主题:【求助】(已应助)求助一些老文献
浏览0 回复22 电梯直达
jiangzq
悬赏金额:85积分 状态: 已解决
请楼主下次求助时一定要加上编号
目前还有5、13、14、19、20没有应助!
谢谢斑竹
以后注意!
1、
Yoshiyuki Sakai
First-principles analysis of tunneling spectra for rutile TiO2 (110) surface with oxygen vacancies
Advances in Quantum Chemistry, Volume 42, Pages 429-438 (2003)
2、
ONISHI H, FUKUI K, IWASAWA Y
Atomic-scale surface-structures of TiO2(110) determined by scanning-tunneling-microscopy – a new surface-limited phase of titanium-oxide
Bulletin of the Chemical Society of Japan 68 (9): 2447-2458 SEP 1995
3、
K. V. R. Chary, V. Venkat Rao, G. Muralidhar, P. Kanta Rao
Influence of molybdena on the dispersion and activity of vanadia in V2O5/γ-Al2O3 catalysts
Catalysis Letters, Volume 7, Numbers 5-6, Pages 389-394 (1990年9月)
4、
Lars G. M. Pettersson and Gianfranco Pacchioni
The electronic structure of an oxygen defect in NiO (100)
Chemical Physics Letters, Volume 219, Issues 1-2, Pages 107-112 (4 March 1994)
5、
Benjara N. Reddy, Machiraju Subrahmanyam
Selective ammoxidation of 3-picoline to nicotinonitrile on MoO3-promoted V2O5/-Al2O3 catalyst
Chemistry & Industry, Issue 3, Pages 95-96 (February 1991)
6、
M. G. Sanchez and J. L. Gazquez
Oxygen vacancy model in strong metal-support interaction
Journal of Catalysis, Volume 104, Issue 1, Pages 120-135 (March 1987)
7、
Thi X. T. Sayle, Stephen C. Parker and C. Richard A. Catlow
Surface oxygen vacancy formation on CeO2 and its role in the oxidation of carbon monoxide
Journal of the Chemical Society - Chemical Communications (14): 977-978 JUL 15 1992
8、
Michael A. Vuurman, Derk J. Stufkens, Ad Oskam, Goutam Deo and Israel E. Wachs
Combined Raman and IR study of MOx–V2O5/Al2O3(MOx= MoO3, WO3, NiO, CoO) catalysts under dehydrated conditions
Journal of the Chemical Society, Faraday Transactions, Volume 92, Issue 17, Pages 3259-3265 (September 1996)
9、
Michael A. Vuurman and Israel E. Wachs
Raman spectroscopy of V2O5, MoO3, Fe2O3, MoO3-V2O5, and Fe2O3-V2O5 supported on alumina catalysts: Influence of coverage and dehydration
Journal of Molecular Catalysis, Volume 77, Issue 1, Pages 29-39 (1 November 1992)
10、
L.A. Bursill and M.G. Blanchin
Structure of small oxygen vacancy defects in nonstoichiometric rutile
Journal of Solid State Chemistry, Volume 51, Issue 3, Pages 321-335 (1 March 1984)
11、
J. Walczak, P. Tabero
Studies on the system Al2O3-V2O5-MoO3
Journal of Thermal Analysis and Calorimetry, Volume 36, Number 6, Pages 2173-2176 (1990年9月)
12、
B. Mahipal Reddy, E. Padmanabha Reddy and Safia Mehdi
Phase transformation study of titania in V2O5/TiO2 and MoO3/TiO2 catalysts by X-ray diffraction analysis
Materials Chemistry and Physics, Volume 36, Issues 3-4, Pages 276-281 (January 1994)
13、
Isao Tanaka, Fumiyasu Oba, Kazuyoshi Tatsumi, Masahiro Kunisu, Masanobu Nakano and Hirohiko Adachi
Theoretical formation energy of oxygen-vacancies in oxides
Materials Transactions, Volume 43, Number 7, Pages 1426-1429 (July 2002)
14、
Martra G, Vittone P, Coluccia S, et al.
UV-Vis diffuse reflectance and FT-IR spectroscopic investigation of V2O5/SiO2 and MoO3/SiO2 catalysts for partial oxidation of methane to formaldehyde
Nuovo Cimento Della Società Italiana di Fisica D - Condensed Matter, Atomic, Molecular and Chemical Physics, Fluids, Plasmas, Biophysics 19 (11): 1727-1734 NOV 1997
15、
Y. Aiura, Y. Nishihara, Y. Haruyama, T. Komeda, S. Kodaira, Y. Sakisaka, T. Maruyama and H. Kato
Effects of surface oxygen vacancies on electronic states of TiO2(110), TiO2(001) and SrTiO3(001) surfaces
Physica B: Condensed Matter, Volumes 194-196, Part 1, Pages 1215-1216 (2 February 1994)
16、
S. Munnix and M. Schmeits
Electronic structure of oxygen vacancies in TiO2
Solid State Communications, Volume 50, Issue 12, Pages 1087-1089 (June 1984)
17、
Parmaliana A, Arena F, Frusteri F, et al.
Active species and working mechanism of silica supported MoO3 and V2O5 catalysts in the selective oxidation of light alkanes
Studies in Surface Science and Catalysis 110: 347-356 1997
18、
Partial oxidation of methane to formaldehyde on bulk and silica supported MoO3 and V2O5 catalysts: Surface features and reaction mechanism
Studies in Surface Science and Catalysis 107: 23-28 1997
19、
PARMALIANA A, SOKOLOVSKII V, SCURRELL MS, et al.
METHANE PARTIAL OXIDATION TO FORMALDEHYDE ON SILICA-SUPPORTED OXIDE CATALYSTS - ROLE OF MOO3 AND V2O5
Studies in Surface Science and Catalysis 81: 491-496 1994
20、
GRZYBOWSKA B, MEKSS P, GRABOWSKI R, et al.
EFFECT OF POTASSIUM ADDITION TO V2O5/TIO2 AND MOO3/TIO2 CATALYSTS ON THEIR PHYSICOCHEMICAL AND CATALYTIC PROPERTIES IN OXIDATIVE DEHYDROGENATION OF PROPANE
Studies in Surface Science and Catalysis 82: 151-158 1994
21、
T. X. T. Sayle, S. C. Parker and C. R. A. Catlow
The role of oxygen vacancies on ceria surfaces in the oxidation of carbon monoxide
Surface Science, Volume 316, Issue 3, Pages 329-336 (10 September 1994)
22、
Walter Lambrecht, Bahram Djafari-Rouhani and Joost Vennik
Electronic structure of bulk and surface vanadyl oxygen vacancies in the layer compound V2O5
Surface Science, Volume 126, Issues 1-3, Pages 558-564 (2 March 1983)
谢谢两位的大力帮助!
推荐答案:panyb15715回复于2008/01/26
补充答案:
海之巅回复于2008/01/25
Studies in Surface Science and Catalysis 是SD上的,但好像显示的为book 系列,没有找到下载的权限
海之巅
海之巅
海之巅
海之巅
海之巅
海之巅
panyb15715
panyb15715
panyb15715
