1.网址:http://www3.interscience.wiley.com/journal/73503402/abstract
题目:Nanocrystalline Titania Films and Particles by Chemical Vapor Synthesis
作者:S. Seifried, M. Winterer, H. Hahn
期刊:Chemical Vapor Deposition
卷号:2000,6(5):239-244
2.网址:http://www.nature.com/nmat/journal/v4/n6/abs/nmat1387.html
题目:Nanowire dye-sensitized solar cells
作者:Matt Law1,2,3, Lori E. Greene1,2,3, Justin C. Johnson1, Richard Saykally1 and Peidong Yang
期刊:Nature Materials 4, 455 - 459 (2005)
3.网址:http://www.nature.com/nnano/journal/v4/n9/pdf/nnano.2009.226.pdf
题目:Long vertically aligned titania nanotubes on transparent conducting oxide for highly efficient solar cells
作者:Oomman K. Varghese , Maggie Paulose & Craig A. Grimes
期刊:Nature Nanotechnology 4, 592–597 (1 September 2009) | doi:10.1038/nnano.2009.226
4.网址:http://www.iop.org/EJ/abstract/0022-3727/38/8/009
题目:Field-emission properties of TiO2 nanowire arrays
作者:B Xiang, Y Zhang, Z Wang, X H Luo, Y W Zhu, H Z Zhang and D P Yu
期刊:B Xiang et al 2005 J. Phys. D: Appl. Phys. 38 1152-1155 doi: 10.1088/0022-3727/38/8/009
5.网址:http://scitation.aip.org/vsearch/servlet/VerityServlet?KEY=JESOAN&smode=strresults&sort=rel&maxdisp=25&threshold=0&pjournals=JESOAN%2CTESOAV&possible1zone=article&fromvolume=139&tovolume=139&fromissue=9&toissue=9&OUTLOG=NO&viewabs=JESOAN&key=DISPLAY&docID=40&page=2&chapter=0
题目:Photoelectrochemical Energy Conversion Obtained with Ultrathin Organo-Metallic-Chemical-Vapor-Deposition Layer of FeS2 (Pyrite) on TiO2
作者:A. Ennaoui, S. Fiechter, and H. Tributsch, M. Giersig, R. Vogel, and H. Weller
期刊:J. Electrochem. Soc., Volume 139, Issue 9, pp. 2514-2518 (1992)
6.网址:http://scitation.aip.org/vsearch/servlet/VerityServlet?KEY=JESOAN&smode=strresults&sort=rel&maxdisp=25&threshold=0&pjournals=JESOAN%2CTESOAV&possible1zone=article&fromvolume=133&tovolume=133&fromissue=1&toissue=1&OUTLOG=NO&viewabs=JESOAN&key=DISPLAY&docID=1&page=1&chapter=0
题目:Photoelectrochemistry of Highly Quantum Efficient Single-Crystalline n-FeS2 (Pyrite)
作者:A. Ennaoui, S. Fiechter, W. Jaegermann, and H. Tributsch
期刊:J. Electrochem. Soc., Volume 133, Issue 1, pp. 97-106 (1986)
7.网址:http://scitation.aip.org/vsearch/servlet/VerityServlet?KEY=JESOAN&smode=strresults&sort=rel&maxdisp=25&threshold=0&pjournals=JESOAN%2CTESOAV&possible1zone=article&fromvolume=147&tovolume=147&fromissue=5&toissue=5&OUTLOG=NO&viewabs=JESOAN&key=DISPLAY&docID=40&page=2&chapter=0
题目:In Situ Mass Spectrometric Study of Pyrite (FeS2) Thin Film Deposition with Metallorganic Chemical Vapor Deposition
作者:Liesbeth Reijnen, Ben Meester, Albert Goossens, and Joop Schoonman
期刊:J. Electrochem. Soc., Volume 147, Issue 5, pp. 1803-1806 (2000)
8.网址:http://www3.interscience.wiley.com/journal/72503658/abstract
题目:Synthesis of Pyrite (FeS2) Thin Films by Low-Pressure MOCVD
作者:B. Meester, L. Reijnen, A. Goossens, J. Schoonman
期刊:Chemical Vapor Deposition Volume 6 Issue 3, Pages 121 - 128
9.网址:http://www.sciencedirect.com/science?_ob=ArticleURL&_udi=B6TXC-48JM1X4-6H&_user=6093726&_coverDate=09%2F30%2F1988&_rdoc=5&_fmt=high&_orig=browse&_srch=doc-info(%23toc%235587%231988%23999769990%23428674%23FLP%23display%23Volume)&_cdi=5587&_sort=d&_docanchor=&_ct=18&_acct=C000069303&_version=1&_urlVersion=0&_userid=6093726&md5=1044a7a8b9797950707cf1c75ae191e8
题目:Low temperature chemical preparation of semiconducting transition metal chalcogenide films for energy conversion and storage, lubrication and surface protection
作者:G. Chatzitheodorou*, S. Fiechter*, M. Kunst*, J. Luck** and H. Tributsch*
期刊:Materials Research Bulletin Volume 23, Issue 9, September 1988, Pages 1261-1271
10.网址:http://scitation.aip.org/getabs/servlet/GetabsServlet?prog=normal&id=APPLAB000089000025253513000001&idtype=cvips&gifs=Yes&ref=no
题目:Dye sensitized solar cells using well-aligned zinc oxide nanotip arrays
作者:
期刊:Appl. Phys. Lett. 89, 253513 (2006);
11. 网址:http://www3.interscience.wiley.com/journal/110573957/abstract
题目:The Fabrication of an Upright-Standing Zinc Oxide Nanosheet for Use in Dye-Sensitized Solar Cells
作者:E. Hosono 1 2, S. Fujihara 3, I. Honma 1, H. Zhou 1 2 *
期刊:Advanced Materials Volume 17 Issue 17, Pages 2091 - 2094
