主题:【第十八届原创】高分辨四极杆飞行时间质谱常见故障排查与维护保养
p3262017
化工学院大型仪器测试平台
该帖子已被大耳朵兔兔设置为精华; 奖励活力值记录: 大耳朵兔兔(10分)
年度三等奖
刘娜 彭婷 张凌雪 刘士新 何清*
(天津大学,化工学院,天津300315)
摘要:液相色谱高分辨四极杆串联飞行时间质谱(简称 QTOF-MS),是具备高分辨率、高质量精度特性的高端质谱分析设备,可实现化合物定性分析、小分子结构分析,也是表征生物分子翻译后修饰的关键工具,广泛应用于蛋白质组学、代谢组学、临床生物标志物筛查及小分子药物研发等领域。本文结合实际工作经验,主要针对布鲁克公司MicrOTOF-Q II型质谱仪在实验教学中遇到的问题以及常见故障维修经验作了简单介绍,可为其他仪器管理者提供参考。仪器的有效维护对于测试结果的准确性及维持良好的仪器运行状态至关重要。
关键词:质谱、仪器参数、离子源、机械泵、维护、重复性
High-Resolution Quadrupole Time-of-Flight Tandem Mass Spectrometer: Common Troubleshooting and Maintenance
Abstract: Liquid Chromatography High-Resolution Quadrupole Time-of-Flight Tandem Mass Spectrometer (LC-HR-Q-TOF/MS), commonly abbreviated as QTOF-MS, is a high-end analytical instrument renowned for its high resolution and exceptional mass accuracy. It enables qualitative analysis of compounds, structural elucidation of small molecules, and is a critical tool for characterizing post-translational modifications of biomolecules. Widely applied in proteomics, metabolomics, clinical biomarker screening, and small-molecule drug development, this technology plays a pivotal role in modern research.Drawing from practical experience, this article briefly addresses common operational challenges and troubleshooting strategies encountered with Bruker's MicrOTOF-Q II mass spectrometer in experimental training settings, offering insights that may assist other instrument operators. Effective maintenance of the instrument is essential to ensure the accuracy of test results and sustain optimal operational performance.
Keywords: Mass Spectrometry, Instrument Parameters, Ion Source, Mechanical Pump, Maintenance, Repeatability
1、仪器使用中质谱突然无信号,检查仪器各项参数均无异常
1.1 检查离子源与管路连接正常。
1.2 清洗离子源、离子漏斗,玻璃毛细管。安装并抽真空后,仪器报错RFG2 error (如图1),重新reset质谱后,报错依旧未消失,且发现funnel2的RF电压也加不上(如图2)。
1.3 更换新的RFG2 generator 配件,依然报错。检查离子源,发现漏斗的一根连接线断开(如图3)。接上该连接线,重新抽真空。待真空达标后,开启仪器,RFG2报错消失,参数均正常。但质谱仍无信号,再次尝试调谐仪器参数后,信号突然恢复,甲酸钠校正液信号强度e5,测试半小时后,信号再次消失。
1.4 更换新备用毛细管,信号短暂恢复后消失。
1.5 由于离子漏斗长期使用,有过明显断点,怀疑漏斗可能有问题。更换离子漏斗,质谱依然没有信号。
1.6 再次检查所有参数,参数均无异常。怀疑离子源位置可能有问题,借用高压棒测试发现,endplate电压正常,capillary电压无法达到设定值4000V,测得在1000-2000V来回波动。确定该电源损坏,更坏离子源高压电源后(如图4),各项参数正常,质谱信号恢复正常。
图1:funnel 2报错
图2: RF2电压异常
图3:漏斗连接线断开图
图4:高压电源模块
2、质谱仪无法启动或突然崩溃
2.1 供电与连接检查
确认质谱主电源开关处于“ON”,UPS处于工作状态,电源线插头无松动
2.2 软件与系统初始化检查
1)重启控制电脑与仪器
2)查看软件报错日志:在控制软件“Help/日志”中查看故障代码
3)检查电脑系统资源:确保有足够的剩余空间关闭杀毒软件(可能拦截仪器驱动)
2.3 真空系统检查
1)检查机械泵(油位,油颜色、机械泵运行声音)
2)观察真空规读数(打开仪器真空监控界面)
3)检查分子泵是否启动
3、在重复测试同一样品时,信号强度不一致,导致数据的精确性和重复性极差
3.1 样品稳定性
确认样品是否易降解、吸附或挥发
3.2 进样系统一致性检查
1)检查进样针是否堵塞(用异丙醇冲洗,观察流速是否稳定)。
2)针座是否漏液(观察进样后针座有无残留液滴),若有问题则需更换进样针或密封圈。
3.3 监控离子源参数(信号产生的核心)
1)清洁离子源部件。
2)确认喷雾电压、毛细管温度、鞘气/辅助气流速是否稳定,可在软件中查看实时参数,若有波动需重新设定并锁定。
3.4 真空与质量分析器检查
1)确认真空度达标,真空不足会导致离子传输效率下降,信号波动。
2)检查检测器增益:若检测器增益过高或不稳定,会导致信号噪声大、重复性差,可在软件“检测器参数”中查看增益值。
4、日常维护项目
[img]" style="max-width: 100%;max-height: 100%;[/img]定期、系统的维护操作,可以保障Q-TOF质谱仪的长期稳定运行,确保检测数据的准性、重复性和可靠性,延长仪器使用寿命。
4.1机械泵维护
机械泵的运行直接影响仪器低真空稳定性,维护核心是保持油液清洁、确保密封良好、减少机械磨损。
1)日常维护(油位与油色检查、运行状态检查、排气口检查)
2)定期维护(更换泵油)
步骤 1:断电后等待30分钟,让泵内热油冷却至室温
步骤 2:找到泵体底部的放油阀,下方放一个废烧杯,打开阀门将废油彻底放净(约10-15分钟,确保无残留)。
步骤 3:关闭放油阀,向注油口加入仪器原厂推荐的专用真空泵油(禁止混用不同品牌或型号的油)。
步骤 4:加入泵油:油的水平线应在窗口的1/2-2/3处,拧紧注油口盖。(如图5)
图5:机械泵
4.2清洗更换玻璃毛细管
1)仪器卸掉真空后,打开离子源,使用六角螺丝刀拧开毛细管喷雾罩上的小螺丝,并取下喷雾罩(sprayshield)和毛细管帽(capillary cap)。
2)向外顺着用力,拔出毛细管,毛细管没有正反方向。(向外拔出时切勿晃动毛细管,以免折断)
3)在干净的烧杯中加入纯水,将玻璃毛细管通过枪头与针管连接好后,另一端深入水中,用力拉针管,使烧杯中的液体快速通过毛细管吸入针管中,达到初步清洗的目的;将纯水换成色谱级异丙醇后,进行同样的操作步骤,每种试剂清洗5-6次,以达到进一步清洗的目的。(清洗过程中,针管只吸入试剂,不能再推回玻璃毛细管中)
4)继续清洗毛细管帽(capilary cap)和喷雾罩(spray shield),可直接放入烧杯中超声,分别用水,异丙醇超声1-2次)。
图6:毛细管更换、清洗
结束语:
高分辨四极杆串联飞行时间质谱仪是大型精密复杂测试仪器,其运行管理要求相关人员需具备高度责任心、专业培训背景以及仪器故障及时排查能力。本文主要总结了高分辨质谱仪在使用过程中出现的若干软硬件故障与日常维护问题,以期为同行提供仪器维护方面的参考。
参考文献:
[1] 许晓辉, 李坚, 王小乔,等.液相色谱串联三重四极杆质谱的使用,常见故障处理与维护保养[J].分析测试技术与仪器, 2024,30(2):130-137.
[2] 布鲁克(Bruker)Q-TOF高级应用培训手册
维权声明:本文为p3262017原创作品,本作者与仪器信息网是该作品合法使用者,该作品暂不对外授权转载。其他任何网站、组织、单位或个人等将该作品在本站以外的任何媒体任何形式出现均属侵权违法行为,我们将追究法律责任。
液质联用(LC-MS)
其它质谱仪
三合一超高分辨轨道阱质谱仪
三合一超高分辨轨道阱质谱仪
东诚福华
ljl2045
介绍的很详细,图文并茂,高分辨质谱常见故障与维护总结到位,很有参考价值。
很实用的经验,这里面还有一个毛细管玻璃柱,第一次见
symmacros
symmacros
上面问型号未误发,请忽略。非常好的故障排除和维护保养经验,学习了,感谢分享。
ljl2045
高分辨质谱的日常维护总结的很仔细,有图有文,拿来就能用,很好。
