1. Investigation of Corrosion and Cathodic Protection in Reinforced Concrete. D.A.Koleva et al 154, C261 (2007) 2. Algorithm for Extracting Corrosion Parameters from the Response of the Steel-Concrete System to a Current Pulse . V.Feliu et al 151, B134 (2004) 3. Modeling the Time-Dependent Response to External Polarization of a Corrosion Macrocell on Steel in Concrete S.C.Kranc et al 144, 2643 (1997) 4. Important Early Developments and Current Understanding of the IR Mechanism of Localized Corrosion Howard W. Pickering 150, K1 (2003) 5. Impedance Study of Reinforcing Steel in Simulated Pore Solution with Tannin J. Flis et al 143, 2458 (1996) 6. Electrochemical Behavior, Microstructural Analysis, and 6.Morphological Observations in Reinforced Mortar Subjected to Chloride Ingress D.A.Koleva et al 154, E45 (2007) 7. Investigation of Corrosion and Cathodic Protection in Reinforced Concrete D. A. Koleva et al 154, P52 (2007)
