1.Internal standardization and least-squares background correction in high-resolution continuum source flame atomic absorption spectrometry to eliminate interferences on determination of Pb in phosphoric acid
http://www.sciencedirect.com/science?_ob=ArticleURL&_udi=B6THN-4SKK20J-1&_user=1915929&_rdoc=1&_fmt=&_orig=search&_sort=d&view=c&_version=1&_urlVersion=0&_userid=1915929&md5=be98912b3f4b6070d245ae1e833e26f0
2.Investigation of artifacts caused by deuterium background correction in the determination of phosphorus by electrothermal
atomization using high-resolution continuum source atomic absorption spectrometry
http://www.sciencedirect.com/science?_ob=ArticleURL&_udi=B6THN-4R9Y76S-1&_user=1915929&_rdoc=1&_fmt=&_orig=search&_sort=d&view=c&_acct=C000055340&_version=1&_urlVersion=0&_userid=1915929&md5=f01f186a06e1489f3b77ab74e884afdb
3.Advances with tungsten coil atomizers: Continuum source atomic absorption and emission spectrometry
http://www.sciencedirect.com/science?_ob=ArticleURL&_udi=B6THN-4FVH47X-2&_user=1915929&_rdoc=1&_fmt=&_orig=search&_sort=d&view=c&_version=1&_urlVersion=0&_userid=1915929&md5=f60d5e94e21503c49ad698c4a67d89b9
4.A comparison between continuum- and line source
AAS for speciation analysis of butyl- and phenyltin compounds
http://www.rsc.org/Publishing/Journals/JA/article.asp?doi=b518270k
5.Fraunhofer Effect Atomic Absorption Spectrometry
http://pubs.acs.org/cgi-bin/abstract.cgi/ancham/2005/77/i04/abs/ac048917u.html
6.Continuum-source atomic-absorption spectrometry: past, present and future prospects. Plenary lecture
http://www.rsc.org/publishing/journals/AN/article.asp?doi=AN9840900211
7.High Resolution Atomic Absorption Spectrometry Using an Echelle Grating Monochromator
http://pubs.acs.org/cgi-bin/abstract.cgi/ancham/1974/46/i06/f-pdf/f_ac60342a011.pdf?sessid=6006l3(只有一页,求全文)
