1.Andrade, C., Maribona, I. R., Feliu, S., Gonzales, J. A., and Feliu, S. Jr,
The Effect of Macro-Cells Between Active and Passive Areas of Steel
Reinforcements, Corrosion Science, 33(2):237–249 (1992)
2.Feliu, S., Gonzalez, J. A., Andrade, C., and Feliu, V., On-Site
Determination of the Polarization Resistance in a Reinforced Concrete
Beam, Corrosion Engineering, 44:761–765 (1988)
3.Andrade, C., and Gonzales, J. A., Quantitative Measurements of
Corrosion Rate of Reinforcing Steels Embedded in Concrete Using
Polarization Resistance Measurements, Werkstoffe und Korrosion, 29:515-519 (1978)
