原文由 happymingxu 发表:
Cataract syndrome of frog is associated with chryseobacterium meningosepticum,and the symptom is accites()、askew head()、cataract() etc.If the acute syndrome goes with some other diseases the death rate of frog is higher. Basis from many experimentations of sensitivity we filtrated the compounding of Wajunshaxin spray and Koufuwajunsahxing Powder and made a series of prevention and cure experimentations.
这是我拙劣的翻译,括号里面的没有翻译,请指教!!!
这样改一下是否合适:
Cataract syndromes in frog associated with chryseobacterium meningosepticum included accites()、head tilt and cataract() etc.In acute cases or when secondary diseases developed, the death rates of frogs were much higher. Based on many sensitivity tests, we developed formula of Wajunshaxin spray and Koufuwajunsahxing Powder, which were tested through series of prevention and treatment experiments.
有一些你没有翻译出来。如关于季节和年龄的。具体的症状你也没翻译。你再翻译一下我给你修改。
