主题:【已应助】ISO关于皮革方面标准(1)
浏览0 回复15 电梯直达
山石
悬赏金额:30积分 状态: 已解决
1. ISO 4098:2006 Leather -- Chemical tests -- Determination of water-soluble matter, water-soluble inorganic matter and water-soluble organic matter
2. ISO 5398-1:2007 Leather -- Chemical determination of chromic oxide content -- Part 1: Quantification by titration
3. ISO 5398-2:2009 Leather -- Chemical determination of chromic oxide content -- Part 2: Quantification by colorimetric determination
4. ISO 5398-3:2007 Leather -- Chemical determination of chromic oxide content -- Part 3: Quantification by atomic absorption spectrometry
5. ISO 5398-4:2007 Leather -- Chemical determination of chromic oxide content -- Part 4: Quantification by inductively coupled plasma - optical emission spectrometer (ICP-OES)
6. ISO 17233:2002 Leather -- Physical and mechanical tests -- Determination of cold crack temperature of surface coatings
7. ISO 17227:2002 Leather -- Physical and mechanical tests -- Determination of dry heat resistance of leather
8. ISO 3380:2002 Leather -- Physical and mechanical tests -- Determination of shrinkage temperature up to 100 degrees C
9. ISO 2419:2006 Leather -- Physical and mechanical tests -- Sample preparation and conditioning
10. ISO 2417:2002 Leather -- Physical and mechanical tests -- Determination of the static absorption of water
推荐答案:灰米奇回复于2011/01/02
补充答案:
阿迈回复于2011/03/07
10.    ISO 2417-2002
可以结贴了吧!
灰米奇
灰米奇
灰米奇
灰米奇
灰米奇
灰米奇
灰米奇
灰米奇
附件:
山石
灰米奇, 可不可以把这3个贴求助内容调整一下, 把其它两个帖子里面已经应助的标准跟这两个没有应助的换一下, 这样可以先结一个贴。
灰米奇
原文由 山石(ivanxie) 发表:
您自己看着办吧,但不能把已有应助的删除或移动哦~
