篇名是No volatile n-nitrosamines detected in blood and urine from patients ingesting daily large amounts of ammonium nitrate 刊名是Food and Chemical Toxicology, Vol. 20, pp. 939 to 944, 1982 不尽感谢!
原文由 typinmei 发表: 篇名是No volatile n-nitrosamines detected in blood and urine from patients ingesting daily large amounts of ammonium nitrate 刊名是Food and Chemical Toxicology, Vol. 20, pp. 939 to 944, 1982 不尽感谢!
帮你查过了,我们学校Food and Chemical Toxicology期刊有1982年Vol 6,但没有收录Issue 6的。另外该篇文章具体出处应该是1982 Dec;20(6):879-882
No volatile n-nitrosamines detected in blood and urine from patients ingesting daily large amounts of ammonium nitrate Food and Cosmetics Toxicology, Volume 20, Issue 6, 1982, Pages 879-882 G. ellen, P.L. schuller, P.G. A.M. froeling and E. bruijns --------------------------------------------------------------------- Abstract
Whole blood and urine from 23 patients ingesting ammonium nitrate daily in amounts varying from 2.5–9 g were analysed for volatile N-nitrosamines. By contrast with reports in the literature N-nitrosodimethylamine and N-nitrosodiethylamine were not found in blood (limit of detection 0.1 μg/kg) but a trace of N-nitrosopyrrolidine was found in the blood of one subject. Small amounts of N-nitrosomorpholine in some blood samples and in one blank were believed to be formed during the analysis since morpholine had been added to the samples to indicate artefactual nitrosamine formation. Traces of N-nitrosodimethylamine (0.1 μg/kg) were found in six of the 23 urine samples.
