- 类型
- 主题
- 发帖
- 回复/点击
- 最后回复
- RE:RE:RE: 蒸发光压力不稳
- byron1111
21-03-07 18:00 - 0/0
- byron1111
21-03-07 18:00
- RE:RE: ELSD的液相条件优化
- byron1111
21-03-07 17:59 - 0/0
- byron1111
21-03-07 17:59
- RE:RE: 蒸发光散射检测器
- byron1111
21-03-07 17:58 - 0/0
- byron1111
21-03-07 17:58
- RE:RE: 液相脱气机故障
- byron1111
21-03-07 17:57 - 0/0
- byron1111
21-03-07 17:57
- RE:RE: 高效液相色谱脱气机关机后依旧显示压力并报警怎么解决
- byron1111
21-03-07 17:56 - 0/0
- byron1111
21-03-07 17:56
- RE:RE: 环氧乙烷
- byron1111
21-03-07 17:55 - 0/0
- byron1111
21-03-07 17:55
- RE:RE:RE: 环氧乙烷
- byron1111
21-03-07 17:53 - 0/0
- byron1111
21-03-07 17:53
- RE:RE: 环氧乙烷
- byron1111
21-03-07 17:52 - 0/0
- byron1111
21-03-07 17:52
- RE:RE: 花1元解决安捷伦G4513A进样器故障(故障代码245)
- byron1111
21-03-07 17:50 - 0/0
- byron1111
21-03-07 17:50
- RE:RE: 求助来个大哥解读一下
- byron1111
21-03-07 17:46 - 0/0
- byron1111
21-03-07 17:46
- RE:RE: 用TCD测试氨气用什么柱子
- byron1111
21-03-07 17:44 - 0/0
- byron1111
21-03-07 17:44
- RE:RE:RE: 求助测大气中的CO2 CH4 和N2O的仪器方法
- byron1111
21-03-05 18:10 - 0/0
- byron1111
21-03-05 18:10
- byron1111
- byron1111
21-03-05 18:10
- RE:RE:RE: 气相ECD空白样信号升高
- byron1111
21-03-05 18:08 - 0/0
- byron1111
21-03-05 18:08
- RE:RE: 环氧乙烷
- byron1111
21-03-05 18:03 - 0/0
- byron1111
21-03-05 18:03
- RE:RE:RE: 如何检测氨基酸(D-丝氨酸)乙醇残留
- byron1111
21-03-05 16:05 - 0/0
- byron1111
21-03-05 16:05
- RE:RE: 如何检测氨基酸(D-丝氨酸)乙醇残留
- byron1111
- byron1111
21-03-05 16:05
- RE:RE: 色谱柱装填问题
- byron1111
21-03-05 16:04 - 0/0
- byron1111
21-03-05 16:04
- RE:RE: 蒸发光压力不稳
- byron1111
21-03-05 16:03 - 0/0
- byron1111
21-03-05 16:03
- RE:RE: 求助测大气中的CO2 CH4 和N2O的仪器方法
- byron1111
21-03-05 13:40 - 0/0
- byron1111
21-03-05 13:40
- byron1111
21-03-05 13:37 - 0/0
- byron1111
21-03-05 13:37
- RE:RE: 气相ECD空白样信号升高
- byron1111
21-03-05 13:35 - 0/0
- byron1111
21-03-05 13:35
- byron1111
21-03-05 08:31 - 0/0
- byron1111
21-03-05 08:31
- RE:请问如何判断特征离子呀
- byron1111
21-03-05 07:35 - 0/0
- byron1111
21-03-05 07:35
- RE:脂肪酸组分定性出峰数量不够
- byron1111
21-03-04 22:13 - 0/0
- byron1111
21-03-04 22:13
- RE:如何检测氨基酸(D-丝氨酸)乙醇残留
- byron1111
21-03-04 21:55 - 0/0
- byron1111
21-03-04 21:55
- RE:求助测大气中的CO2 CH4 和N2O的仪器方法
- byron1111
21-03-04 20:25 - 0/0
- byron1111
21-03-04 20:25
- RE:气象色谱工作站时间怎么设置无法修改
- byron1111
21-03-04 20:24 - 0/0
- byron1111
21-03-04 20:24
- byron1111
21-03-04 17:26 - 0/0
- byron1111
21-03-04 17:26
- byron1111
21-03-04 16:29 - 0/0
- byron1111
21-03-04 16:29
- byron1111
21-03-04 16:28 - 0/0
- byron1111
21-03-04 16:28
- RE:RE: GC 空气发生器一点疑问
- byron1111
21-03-04 13:47 - 0/0
- byron1111
21-03-04 13:47
- RE:RE:RE: 气象色谱工作站时间怎么设置无法修改
- byron1111
21-03-04 13:45 - 0/0
- byron1111
21-03-04 13:45
- RE:RE: 气象色谱工作站时间怎么设置无法修改
- byron1111
21-03-04 13:41 - 0/0
- byron1111
21-03-04 13:41
- RE:RE: 有一样品的检测波长213nm,在乙腈:水体系中可以测试(乙腈截止波长190nm,检测波长213nm和其相差23nm),而在甲醇:体系中由于甲醇紫外截止波长为210nm,和检测波长213 nm靠很近,所以检测不到信号,也可以
- byron1111
21-03-04 12:22 - 0/0
- byron1111
21-03-04 12:22
- RE:RE: DAD和ELSD
- byron1111
21-03-04 12:21 - 0/0
- byron1111
21-03-04 12:21
- RE:RE: DB-5出峰顺序判断
- byron1111
21-03-04 12:18 - 0/0
- byron1111
21-03-04 12:18
- byron1111
21-03-04 12:14 - 0/0
- byron1111
21-03-04 12:14
- RE:RE: 5975MS罢工了,液晶板面无显示,后面的绿色灯也不亮,但分子泵可以启动。请问有什么可能的原因?
- byron1111
21-03-04 08:35 - 0/0
- byron1111
21-03-04 08:35
- RE:RE:RE: 四级杆质量分析器扫描电压
- byron1111
21-03-04 08:32 - 0/0
- byron1111
21-03-04 08:32
- RE:RE:RE: 面积响应值很大
- byron1111
21-03-04 08:24 - 0/0
- byron1111
21-03-04 08:24
- RE:RE: 脂肪酸组分定性出峰数量不够
- byron1111
21-03-04 08:22 - 0/0
- byron1111
21-03-04 08:22
- byron1111
21-03-04 07:45 - 0/0
- byron1111
21-03-04 07:45
- RE:RE: GCMS响应值忽高忽低
- byron1111
21-03-03 17:47 - 0/0
- byron1111
21-03-03 17:47
- RE:RE: 四级杆质量分析器扫描电压
- byron1111
21-03-03 17:40 - 0/0
- byron1111
21-03-03 17:40
- RE:RE: gc 9790Ⅱ
- byron1111
21-03-03 17:28 - 0/0
- byron1111
21-03-03 17:28
- RE:RE: 岛津gc2010无法连pc
- byron1111
21-03-03 12:28 - 0/0
- byron1111
21-03-03 12:28
- RE:RE:RE: 如何用气相色谱测二氧化碳 甲烷和氧化亚氮
- byron1111
21-03-03 12:23 - 0/0
- byron1111
21-03-03 12:23
- RE:RE: 岛津气相GC2014C
- byron1111
21-03-03 12:21 - 0/0
- byron1111
21-03-03 12:21
- RE:RE: 求助optima624色谱柱老化程序
- byron1111
21-03-03 11:50 - 0/0
- byron1111
21-03-03 11:50
