主题:NMR中常用的英文缩写和中文名称
浏览0 回复21 电梯直达
celan
收集了一些NMR中常用的英文缩写,译出其中文名称,供初学者参考,不妥之处请指出,也请继续添加.
相关附件
NMR中常用的英文缩写和中文名称
APT    Attached Proton Test 质子连接实验
ASIS    Aromatic Solvent Induced Shift 芳香溶剂诱导位移
BBDR    Broad Band Double Resonance  宽带双共振
BIRD    Bilinear Rotation Decoupling 双线性旋转去偶(脉冲)
COLOC    Correlated Spectroscopy for Long Range Coupling  远程偶合相关谱
COSY    ( Homonuclear chemical shift ) COrrelation SpectroscopY (同核化学位移)相关谱
CP    Cross Polarization 交叉极化
CP/MAS    Cross Polarization / Magic Angle Spinning  交叉极化魔角自旋
CSA    Chemical Shift Anisotropy  化学位移各向异性
CSCM    Chemical Shift Correlation Map 化学位移相关图
CW    continuous wave  连续波
DD    Dipole-Dipole  偶极-偶极
DECSY    Double-quantum Echo Correlated Spectroscopy 双量子回波相关谱
DEPT    Distortionless Enhancement by Polarization Transfer 无畸变极化转移增强
2DFTS    two Dimensional FT Spectroscopy 二维傅立叶变换谱
DNMR    Dynamic NMR  动态NMR
DNP    Dynamic Nuclear Polarization  动态核极化
DQ(C)    Double Quantum (Coherence) 双量子(相干)
DQD     Digital Quadrature Detection  数字正交检测
DQF    Double Quantum Filter  双量子滤波
DQF-COSY     Double Quantum Filtered COSY  双量子滤波COSY
DRDS     Double Resonance Difference Spectroscopy  双共振差谱
EXSY    Exchange Spectroscopy  交换谱
FFT     Fast Fourier Transformation 快速傅立叶变换
FID    Free Induction Decay  自由诱导衰减
H,C-COSY    1H,13C chemical-shift COrrelation SpectroscopY  1H,13C化学位移相关谱
H,X-COSY    1H,X-nucleus chemical-shift COrrelation SpectroscopY  1H,X-核化学位移相关谱
HETCOR    Heteronuclear Correlation Spectroscopy  异核相关谱
HMBC    Heteronuclear Multiple-Bond Correlation  异核多键相关
HMQC    Heteronuclear Multiple Quantum Coherence异核多量子相干
HOESY    Heteronuclear Overhauser Effect Spectroscopy  异核Overhause效应谱
HOHAHA    Homonuclear Hartmann-Hahn spectroscopy  同核Hartmann-Hahn谱
HR    High Resolution  高分辨
HSQC     Heteronuclear Single Quantum Coherence 异核单量子相干
INADEQUATE    Incredible Natural Abundance Double Quantum Transfer Experiment 稀核双量子转移实验(简称双量子实验,或双量子谱)
INDOR    Internuclear Double Resonance 核间双共振
INEPT    Insensitive Nuclei Enhanced by Polarization 非灵敏核极化转移增强
INVERSE    H,X correlation via 1H detection  检测1H的H,X核相关
IR    Inversion-Recovery  反(翻)转回复
JRES     J-resolved spectroscopy  J-分解谱
LIS     Lanthanide (chemical shift reagent ) Induced Shift  镧系(化学位移试剂)诱导位移
LSR    Lanthanide Shift Reagent  镧系位移试剂
MAS    Magic-Angle Spinning  魔角自旋
MQ(C)     Multiple-Quantum ( Coherence ) 多量子(相干)
MQF    Multiple-Quantum Filter  多量子滤波
MQMAS     Multiple-Quantum Magic-Angle Spinning  多量子魔角自旋
MQS    Multi Quantum Spectroscopy  多量子谱
NMR    Nuclear Magnetic Resonance 核磁共振
NOE    Nuclear Overhauser Effect  核Overhauser效应(NOE)
NOESY    Nuclear Overhauser Effect Spectroscopy 二维NOE谱
NQR     Nuclear Quadrupole Resonance 核四极共振
PFG    Pulsed Gradient Field  脉冲梯度场
PGSE    Pulsed Gradient Spin Echo 脉冲梯度自旋回波
PRFT    Partially Relaxed Fourier Transform  部分弛豫傅立叶变换
PSD    Phase-sensitive Detection 相敏检测
PW    Pulse Width  脉宽
RCT    Relayed Coherence Transfer 接力相干转移
RECSY    Multistep Relayed Coherence Spectroscopy 多步接力相干谱
REDOR    Rotational Echo Double Resonance 旋转回波双共振
RELAY    Relayed Correlation Spectroscopy 接力相关谱
RF    Radio Frequency  射频
ROESY    Rotating Frame Overhauser Effect Spectroscopy 旋转坐标系NOE谱
ROTO    ROESY-TOCSY Relay    ROESY-TOCSY 接力谱
SC    Scalar Coupling  标量偶合
SDDS    Spin Decoupling Difference Spectroscopy 自旋去偶差谱
SE    Spin Echo  自旋回波
SECSY    Spin-Echo Correlated Spectroscopy自旋回波相关谱
SEDOR    Spin Echo Double Resonance 自旋回波双共振
SEFT    Spin-Echo Fourier Transform Spectroscopy (with J modulation) (J-调制)自旋回波傅立叶变换谱
SELINCOR    Selective Inverse Correlation 选择性反相关
SELINQUATE    Selective INADEQUATE  选择性双量子(实验)
SFORD    Single Frequency Off-Resonance Decoupling  单频偏共振去偶
SNR or S/N    Signal-to-noise Ratio  信 / 燥比
SQF    Single-Quantum Filter  单量子滤波
SR    Saturation-Recovery  饱和恢复
TCF    Time Correlation Function  时间相关涵数
TOCSY    Total Correlation Spectroscopy  全(总)相关谱
TORO    TOCSY-ROESY Relay  TOCSY-ROESY接力
TQF    Triple-Quantum Filter 三量子滤波
WALTZ-16    A broadband decoupling sequence 宽带去偶序列
WATERGATE    Water suppression pulse sequence  水峰压制脉冲序列
WEFT    Water Eliminated Fourier Transform 水峰消除傅立叶变换
ZQ(C)    Zero-Quantum (Coherence) 零量子相干
ZQF    Zero-Quantum Filter  零量子滤波
T1    Longitudinal (spin-lattice) relaxation time for MZ 纵向(自旋-晶格)弛豫时间
T2    Transverse (spin-spin) relaxation time for Mxy 横向(自旋-自旋)弛豫时间
tm    mixing time  混合时间
τc    rotational correlation time  旋转相关时间
您可能想找: 核磁共振(NMR) 询底价
tanggangfeng
luchenmin
xivh
batur
jh1234567jh
trufan
albumj
sslin
原文由 celan 发表:
NMR中常用的英文缩写和中文名称
INEPT    Insensitive Nuclei Enhanced by Polarization Transfer 非灵敏核极化转移增强
为什么 APT 的 PT 不是 polarization transfer?
celan
原文由 sslin 发表:
原文由 celan 发表:
NMR中常用的英文缩写和中文名称
APT: Attached Proton Test
http://www.chem.queensu.ca/FACILITIES/NMR/nmr/webcourse/apt.htm
http://drx.ch.huji.ac.il/nmr/techniques/1d/row2/apt.htm
celan
Attached Proton Test (APT)
            The APT pulse sequence generates a 1D spectra with CH3 and CH carbons phased down and CH2 and C carbons phased up. Unlike the DEPT experiment, this technique is not able to distinguish between CH3 and CH carbons and between CH2 and C carbons.
Distortionless Enhancement by Polarization Transfer (DEPT)
            The DEPT experiment is similar to the APT pulse sequence in that it can be used to determine the number of protons that are attached to a carbon atom. Quaternary carbon atoms don’t generate a signal in the DEPT procedure.  The DEPT technique can be used to distinguish between CH3 and CH carbons and between CH2 and C carbons.
