1.Significant Enhancement of Hole Mobility in [110] Silicon Nanowires Compared to Electrons and Bulk Silicon
A. K. Buin, A. Verma, A. Svizhenko, and M. P. Anantram
Nano Lett., 8 (2), 760 -765, 2008. 10.1021/nl0727314 S1530-6984(07)02731-2
http://pubs.acs.org/cgi-bin/abstract.cgi/nalefd/2008/8/i02/abs/nl0727314.html
2.Synthesis of BaMoO4 Nestlike Nanostructures Under a New Growth Mechanism
Zhijun Luo, Huaming Li, Huoming Shu, Kun Wang, Jiexiang Xia, and Yongsheng Yan
Cryst. Growth Des., 8 (7), 2275–2281, 2008. 10.1021/cg700967y
http://pubs.acs.org/cgi-bin/abstract.cgi/cgdefu/2008/8/i07/abs/cg700967y.html
3.Novel Nanocrystal Heterostructures: Crystallographic-Oriented Growth of SnO2 Nanorods onto α-Fe2O3 Nanohexahedron
Mutong Niu, Yao Cheng, Yuansheng Wang, Lifeng Cui, Feng Bao, and Lihua Zhou
Cryst. Growth Des., 8 (5), 1727–1729, 2008. 10.1021/cg701048d
http://pubs.acs.org/cgi-bin/abstract.cgi/cgdefu/2008/8/i05/abs/cg701048d.html
4.A facile approach to fabricate functionalized superparamagnetic copolymer-silica nanocomposite spheres
Dechao Niu, Yongsheng Li, Xiaoli Qiao, Liang Li, Wenru Zhao, Hangrong Chen, Qiaoling Zhao, Zhi Ma and Jianlin Shi,
Chem. Commun., 2008 DOI: 10.1039/b807781a
http://www.rsc.org/Publishing/Journals/CC/article.asp?doi=b807781a
5.Facile approach to prepare loose-packed NiO nano-flakes materials for supercapacitors
Jun-Wei Lang, Ling-Bin Kong, Wei-Jin Wu, Yong-Chun Luo and Long Kang,
Chem. Commun., 2008 DOI: 10.1039/b800264a
http://www.rsc.org/Publishing/Journals/CC/article.asp?doi=b800264a
6.Investigation of Spontaneous Transition from Low-Molecular-Weight Hydrogel into Macroscopic Crystals
Yujiang Wang, Liming Tang, and Jian Yu
Cryst. Growth Des., 8 (3), 884–889, 2008. 10.1021/cg070619d
http://pubs.acs.org/cgi-bin/abstract.cgi/cgdefu/2008/8/i03/abs/cg070619d.html
