Accession Number : ADA067829
Title : Thermogravimetric Analysis of Solid Refuse-Derived Fuels and Coal.
Descriptive Note : Technical rept.,
Corporate Author : CONSTRUCTION ENGINEERING RESEARCH LAB (ARMY) CHAMPAIGN ILL
Personal Author(s) : Hathaway,S. A. ; Lin,J. S.
Report Date : MAR 1979
Pagination or Media Count : 28
Abstract : The ignition and combustion rates of three types of densified refuse-derived fuel (DRDF) and low-volatile Illinois bituminous coal were investigated at temperatures ranging from 600 C to 1000 C and residence times ranging up to 120 sec. It was found that DRDF ignition time is up to 12 times less than that of coal, that the temperature required for coal ignition at a given residence time is greater than that needed for DRDF ignition, and that the DRDF:coal time to ignition ratio is expressible as a linear function of furnace temperature. It was also found that DRDF produced from mixed municipal-residential solid waste has a slower combustion rate than that produced from homogeneous heavy paper stock, and that the combustion rates of all types of DRDF are significantly greater than that of the coal tested at a 99.9 percent level of confidence. (Author)
Descriptors : *FUELS, *SOLID WASTES, *THERMOGRAVIMETRIC ANALYSIS, TEMPERATURE, EFFICIENCY, COMBUSTION, IGNITION, BURNING RATE, ENERGY CONSERVATION, SAVINGS, COAL.
Subject Categories : PHYSICAL CHEMISTRY
CIVIL ENGINEERING
FUELS
Distribution Statement : APPROVED FOR PUBLIC RELEASE
只有摘要了
