1.The determination of the corrosion rate of steel in concrete by a non-stationary method
Corrosion Science, Volume 26, Issue 11, 1986, Pages 961-965
S. Feliu, J. A. Gonzalez, C. Andrade, V. Feliu
2.Determining polarization resistance in reinforced concrete slabs
Corrosion Science, Volume 29, Issue 1, 1989, Pages 105-113
S. Feliu, J. A. González, M. C. Andrade, V. Feliu
3.The electrochemical behaviour of steel under polarization in porous media simulating concrete
Corrosion Science, Volume 33, Issue 10, October 1992, Pages 1607-1616
André Raharinaivo, Jean-Pierre Guilbaud, Gérard Chahbazian, François Derrien
4.Electrochemical changes in chloride-contaminated reinforced concrete following cathodic polarisation
Corrosion Science, Volume 35, Issues 5-8, 1993, Pages 1627-1631
W. K. Green, S. B. Lyon, J. D. Scantlebury
5.A study of reinforcement behaviour in concrete structures using electrochemical techniques
Corrosion Science, Volume 35, Issues 5-8, 1993, Pages 1579-1584
Ranieri Cigna, Edoardo Proverbio, Gabriele Rocchini
6.Oxygen diffusion through portland cement mortars
Corrosion Science, Volume 35, Issues 5-8, 1993, Pages 1551-1556
C. M. Hansson
7.Analysis of local corrosion of large metallic structures or reinforced concrete structures by electrochemical impedance spectroscopy (EIS)
Electrochimica Acta, Volume 35, Issue 10, October 1990, Pages 1573-1578
F. Wenger and J. Galland
