25. Given a table of COPQ data over time, the Six Sigma Black Belt should be able to perform a statistical analysis of the distribution of costs among the various categories.
给出过去的劣质成本报表,6西格玛黑带应能对各类品质成本的分配情况进行统计分析。
26. Given a list of tasks for a project, their times to complete, and their precedence relationships, the Six Sigma Black Belt should be able to compute the time to completion for the project, the earliest completion times, the latest completion times and the slack times. He should also be able to identify which tasks are on the critical path.
给出一个项目的任务列表、它们的完成时间和它们之间的优先级关系,6西格玛黑带应能计算出项目的完成时间、最早完成时间、最迟完成时间和延迟时间。他还应能识别哪项任务位于关键路径上。
27. Give cost and time data for project tasks, the Six Sigma Black Belt should be able to compute the cost of normal and crash schedules and the minimum total cost schedule.
给出项目任务的成本和时间数据,6西格玛黑带应能计算出正常的和紧急加快的生产费用表以及最小的生产总费用表。
28. The Six Sigma Black Belt should be familiar with the basic principles of benchmarking.
6西格玛黑带应熟悉标杆的基本原理。
29. The Six Sigma Black Belt should be familiar with the limitations of benchmarking. 6西格玛黑带应熟悉标杆的局限性。
30. Given an organization chart and a listing of team members, process owners, and sponsors, the Six Sigma Black Belt should be able to identify projects with a low probability of success.
给出一份组织图和团队成员名单、过程负责人和发起人,6西格玛黑带应能识别出哪些是成功机率小的项目。
31. The Six Sigma Black Belt should be able to identify measurement scales of various metrics (nominal, ordinal, etc).
6西格玛黑带应能识别各种度量标准的测量标度(名义的、顺序的等等)。
32. Given a metric on a particular scale, the Six Sigma Black Belt should be able to determine if a particular statistical method should be used for analysis.
给定一种特定标度的度量标准,6西格玛黑带应能确定采用什么特定的统计学方法进行分析。
33. Given a properly collected set of data, the Six Sigma Black Belt should be able to perform a complete measurement system analysis, including the calculation of bias, repeatability, reproducibility, stability, discrimination (resolution) and linearity.
给出一组适当的数据,6西格玛黑带应能完成测量系统分析,包括计算偏倚、重复性、再现性、稳定性、辨别力(分辨率)和线性。
34. Given the measurement system metrics, the Six Sigma Black Belt should know whether or not a given measurement system should be used on a given part or process.
给出测量系统的度量标准,6西格玛黑带应了解给定的测量系统能否用于给定的零件或过程。
35. The Six Sigma Black Belt should know the difference between computing sigma from a data set whose production sequence is known and from a data set whose production sequence is not known.
6西格玛黑带应了解从已知生产次序的数据组和未知生产次序的数据组计算出的西格玛之间的不同。
36. Given the results of an AIAG Gage R&R study, the Six Sigma Black Belt should be able to answer a variety of questions about the measurement system.
给出一份 AIAG(汽车工业行动集团)量具双性研究结果,6西格玛黑带应能回答各种关于该测量系统的问题。
37. Given a narrative description of "as-is" and "should-be" processes, the Six Sigma Black Belt should be able to prepare process maps.
给出一个“不予改变”和“应”的过程叙述性描述,6西格玛黑带应能作出过程图。
