光电直读光谱仪操作说明
photoelectric spectrometer operating instructions
光电直读光谱仪操作我们可以分为日常校准和工作曲线的建立。
The establishment of JB-750 photoelectric spectrometer Operation we can be divided into daily calibration and working curve:
一:日常校准Daily calibration
光电直读光谱仪操作可分为:磨样,狭缝扫描,标准化,控样校准和试样分析几个部分。
JB750type photoelectric directreading spectrometer operation can be divided into:sample grinding and slit scanning, standardization, control calibration samples and sample analysis several part
1:磨样
grinding
样品制备好对其进行后期的处理,就是在磨样机上进行磨制,被测样品激发的一面一定要平,使样品纹理清晰,才能保证样品与激发台之间贴合度, 这样才能保证气体冲洗室的密封性,使样品得到更好的激发。
Samples were prepared on the post processing, is in grinding machine for grinding,the sample to be measured excitation side must be flat, the sample texture clear, to ensure that the sample and excitation,and fit, so as to ensure gas washing chamber sealing,the samples were better excitation.
磨样机有以上两种可以选择,但是磨样机的转速必须要求在3600r/min,砂轮的粗细在36~60目之间,这样磨出的才符合光谱需求。
There are more than two kinds of grinding machine can choose, but the speed of the grinding machine must be required in the 3600r/min,the thickness of the grinding wheel in the P36~60 , so that the wear out of the spectral requirements.
正确的磨样 错误的磨样
RIGHT SAMPLE ERROR sample
2:狭缝扫描
Seam scanning
JB-750型光电直读光谱仪的光学系统都是按照仪器技术指标及光栅实际色散在生产过程中进行调整并紧固好的。出入射狭缝外其余部分不会相对位置的移动。但因温度及金属本身的变形会造成谱线相对出射狭缝位置的漂移。为了补偿这种缓慢的移动,在仪器的正常使用过程中,一般要求每天6~8个进行移动入社狭缝对出射狭缝的扫描,这样才能更好的进行样品分析,具体操作如下:
JB750 type photoelectric direct reading spectrometer optical system are in technical index of the instrument and the actual grating dinsersion in the production process adjustment and fastening,in addition to the entrance slit the rest not relative position of a mobile ,but due to the deformation of the temperature and the metal itself will cause spectrum relative exit Slit position drift ,in order to compensate for the slow movement,in the instrument during normal use ,the general requirements of every 6-8 for moving the entrance Slit of the exit Slit scanning ,so as to better sample analysis and specific operation as follows.
想下载具体内容请联系我。
原文由 孬子(v2839974) 发表:我也是这么认为的,每天,即使是每个礼拜都要狭缝描迹,这种设备也没人敢买。更别说曲线标准化了,恐怕是每天都要曲线标准化,化验人恐怕操作都快疯了,那还能叫光谱吗?美国热电光谱一年都不需要描迹的,鼓轮就不要动。我们光谱AES998至少一个月才用全局标准化一次,至少半年以上甚至更久才需要描迹。
每隔六到八小时还是每天做6-8次狭缝描迹?这个频率的设备我真心不敢买,我都不知道我做出来的结果靠谱吗?目前使用的进口垃圾设备几个月不做一次描迹,数据精度也还凑合。
