主题:【求助】(已应助)求助几篇外文文献,谢谢!
浏览0 回复17 电梯直达
YIQIFENXI
悬赏金额:50积分 状态: 已解决
在下求助以下几篇文献,有几篇是较古老的了,求各位大侠帮忙啊!谢谢了!
谢谢大家的帮助,我的邮箱是wy-zhejiang@163.com
1.    Harnly J M. Multielement atomic absorption with a continuum source. Anal.Chem., 1986 58(8): 933A-943A
2.    O’Haver T C, Harnly J M,  Zander A T. Comparison of radiant power of the Eimac xenon lamp and hollow cathode lamp sources. Anal.Chem., 1978 50(8): 1218-1221
3.    Cochran R L, Hieftje G M,  Spectral and noise characteristics of a 300-W Eimac arc lamp. Anal.Chem., 1977 49(13): 2040-2043
4.    Pebler A, Zomp J M, Stabilizing the radiant flux of a xenon arc lamp. Applied Optics, 1981  20(23): 4059-4061
5.    O’Haver T C, Messman J D.Continuum source atomic absorption spectrometry, Prog. Analyt. Spectrosc., 1986 9(4):483-503
6.    Snelleman W,An A.C. Scanning method with increased sensitivity in atomic absorption analysis using a continuum primary source.Spectrochim. Acta, 1968 23B(6): 403-411
7.    Hsiech C, Petrovic S C, Pardue H L. Continuum-source atomic absorption spectroscopy with an echelle spectrometer adapted to a charge injection device. Anal.Chem., 1990 62(18): 1983-1988
8.    Harnly J M. Graphite furnace atomic absorption spectrometry using a linear photodiode array and continuum source. J.Anal.At. Spectrom., 1993 8(2): 317-324
9.    Smith C C M, Harnly J M. Effect of elevated gas pressure on atomization in graphite furnace continuum aource atomic absorption spectrometry with linear photodiode array detector. J.Anal.At. Spectrom., 1993 10(3):187-195
10.    Harnly J M, Smith C C M, Radziuk B. Extended calibration range for continuum source atomic absorption spectrometry with array detection Spectrochim. Acta, 1996 51B(9/10): 1055-1079
11.    Harnly J M, Smith C C M, Wichems D N,et al., Use of a segmented array charge coupled devive detector for continuum source atomic absorption spectrometry with graphite furance atomization. J Anal. At.Spectrom., 1997, 12(6): 617-627
12.    Wichenms D N, Field R E, Harnly J M. Characterization of hyperbolic calibration curves for continuum source atomic absorption spectrometry with array detection. J Anal. At.Spectrom., 1998 13(11): 1277-1284
推荐答案:fengxuezhang200回复于2008/01/14
1、2、3、7已发往楼主邮箱,请楼主查收
补充答案:
醉卧古隆中回复于2008/01/14
A. Pebler and J. M. Zomp
Applied Optics, Vol. 20, Issue 23, pp. 4059- (December 1981)
ApplOptics20-4059
piter18
nancy_liu2006
比较难找了。你要这些文献可以叫老外试试看,毕竟是他们的资料库
fengxuezhang200
fengxuezhang200
我找到了1237四篇,需要的话,我发你邮箱,这样上传太慢了。或者联系我fengxuezhang200@163.com.
happyfish9966
醉卧古隆中
Desmond N. Wichems, Robert E. Fields, James M. Harnly
Journal of Analytical Atomic Spectrometry, 1998, 13(11), 1277-1284
JAAS1998-1277
附件:
醉卧古隆中
Use of a Segmented Array Charge Coupled Device Detector for Continuum Source Atomic Absorption Spectrometry With Graphite Furnace Atomization
Journal of Analytical Atomic Spectrometry, 1997, 12, 617 - 627
JAMES M. HARNLY, CLARE M. M. SMITH, DESMOND N. WICHEMS, JUAN C. IVALDI, PETER L. LUNDBERG and BERNARD RADZIUK
JAAS1997-617
附件:
醉卧古隆中
Extended calibration ranges for continuum source atomic absorption spectrometry with array detection
Spectrochimica Acta Part B: Atomic Spectroscopy, Volume 51, Issues 9-10, Pages 1055-1079 (30 July 1996)
James M. Harnly, Clare M. M. Smith and Bernard Radziuk
SpectrochimActaB51-1055
juliaju66
fengxuezhang200
