References
w x . 1 G. Kirchhoff, Ann. Phys. Poggendorf’s Annalen 109
. 1860 275.
w x . 2 G. Kirchhoff, R. Bunsen, Philos. Mag. 20 1860 89.
w x . 3 G. Kirchhoff, R. Bunsen, Philos. Mag. 22 1861 329]349.
w x . 4 A. Walsh, Spectrochim. Acta Part B 35 1980 643]652.
w x 5 C.Th.J. Alkemade, J.M.W. Milatz, A double-beam
method of spectral selection with flames, Appl. Sci. Res.
. B4 1955 289]299.
w x 6 C.Th.J. Alkemade, J.M.W. Milatz, J. Opt. Soc. Am. 45
. 1955 583]584.
w x 7 A. Walsh, The application of atomic absorption spectra
. to chemical analysis, Spectrochim. Acta 7 1955
108]117.
w x 8 B.V. L’vov, Twenty-five years of furnace atomic absorp-
. tion spectroscopy’, Spectrochim. Acta Part B 39 1984
149]157.
w x 9 B. Welz, M. Sperling, Atomic Absorption Spectrometry,
3rd ed, Wiley-VCH, Weinheim, New York, 1999.
w x 10 A. Walsh, Atomic absorption spectroscopy } stagnant
. or pregnant?, Anal. Chem. 46 1974 698A]708A.
w x 11 B.V. L’vov, Electrothermal atomization } the way towards
absolute methods of atomic absorption analysis,
. Spectrochim. Acta Part B 33 1978 153]193.
w x 12 W. Slavin, D.C. Manning, G.R. Carnrick, The stabilized
. temperature platform furnace, At. Spectrosc. 2 1981
137]145.
w x 13 G.M. Hieftje, Atomic absorption spectrometry } has it
gone or where is it going?, J. Anal. At. Spectrom. 4
. 1989 117]122.
w x 14 B. Welz, M. Sperling, Flow injection: the ultimate approach
to automation in analytical atomic spectroscopy,
. Pure Appl. Chem. 65 1993 2465]2472.
w x 15 Z.-L. Fang, M. Sperling, B. Welz, Flow-injection online
sorbent extraction pre-concentration for graphite furnace
atomic absorption spectrometry, J. Anal. At. Spec-
. trom. 5 1990 639]646.
w x 16 Z.-L. Fang, L.-P. Dong, Flow-injection online co-precipitation
pre-concentration for electrothermal atomic ab-
. sorption spectrometry, J. Anal. At. Spectrom. 7 1992
439]446.
w x 17 M. Sperling, X.-F. Yin, B. Welz, Flow-injection online
separation and pre-concentration for electrothermal
atomic absorption spectrometry. I. Determination of
ultra-trace amounts of cadmium, copper, lead and nickel
. in water samples, J. Anal. At. Spectrom. 6 1991
295]300.
w x 18 M. Sperling, X.-F. Yin, B. Welz, Flow-injection online
atomic absorption spectrometry. II. Determination of
ultra-trace amounts of cobalt in water, J. Anal. At.
. Spectrom. 6 1991 615]621.
w x 19 M. Sperling, X.-P. Yan, B. Welz, Electrothermal atomic
absorption spectrometric determination of lead in highpurity
reagents with flow-injection on-line microcolumn
preconcentration and separation using a macrocycle immobilized
silica gel sorbent, Spectrochim. Acta Part B
. 51 1996 1875]1889.
w x 20 J.N. Lockyer, Studies in Spectrum Analysis, Appleton,
London, 1878.
w x . 21 U. Kurfurst Ed. , Solid Sample Analysis, Springer- ¨
Verlag, Berlin, Heidelberg, New York, 1998.
w x 22 K.-Ch. Friese, V. Krivan, A solid-sampling system for a
transversely heated graphite furnace and its application
to trace element analysis of high-purity tantalum
powders by atomic absorption spectrometry, Spec-
. trochim. Acta Part B 53 1998 1069]1078.
w x 23 G.R. Carnrick, G. Daley, A. Fotinopoulos, Design and
use of a new automated ultrasonic slurry sampler for
graphite furnace atomic absorption, At. Spectrosc. 10
. 1989 170]174.
w x 24 N.J. Miller-Ihli, Automated ultrasonic mixing accessory
for slurry sampling into a graphite furnace atomic ab-
. sorption spectrometer, J. Anal. At. Spectrom. 4 1989
295]297.
w x 25 M. Lucic, V. Krivan, Solid sampling electrothermal
atomic absorption spectrometry for analysis of
aluminium oxide powders, J. Anal. At. Spectrom. 13
. 1998 1133]1139.
w x 26 M. Hornung, V. Krivan, Determination of trace impurities
in high-purity tungsten by direct solid sampling
electrothermal atomic absorption spectrometry using a
. transversely heated graphite tube, Anal. Chem. 70 1998
3444]3451.
w x 27 M. Hornung, V. Krivan. Solid sampling electrothermal
atomic absorption spectrometry for analysis of high-purity
tungsten trioxide and high-purity tungsten blue oxide,
. Spectrochim. Acta Part B 54 1999 1177]1191.
w x 28 B. Welz, Speciation analysis. The future of atomic ab-
. sorption spectrometry, J. Anal. At. Spectrom. 13 1998
413]417.
w x 29 T. Guo, J. Baasner, D.L. Tsalev, Fast automated determination
of toxically relevant arsenic in urine by flow
injection-hydride generation atomic absorption spec-
. trometry, Anal. Chim. Acta 349 1997 313]318.
w x 30 M. Sperling, X.-F. Yin, B. Welz, Differential determina-
. tion of chromium VI and total chromium in natural
waters using flow injection on-line separation and preconcentration
electrothermal atomic absorption spec-
. trometry, Analyst 117 1992 629]635.
w x 31 M. Sperling, S.-K. Xu, B. Welz, Determination of
. . chromium III and chromium VI in water using flow
injection on-line preconcentration with selective adsorption
on activated alumina and flame atomic absorption
. spectrometric detection, Anal. Chem. 64 1992
3101]3108.
w x 32 J.C. Van Loon, B. Radziuk, A quartz tube furnaceatomic
absorption spectroscopy system for metal specia-
. tion studies, Can. J. Spectrosc. 21 1976 46]50.
w x 33 O.F.X. Donard, S. Rapsomanikis, J.H. Weber, Speciation
of inorganic tin and alkyltin compounds by atomic
absorption spectrometry using electrothermal quartz
. furnace after hydride generation, Anal. Chem. 58 1986
772]777.
w x 34 X.-R. Zhang, R. Cornelis, J. DeKimpe, L. Mees, Arsenic
speciation in serum of uraemic patients based on liquid
chromatography with hydride generation atomic absorption
spectrometry and on-line UV photo-oxidation di-
. gestion, Anal. Chim. Acta 319 1996 177]185.
w x 35 D.L. Tsalev, M. Sperling, B. Welz, On-line microwave
sample pre-treatment for hydride generation and cold
vapour atomic absorption spectrometry. Part 1. The
. manifold, Analyst 117 1992 1729]1733.
w x 36 D.L. Tsalev, M. Sperling, B. Welz, On-line microwave
vapour atomic absorption spectrometry. Part 2. Chem-
. istry and applications, Analyst 117 1992 1735]1741.
w x 37 M. Sperling, Z.-L. Fang, B. Welz, Expansion of dynamic
working range and correction for interferences in flame
atomic absorption spectrometry using flow-injection gradient
ratio calibration with a single standard, Anal.
. Chem. 63 1991 151]159.
