矿浆体系不知道程度如何?
一般pH电极耐用的可以选择使用瑞士万通专用的高温pH电极。可以在摄氏100度下连续使用,带温度探头。
电极货号:6.0258.010 Unitrode with Pt 1000 (2 mm plug)
High performance in difficult samples and at high temperatures
- High temperature resistance (0...100 °C)
- Very low alkali error
- Short stabilization times after temperature changes
- Can be used for long-term measurements
- Fixed ground-joint diaphragm insensitive to contamination。
直接与瑞士万通的各地联络处和经销商即可。
