主题:【求助】(已应助)求助几篇英文文献、、、、多谢了【完成,结贴,感谢。】
浏览0 回复8 电梯直达
nihaopp
1.1.
Photostability of Colloidal PbSe and PbSe/PbS Core/Shell Nanocrystals in Solution and in the Solid State
Stouwdam, J. W.; Shan, J.; van Veggel, F. C. J. M.; Pattantyus-Abraham, A. G.; Young, J. F.; Raudsepp, M.
J. Phys. Chem. C.; (Article); 2007; 111(3); 1086-1092.  DOI: 10.1021/jp0648083
http://pubs.acs.org/cgi-bin/abstract.cgi/jpccck/2007/111/i03/abs/jp0648083.html
2.2
Air-Stable PbSe/PbS and PbSe/PbSexS1-x Core-Shell Nanocrystal Quantum Dots and Their Applications
Lifshitz, E.; Brumer, M.; Kigel, A.; Sashchiuk, A.; Bashouti, M.; Sirota, M.; Galun, E.; Burshtein, Z.; Le Quang, A. Q.; Ledoux-Rak, I.; Zyss, J.
J. Phys. Chem. B.; (Article); 2006; 110(50); 25356-25365.  DOI: 10.1021/jp0644356
http://pubs.acs.org/cgi-bin/abstract.cgi/jpcbfk/2006/110/i50/abs/jp0644356.html
3.3
Optical Properties of Rotationally Twinned InP Nanowire Heterostructures
Jiming Bao, David C. Bell, Federico Capasso, Jakob B. Wagner, Thomas Mårtensson, Johanna Trägårdh, and Lars Samuelson
Nano Lett., 8 (3), 836–841, 2008. 10.1021/nl072921e
http://pubs.acs.org/cgi-bin/abstract.cgi/nalefd/2008/8/i03/abs/nl072921e.html
4.4
A Mild and Efficient Biomimetic Synthesis of Rodlike Hydroxyapatite Particles with a High Aspect Ratio Using Polyvinylpyrrolidone As Capping Agent
Yanjie Zhang and Jinjun Lu
Cryst. Growth Des., 8 (7), 2101–2107, 2008. 10.1021/cg060880e
http://pubs.acs.org/cgi-bin/abstract.cgi/cgdefu/2008/8/i07/abs/cg060880e.html
5.5
Control of the Morphology and Size of PbS Nanowires Using Gold Nanoparticles
Yong, K.-T.; Sahoo, Y.; Choudhury, K. R.; Swihart, M. T.; Minter, J. R.; Prasad, P. N.
Chem. Mater.; (Article); 2006; 18(25); 5965-5972.  DOI: 10.1021/cm061771q
http://pubs.acs.org/cgi-bin/abstract.cgi/cmatex/2006/18/i25/abs/cm061771q.html
6.6
Fabrication of Symmetric Hierarchical Hollow PbS Microcrystals via a Facile Solvothermal Process
Zhao, P.; Wang, J.; Cheng, G.; Huang, K.
J. Phys. Chem. B.; (Article); 2006; 110(45); 22400-22406.  DOI: 10.1021/jp064392t
http://pubs.acs.org/cgi-bin/abstract.cgi/jpcbfk/2006/110/i45/abs/jp064392t.html
7.7
Shape-Controlled Synthesis of Single-Crystalline CdCO3 and Corresponding Porous CdO Nanostructures
Zhiyong Jia, Yiwen Tang, Lijuan Luo, and Bihui Li
Cryst. Growth Des., 8 (7), 2116–2120, 2008. 10.1021/cg7007254
http://pubs.acs.org/cgi-bin/abstract.cgi/cgdefu/2008/8/i07/abs/cg7007254.html
8.8
Tunable Arrays of ZnO Nanorods and Nanoneedles via Seed Layer and Solution Chemistry
Yun-Ju Lee, Thomas L. Sounart, Jun Liu, Erik D. Spoerke, Bonnie B. McKenzie, Julia W. P. Hsu, and James A. Voigt
Cryst. Growth Des., 8 (6), 2036–2040, 2008. 10.1021/cg800052p
http://pubs.acs.org/cgi-bin/abstract.cgi/cgdefu/2008/8/i06/abs/cg800052p.html
我在故我思
我在故我思
我在故我思
我在故我思
我在故我思
我在故我思
我在故我思
