【Author】 ZHANG Qi,XIANG Guang-Ya,LONG Na,WU Ji-Zhou(School of Pharmacy,Tongji Medical College of Huazhong University of Science & Technology,Wuhan 430030,China)
【Abstract】 AIM:To investigate enzymatic hydrolysis of N-(phenylacetyl) doxorubicin(DOXP) catalyzed by folate-conjugated penicillin-G acylase(PGA).METHODS:The determination of prodrug DOXP and cleavage product doxorubicin was monitored by HPLC.A Diamonsil C18 column(250 mm×4.6 mm,5 μm) was used with 1 mL/min flow rate of 85% phosphoric acid in water(pH 2.4) with a gradient of acetonitrile created according to the following scheme:24% for 3 min and then constant at 80% for 12 min.RESULTS:PGA effec... 更多还原 【关键词】 叶酸; 青霉素G酰化酶; N-苯乙酰化阿霉素; 催化活性; 高效液相色谱法; 【Key words】 Folate; Penicillin-G acylase; N-(Phenylacetyl) doxorubicin; Catalytic activity; HPLC; 【基金】 国家自然科学基金资助项目(No.30300430)~~
【Author】 WU Yan 1,GUO Cheng-Ming 1,Zhang Sheng-Qiang 2 ( 1Tianjin Institute for Drug Control,Tianjin 300070; 2Department of Pharmaceutical Analysis,China Pharmaceutical University,Nanjing 210009,China)
【Abstract】 AIM:To establish an HPLC and evaporative light-scattering detection(ELSD) method for the related substance analysis of spectinomycin and content determination of spectinomycin fermented solution.METHOD: The Diamonsil C_ 18 column (250 mm×4.6 mm,5 μm) was used and the mobile phase consisted of 0.04 mol/L trifluoroacetic acid solution.The temperature of the drift tube was 50 ℃ and the gas pressure was 3.0× 105 Pa.RESULT: The chromatography system met the need of related substances analysis of spec... 更多还原 【关键词】 大观霉素; 高效液相色谱法; 蒸发光散射检测; 含量测定; 有关物质; 【Key words】 Spectinomycin; HPLC; Evaporative light-scattering detection; Content determination; Related substance;
【Abstract】 AIM To develop HPLC method for the determination of the main ingredients (Baicalin and Icariin) in Anti-allergy Capsules. METHODS The measurement conditions used as follows; For Baicalin, Diamosil C18 Column; mobile phase: 0. 05mol/L phosphate solution-Acetonitrile (70: 30) ; flow rate 1 ml/min; wavelength for measurement 277 nm;For Icariin, Spherisorb C18 column; mobile phase: Acetonitrile-water-acetate acid(22:78: 0. 1); flow rate 1 ml/min; wavelength for measurement 270 nm. The recovery rates... 更多还原 【关键词】 黄芩苷; 淫羊霍苷; 高效液相色谱法; 【Key words】 Baicalin; Icariin; HPLC;
【Abstract】 AIM The purpose is to develop a method for determining the contents of two different xanthone in Polygala fallax Hemsl. METHOD The method used Dikma Diamonsil C 18 column with MeOH-H 2O(65∶35) as mobile phase,0.9ml/min as flow-rate and 996-photodiode array detector at 245 nm. RESULTS The relative standard deviation of the repeatability were 0.96% and 2.6% respectively and the average recovery were 99.40% and 100.8% respectively. CONCLUSION The method was simple and had good liner relationship. 更多还原 【关键词】 黄花倒水莲; 酮; 反相高效液相色谱; 二级管阵列检测器; 【Key words】 Polygala fallax Hemsl.; Xanthone; RP-HPLC; DAD;
【Abstract】 AIM The purpose is to develop the analysis method of Icariin in Shenbao mixture; METHODS A HPLC method was adopted .The measurement condition used are as follows: Dikma Diamonsil ODS column; mobile phase: acetonitrile water acetic acid glacial(30∶70∶1); flow rate 1.0ml/min; wavelength for measure 270 nm; The conditions of extraction and determination were optimized. RESULT The relative standard deviation of the reproducibility was 2.11% and the average recovery rate was 97.79%. CONCLUSION The me... 更多还原 【关键词】 肾宝合剂; 淫羊藿苷; 高效液相色谱法; 【Key words】 Shenbao mixture; Icariine; HPLC;
【Author】 DUAN Wei(Shenyang Pharmaceutical University,Shenyang 110016,China)DUAN Wei,XIA Dong-ya,GUO Tao(Dept. of Pharmacy,The General Hospital of Shenyang Military Region,Shenyang 110016,China)
【Abstract】 OBJECTIVE:To establish an HPLC method for the determination of cefepime in human plasma.METHODS:The separation of sample was carried on a Diamonsil C18 column with the mobile phase consisted of 20 mmol·L-1 ammonium acetate(which was adjusted to pH=5.00 by acetic acid)-acetonitrile(90∶10) at a flow rate of 1.0 mL·min-1.The detection wavelength was set at 254 nm;the sample size was 20 μL,and the column temperature was set at room temperature.RESULTS:The linear range of cefepime was 0.2~50.0 μg·mL-... 更多还原 【关键词】 头孢吡肟; 高效液相色谱法; 血药浓度;
【Author】 YE Li-ka,XIE Zhi-hong,WANG Ruo-lun,XU Xin,ZHANG Wei-ting(The Second Affiliated Hospital of Guangzhou Medical College, Guangzhou 510260, China)
【Abstract】 OBJECTIVE:To determine the plasma mycophenolic acid concentration by HPLC, and study the multidoses pharmacokinetics character of mycophenolic acid in Chinese kidney transplantation patients. METHODS: The samples were precipitated with acetonitrile before injection. Diamonsil C18 column was used. The mobile phase consisted of acetonitrile-10 mmol·L-1 KH2PO4 (5∶6) at a flow rate of 1.1 mL·min-1. The detection wavelength was 254 nm and the column temperature was 40 ℃. This method was used to deter... 更多还原 【关键词】 霉酚酸; 高效液相色谱法; 肾移植患者; 血药浓度; 多剂量; 药动学; 【Key words】 Mycophenolic acid; HPLC; Kidney transplantation patients; Plasma drug concentration; Multidoses; Pharmacokinetics; 【基金】 广州市属高校科技项目(61027);广东省医院药学研究基金资助项目(2008A018)
【Author】 ZHANG Ya-zhou,LUO Li-li,DONG Li-sha(Guiyang College of Traditional Chinese Medicine, Guiyang 550002, China)CAI Shao-qing(School of Pharmaceutical Sciences, Beijing University, Beijing 100083,China)
【Abstract】 OBJECTIVE: To establishes an HPLC method for determination of the contents of Osthol and Berberine in Kangfuyan effervescent suppository. METHODS: HPLC was carried out on a column of Diamonsil (250 mm×4.6 mm,5 μm) with mobile phase consisted of acetonitrile-0.2% phosphate acid (52∶48,Lauryl sulfonic acid sodium 0.1 g was contained in every 100 mL) with flow rate at 1 mL·min-1.The detection wavelength was set at 322 nm and the column temperature was set at room temperature. RESULTS: The linear ra... 更多还原 【关键词】 抗妇炎泡腾栓; 反相高效液相色谱法; 蛇床子素; 盐酸小檗碱; 含量测定; 【Key words】 Kangfuyan effervescent suppository; RP-HPLC; Osthole; Berberine; Content determination; 【基金】 贵州省中药现代化科技创新项目(2006-5011)
【Author】 WANG Xin(Department of Pharmacy,The Second Affiliated Hospital of Hebei Medical University,Shijiazhuang 050000,China)JIANG Qin(Center of Drug Research and Development,North China Pharmaceutical Group Corporation,Shijiazhuang 050015,China)
【Abstract】 OBJECTIVE:To establish the quality standard for Ruheneixiao soft capsules.METHODS:Radix Paeoniae Rubra,Radix Angelicae Sinensis and Spica Prunellae were identified using TLC.The content of Paeoniflorin in Ruheneixiao Soft Capsules was determined with HPLC.HPLC analytical method was carried out using a C18 column and a mixture containing 13 volume of acetonitrile and 87 volume of water as the mobile phase.The detection wavelength was set at 230nm.RESULTS:Spots obtained from the test solutions had... 更多还原 【关键词】 乳核内消软胶囊; 薄层色谱法; 高效液相色谱法; 赤芍; 当归; 夏枯草; 芍药苷; 【Key words】 Ruheneixiao soft capsules; TLC; HPLC; Radix Paeoniae Rubra; Radix Angelicae Sinensis; Spica Prunellae; Paeoniflorin;
【Abstract】 Objective: To develop an HPLC method for the determination of baicalin and arctiin in Huxitong Oral Solution.Method: Analysis was carried out at room temperature on a platisil ODS column(4.6 mm × 250 mm,5 μm) with acetonitrile-0.02% phosphoric acid as the mobile phase,detecting at 208 nm·Result: The average recovery of baicalin was 99.0%,RSD 0.94% and the linear range was 10-100 mg·L-1,r = 0.999 5;The average recovery of arctiin was 100.5%,RSD 1.29% and the linear range was 5-50 mg·L-1,r = 0.999... 更多还原 【关键词】 呼吸通口服液; 黄芩苷; 牛蒡子苷; 高效液相色谱法; 【Key words】 Huxitong Oral Solution; baicalin; arctiin; HPLC; 【基金】 南京市医学科技发展项目(YKK08109)
