主题:【已应助】哪位有ASTM E1221-12a?还望赐教给小弟。
浏览0 回复2 电梯直达
fanluvchou
内容大概是这样的:
1. Scope
1.1 This test method employs a side-grooved, crack-line-wedge-loaded specimen to obtain a rapid run-arrest segment of flat-tensile separation with a nearly straight crack front. This test method provides a static analysis determination of the stress intensity factor at a short time after crack arrest. The estimate is denoted Ka. When certain size requirements are met, the test result provides an estimate, termed KIa, of the plane-strain crack-arrest toughness of the material.
还望哪位达人传给小弟,谢谢
zk200512345
ASTM E1221-12a Standard Test Method for Determining Plane-Strain Crack-Arrest Fracture Toughness,KIa, of Ferritic Steels
附件:
该帖子作者被版主 eginzon8积分, 2经验,加分理由:加大奖励额度
fanluvchou
