
Minimum load25%25%
Maximum Capacitive Load (at 230VAC10000 uF470 uF10000 uF400 uF
EMiciency(typ.82%82%
Model No.  (Triple  Output)AJC-5S12DAJC-5S15D
OutputOutput 2Output 3Output 1Output 2Output 3
Voltage (V.DC.)+12-125+15-15
Current (mA)ma6006005000500500
Voltage set accurac±5%±3%±5%
Line regulation (typ.5%0.5%5%
(symmetric load
7%3%7%
Cross regulation (typ.±10%±3%±10%
Minimum load25%25%
Maximum Capacitive Load780 uF10000 uF900 uF
Efficiency(typ80%81%
深圳市立维创展科技授权代理ARCH电源模块产品,提供高效率,高品质与小尺寸特性的产品满足市场趋势和需求,并提供技术支持服务,欢迎咨询。
您可能想找: 其它 询底价
