1.Hydrothermal Growth of CuS Nanowires from Cu-Dithiooxamide, a Novel Single-Source Precursor
Roy, P.; Srivastava, S. K.
Cryst. Growth Des.; 2006; 6(8); 1921-1926.
http://pubs.acs.org/cgi-bin/abstract.cgi/cgdefu/2006/6/i08/abs/cg060134+.html
2.Synthesis of CuS Nanoparticles in Water-in-Carbon Dioxide Microemulsions
Dong, X.; Potter, D.; Erkey, C.
Ind. Eng. Chem. Res.; 2002; 41(18); 4489-4493. http://pubs.acs.org/cgi-bin/abstract.cgi/iecred/2002/41/i18/abs/ie0107892.html
3.Controllable Synthesis of Cu2S Nanocrystals and Their Assembly into a Superlattice
Zhuang, Z.; Peng, Q.; Zhang, B.; Li, Y.
J. Am. Chem. Soc.; (Communication); 2008; 130(32); 10482-10483.
http://pubs.acs.org/cgi-bin/abstract.cgi/jacsat/2008/130/i32/abs/ja803644g.html
4.Selected-Control Hydrothermal Synthesis of - and -MnO2 Single Crystal Nanowires
Wang, X.; Li, Y.
J. Am. Chem. Soc.; (Communication); 2002; 124(12); 2880-2881. http://pubs.acs.org/cgi-bin/abstract.cgi/jacsat/2002/124/i12/abs/ja0177105.html
5.Large-Scale Synthesis and Self-Assembly of Monodisperse Hexagon Cu2S Nanoplates
Zhang, H.-T.; Wu, G.; Chen, X.-H.
Langmuir; (Letter); 2005; 21(10); 4281-4282.
http://pubs.acs.org/cgi-bin/abstract.cgi/langd5/2005/21/i10/abs/la050741j.html
6.Synthesis of Uniform Cu2S Nanowires from Copper-Thiolate Polymer Precursors by a Solventless Thermolytic Method
Chen, L.; Chen, Y.-B.; Wu, L.-M.
J. Am. Chem. Soc.; (Communication); 2004; 126(50); 16334-16335. http://pubs.acs.org/cgi-bin/abstract.cgi/jacsat/2004/126/i50/abs/ja045074f.html
7.Cu2S/Au Core/Sheath Nanowires Prepared by a Simple Redox Deposition Method
Wen, X.; Yang, S.
Nano Lett.; (Letter); 2002; 2(5); 451-454.
http://pubs.acs.org/cgi-bin/abstract.cgi/nalefd/2002/2/i05/abs/nl0202915.html
8.Facile Synthesis and Assembly of Cu2S Nanodisks to Corncoblike Nanostructures
Du, X.-S.; Yu, Z.-Z.; Dasari, A.; Ma, J.; Meng, Y.-Z.; Mai, Y.-W.
Chem. Mater.; (Communication); 2006; 18(22); 5156-5158. https://pubs.acs.org/secure/login?url=http%3A%2F%2Fpubs.acs.org%2Fcgi-bin%2Farticle.cgi%2Fcmatex%2F2006%2F18%2Fi22%2Fpdf%2Fcm0617135.pdf
