原文由 jzhiquan 发表:
看看是不是这个
Spatial Distribution of Daylight - CIE Standard General Sky
Joint ISO/CIE Standard
ISO 15469:2004 (E) / CIE S 011/E:2003
CIE has published the standard "CIE S003 Spatial distribution of daylight - CIE standard overcast sky and clear sky" in 1996. Since then further types of skies were examined and an international consensus was reached on their luminance distribution and standardization.
This standard has been approved by CIE and by ISO. It may be obtained from the CIE National Committees or the Central Bureau of the CIE.
应该不是,这个文献名字应该是Recommendation for the Integrated Irradiance and the Spectral...是RlPublication CIE No.20 (TC-2.2), 1972 .其它我查不到.不好意思
