主题:【求助】求篇1997年文献(应助者将得到10个积分)谢谢大家
浏览0 回复0 电梯直达
hyp81
Accession number:  5702943
Title:  X-ray characterization of the new nasicon compositions Na3Zr2-x/4Si2-xP1+xO12 with x=0.333, 0.667, 1.000, 1.333, 1.667
Authors:  Lucco-Borlera, M.1 ; Mazza, D.1 ; Montanaro, L.1 ; Negro, A.1 ; Ronchetti, S.1
Author affiliation:  1 Dipt. di Sci. dei Mater. e Ingegneria Chimica, Politecnico di Torino, Italy
Serial title:  Powder Diffraction
Abbreviated serial title:  Powder Diffr. (USA)
Volume:  12
Issue:  3
Publication date:  Sept. 1997
Pages:  171-4
Language:  English
ISSN:  0885-7156
CODEN:  PODIE2
Document type:  Journal article (JA)
Publisher:  AIP for JCPDS-Int. Centre for Diffraction Data
Country of publication:  USA
Material Identity Number:  P919-1997-002
Abstract:  It is known that solids with composition Na3Zr2Si2PO12 heated at 1200°C crystallize in the nasicon structure. This material shows a high ionic conductivity that represents an interesting improvement in the field of solid electrolytes. Our experimental results allow to establish for the first time that nasicon structures are stable along the compositional join Na3Zr2-x/4Si2-xP1+xO12 with x extending from 0 to 1.667. These structures are characterized by a Zr underoccupation of octahedral sites and a constant number of Na+ ions. This fact envisages a possible application of these materials in the field of ceramic sensors and ionic conductors
Number of references:  18
Inspec controlled terms:  crystal structure  -  ionic conductivity  -  sodium compounds  -  solid electrolytes  -  X-ray diffraction
Uncontrolled terms:  Na3Zr2-x/4Si2-xP1+xO12  -  nasicon composition  -  structure  -  ionic conductivity  -  solid electrolytes  -  ceramic sensors  -  X-ray characterization  -  1200 C  -  Na3Zr2Si2PO12
Inspec classification codes:  A6160 Crystal structure of specific inorganic compounds  -  A6630H Self-diffusion and ionic conduction in solid nonmetals
Numerical data indexing:  temperature 1.47E+03 K
Chemical indexing:  Na3Zr2Si2PO12/ss Na3/ss O12/ss Si2/ss Zr2/ss Na/ss Si/ss Zr/ss O/ss P/ss
Treatment:  Experimental (EXP)
Discipline:  Physics (A)
Database:  Inspec
  Copyright 1997, IEE
找到了麻烦发到信箱16010619@163.com
谢谢大家
