主题:【第十八届原创】球差电镜在Ti-24Zr-10Nb-2Sn合金变形研究中的应用
p3238978
化工学院大型仪器测试平台
梁国弘  何雨桐  黄禹琼  顾琳  翟勇  习 卫 靳凤民*
(天津大学 化工学院,天津 300350)
摘要:生物医用亚稳β钛合金因其良好的力学性能、抗腐蚀性能和多种多样的变形行为受到了广大科研工作者的青睐。本研究将以Ti-24Zr-10Nb-2Sn (at.%)合金为模板,利用球差电镜和高分辨透射电子显微镜基对该合金变形前、后的显微组织结构、物相组成等方面进行表征分析。在本研究中,可以清晰观察到合金的显微形貌,并且获得目标区域的原子像。与此同时,还可以利用STEM-EDS模式对合金的的化学元素分布进行全面表征。该工作的完成为科研人员利用透射电子显微镜深入研究金属材料的显微结构奠定了良好的基础。
关键词 球差电镜;高分辨透射电子显微镜;亚稳β钛合金
中图分类号:TB37; TH742 文献标识码:B
TEM characterization of Ti-24Zr-10Nb-2Sn alloy
LIANG Guohong,   HE Yutong,  HUANG Yuqiong,  GU Lin,  ZHAI Yong,  XI Wei,  JIN Fengmin*
( School of Chemical Engineering and Technology, Tianjin University, Tianjin 300350, China)
Abstract:Biomedical metastable β-titanium alloys have garnered significant attention from researchers due to their excellent mechanical properties, corrosion resistance, and diverse deformation behaviors. In this study, the Ti-24Zr-10Nb-2Sn (at.%) alloy was used as a model, and its microstructure and phase composition before and after deformation were characterized using a spherical aberration corrected transmission electron microscope and high-resolution transmission electron microscope equipped. The study allowed clear observation of the alloy’s microstructural morphology and atomic-resolution imaging of target regions. Additionally, the chemical element distribution of the alloy was comprehensively characterized using the STEM-EDS mode. The completion of this work lays a good foundation for further in-depth investigation of the microstructure of metallic materials using transmission electron microscope.
Keywords:Transmission Electron Microscope, Titanium alloy
透射电子显微镜(Transmission Electron Microscope, TEM)是现代材料科学、纳米技术及生命科学领域不可或缺的高分辨率分析工具。其工作原理是在真空环境中,利用高压(通常为60-300 kV)加速电子束,穿透超薄样品(通常<100 nm)。由于样品各区域的厚度和原子序数差异,电子束会发生不同程度的散射与衍射,这些信号经电磁透镜系统聚焦后,最终在荧光屏或探测器上形成高对比度图像、衍射图谱及元素信息,从而揭示样品的微观结构、晶体特征与化学组成。天津大学化工学院球差电镜中心目前拥有1台物镜球差校正透射电镜(Spherical Aberration Corrected Transmission Electron Microscope,AC-TEM),1台聚光镜球差校正透射电镜(Spherical Aberration Corrected Transmission Electron Microscope,AC-STEM),1台高分辨场发射透射电镜(HR-TEM),一套加热原位系统,一套单倾冷冻传输系统,一套气体加热原位系统,一套液体热电原位系统。球差电镜校正后的空间分辨率为0.6?,能在不同尺度对材料的形态、结晶状态以及微观结构进行研究,广泛应用于化学、材料科学、生命科学以及地质学等许多科学领域[1-3]。
钛合金具有优异的力学性能(如高强度、低密度)、抗腐蚀性能,与此同时合金中不同的相组成会使材料展现出多种多样的变形行为,如常规稳态力学性能,超弹性能,形状记忆效应等,其中超弹钛合金在生物医疗领域中有着重要的应用前景[4-7]。通常采用具有良好生物相容性的元素(锆、铌、钽、锡等)制备具有优异超弹性能的钛合金,从而将其应用于生物医疗领域(如正畸丝,血管支架、手术用导丝、外科缝合线等)[8-15]。目前,Ti-Nb基合金仍是研究最为广泛的材料[8,11,13],但其超弹性能难以满足临床医学的应用需求。据报道,Ti-Zr基合金是新兴的一类超弹材料[9-10,12,14-15],所以,本文将以Ti-24Zr-10Nb-2Sn合金为研究对象,利用球差透射电子显微镜对该合金变形前、后的微观组织结构进行表征分析,指导材料性能。
1 实验材料、设备与方法
实验材料
在本研究中使用的四种溶液分别为:硝酸(50%,阿拉丁有限公司,上海),氢氟酸(50%,阿拉丁有限公司,上海),高氯酸(5%,阿拉丁有限公司,上海),甲醇(95%,阿拉丁有限公司,上海)。合金熔炼所用钛、锆、铌、锡原材料均为从中诺公司购买的高纯金属,纯度分别为99.995%,99.95%,99.99%,99.99%。
实验设备
聚光镜球差电镜(JEM-ARM300F2,JEOL,日本),物镜球差电镜(JEM-ARM300F2 WGP,JEOL,日本), 高分辨透射电子显微镜(JEM-F200,JEOL,日本),电解双喷仪(TenuPol-5,丹麦),离子减薄仪(PIPS II 695, Gatan,美国)。
实验方法
通过高真空非自秏电弧熔炼炉制备Ti-24Zr-10Nb-2Sn纽扣铸锭,在熔炼过程中有高纯氩气作为保护气,反复将样品熔炼6遍。将得到的纽扣铸锭密封于装有氩气的石英管中,随之置于管式炉中在950℃条件下均一化处理24小时,然后淬火。将淬火处理后的铸锭置于氢氟酸和硝酸的混合液中(1:1体积比),直至表面呈现银白色金属光泽,随后通过冷轧机对其进行冷轧处理,直至下压率为91%。通过电火花切割仪将冷轧板材加工成标准拉伸式样,然后再次将合金进行750℃ 30分钟固溶处理,随后水淬,并采用相同方法出去表层氧化物。最后,通过拉伸试验机将合计进行塑性变形至5%。
利用样品冲片机冲出直径为3 mm的圆片,并机械抛光至厚度为100 μm。由于此合金亚稳材料,所以很容易造成透射样品制备过程中马氏体相进行逆转变,而且块体材料不能直接进行透射电镜表征,材料必须被较薄成厚度小于100 nm的3 mm的圆片。所以本实验采用电解双喷和离子减薄相结合的方法来制备透射样。首先通过电解双喷仪在-20℃条件下对样品进行预减薄(5%高氯酸和95%甲醇混合液),直至残余厚度为10-20 μm,然后利用离子减薄仪对样品进行最终减薄,直至出孔。
使用TEM和AC-TEM对上述较薄后的材料进行观察筛样和表征,首先进行样品高度调整、电子束中心居中、聚光镜光阑对正、电子枪对中、电压中心调节、聚光镜消像散、物镜消像散等电子枪和电子束校正合轴操作以及球差校正。然后对STEM观察方法进行调整和优化,对合金进行原子像表征和分析。
2 结果与讨论
图1为Ti-24Zr-10Nb-2Sn合金经750℃ 30分钟固溶处理后的聚光镜球差校正电镜结果。图1(a)是在三叉晶界处的STEM结果,从图中可以看出,无论在晶粒内部还是在晶界处,均无明显沉积相的形成。为进一步加以证明,我们对合金进行了能谱分析(STEM-EDS),如图1b-e所示。该结果清晰表明无论在晶粒内部还是在晶界处,均无元素偏析现象,这表明Ti、Zr、Nb、Sn各元素在合金中是均匀分布的,并成功制备出了目标合金。
图1 合金变形前形貌(a)及STEM-EDS(b-e)结果
在此基础上我们对合金进行了5%塑性变形,如图2所示。首先,我们通过TEM进行了初步分析,从图中可以看出,与图1a显微形貌相比,合金基体中出现了明显条状变形带,这是因为塑性变形导致的。为进一步确定该变形带的物相组成,我们对该区域进行了衍射斑点分析,如图2b所示。经对衍射斑点分析可知,板条为马氏体相,并且[131]β‖[131]α"带轴相平行。此结果表明,Ti-24Zr-10Nb-2Sn合金经5%拉伸变形后已发生塑变,并且塑变产物为马氏体相。
图2 合金经5%变形后显微形貌(a)及衍射斑点(b)
与此同时,我们利用AC-STEM对该变形后的合金进行原子尺度结构分析,如图3。从STEM图片(图3a)中可以基体被变形带割裂成几部分,所以我们在基体处对合金进行了原子像分析,如图3b。从图中可以看出,原子呈标准六边形状,并且原子排列方向分别沿[01-1]和[10-1],所以,从此图可以判定出基体确实为beta相。
图3 合金STEM形貌图(a)及衍射斑点母相原子像(b)
最后,我们继续利用聚光镜球差校正电镜对变形带附近是否会产生成分偏析进行了研究和分析。图4为相应区域的STEM和STEM-EDS结果。从能谱图中可以清晰看出,变形带附近无明显元素偏析行为,这表明在该合金中应力诱导产生的马氏体相成分是均匀分布的。
图4 合金在变形带附近处的STEM形貌图(a)及STEM-EDS(b-e)结果
3 结论
本研究利用高分辨透射电子显微镜和聚光镜球差校正电镜对Ti-24Zr-10Nb-2Sn合金变形前、后的显微形貌进行了深入分析。通过球差电镜不仅可以清晰获得合金的显微形貌,而且能够获得相应区域的原子像,并进行能谱分析。该工作为科研人员利用电子显微镜深入探究金属材料变形机制奠定了坚实的基础。
参考文献:
Williams, D. B., & Carter, C. B. Transmission Electron Microscopy: A Textbook for Materials Science. Springer Science & Business Media, 2009.
Pennycook, S. J., & Nellist, P. D. (Eds.). Scanning Transmission Electron Microscopy: Imaging and Analysis. Springer Science & Business Media, 2011.
欧阳,李松达,袁文涛,等.原位透射电镜在金属纳米颗粒氧化研究中的应用[J].电子显微学报, 2021, 40(5): 623-634.
BALAZIC M, KOPAC J, JACKSON M J, et al. Review: titanium and titanium alloy applications in medicine[J]. IJNBM, 2007, (1) 3.
肖文龙,付雨,王俊帅,等.生物医用亚稳 β 钛合金的研究进展[J]. 材料工程 2023, 51 (2): 52-66.
MIYAZAKI S, KIM H Y, HOSODA H, et al. Development and characterization of Ni-free Ti-base shape memory and superelastic alloys[J]. Materials Science and Engineering: A, 2006, 438: 18-24.
齐欢,武祥为,张涵雅,等.Ti-34Nb-4Zr-0.3O合金时效组织调控及其力学性能[J]. 材料工程,2024,52(4):102-109.
YANG Y, CASTANY P, HAO Y L, et al. Plastic deformation via hierarchical nano-sized martensitic twinning in the metastable β Ti-24Nb-4Zr-8Sn alloy[J]. Acta Materialia, 2020, 194: 27-39.
KONG L, WANG B, MENG X, et al. Texture evolution, microstructure, and superelastic properties of different cold-rolled Ti-Zr-Nb-Sn strain glass alloys[J]. Materials Characterization, 2022, 193: 112309.
IJAZ M F, KIM H Y, HOSODA H, et al. Superelastic properties of biomedical (Ti-Zr)-Mo-Sn alloys[J]. Materials Science and Engineering: C, 2015, 48: 11-20.
H.Y. Kim, J. Fu, H. Tobe, J.I. Kim, S. Miyazaki, Crystal Structure, Transformation Strain, and Superelastic Property of Ti-Nb-Zr and Ti-Nb-Ta Alloys, Shap. Mem. Superelast. 1 (2015) 107-116.
W. Tasaki, K. Nakano, Y. Sato, T. Koyano, S. Miyazaki, H.Y. Kim, Effects of Zr and Hf on superelasticity, shape memory effect and microstructure of β-type (Ti-Zr-Hf)-Nb-Sn multi-principal element alloys with low magnetic susceptibility, Mater. Sci. Eng: A 908 (2024) 146760.
M. Besse, P. Castany, T. Gloriant, Mechanisms of deformation in gum metal TNTZ-O and TNTZ titanium alloys: A comparative study on the oxygen influence, Acta Mater. 59 (2011) 5982-5988.
L. López Pavón, H.Y. Kim, H. Hosoda, S. Miyazaki, Effect of Nb content and heat treatment temperature on superelastic properties of Ti-24Zr-(8-12)Nb-2Sn alloys, Scr. Mater. 95 (2015) 46-49.
J. Fu, A. Yamamoto, H.Y. Kim, H. Hosoda, S. Miyazaki, Novel Ti-base superelastic alloys with large recovery strain and excellent biocompatibility, Acta Biomater. 17 (2015) 56-67.
S. Li, M.-S. Choi, T.-H. Nam, Phase stability of the amorphous phase and non-equilibrium phase in a β Ti-Zr-based shape memory alloy, Scr. Mater. 195 (2021) 113721.
维权声明:本文为p3238978原创作品,本作者与仪器信息网是该作品合法使用者,该作品暂不对外授权转载。其他任何网站、组织、单位或个人等将该作品在本站以外的任何媒体任何形式出现均属侵权违法行为,我们将追究法律责任。
光学仪器组件
用于光学力学的压电镜移位器STr
PSt150 系列、PSt150 VS、HPSt150、FPSt150、STr 系列、配件
量青光电
金相显微镜
明暗场微分干涉相衬金相显微镜
XJL-20BDDIC
广州粤显光学仪器有限责任公司
