原文由 hail_zhang 发表:
用交叉极化定量?不能这么干滴
原文由 aytdy 发表:
我用化学法测过碳含量在55%左右,文献测定数据如下,请帮忙估计一下测定所需时间,我好向老师汇报费用问题。不胜感谢!!!
Cross-Polarization Magic Angle Spinning Carbon-13 Nuclear Magnetic Resonance experiments were performed on a Bruker AMX400 operating at 100.625 MHz on carbon-13. The rotor spin rate was set at 4500 Hz. A recycle time of 1 s and an acquisition time of 13 ms were used.
All the experiments were conducted with the variable contact time (VCT) pulse sequence in order to find the optimal contact time (OCT) for each sample and to minimize the error on the evaluation of the peak areas (Conte et al., 1997). OCT of 1 ms was measured for HA~, FA 1 and FA 2, and of 0.8 ms for HA~. A line broadening of 50 Hz was used to transform all the FIDs.
Structural carbons determined were aliphatic carbon (0-50 ppm), alcohols, amines, carbohydrates, ethers,methoxyl and acetal carbon (50-112 ppm),aromatic carbon (112-145 ppm), phenolic carbon (145-163ppm), and carboxyl and carbonyl carbon (163-215 ppm).
土壤中有机质的表征,很多时候都用CP/MAS做定量。
好象约定俗成,呵呵。
顺便问个问题,象DEPT这样的去偶技术能用在固体C13NMR上吗?
