【名称】应用化学数据库
【资源简介】
碳-13核磁共振波谱数据库
碳-13核磁共振波谱数据库系统始建于1982年,它是国内第一个比较大型的碳-13 NMR谱图数据库系统,主要用于有机化合物结构的自动解析。数据类型包括各类有机化合物的碳-13 NMR谱图数据,如天然产物,金属有机化合物, 毒物等各类化合物。数据项包括化合物名称、分子式、化合物重量、化学位移、多重性、实验条件、相关的文献等。
稀土萃取数据库
稀土萃取数据库系统始建于1987年,主要用于稀土的分离。稀土萃取数据库的主要数据类型为:中性磷类萃取剂;胺类萃取剂;羧酸类萃取剂;无机酸的萃取。数据项包括萃取剂名称、分子式、被萃成分(金属元素和无机酸)、极性项、稀释剂、辅助配位体、参考文献等。
稀土物理化学性质数据库
稀土物理化学性质数据库系统始建于1987年,主要用于与稀土相关的材料的研究与设计。数据库中包括氧化物,卤化合物,硫化合物,金属间化合物等40余种化合物的熔点,沸点,生成热,熵,焓等多种物理化学性质。
化合物活性数据库
化合物活性数据库中包括化合物的CAS登录号,化合物名称,分子式,分子量,活性值等
【地址】http://www.appchem.csdb.cn/
【名称】质谱:Mass Spectrometry Database,American Academy of Forensic Sciences
【资源简介】
This library is a "subset" of one that has been compiled over a period of many years by Dr. Graham Jones and colleagues in Edmonton, Alberta, Canada. Pure drug spectra, plus a few breakdown products and pure metabolite standards have been edited into a single library. The first version of this library contained about 1500 entries. A separate library of metabolites, endogenous compounds and artifacts is under construction, but may be 1-2 years from completion of the first draft (it's an incredibly time consuming process!!).
【检索途径】
The current library is aafsdrug.zip. Click on the file name to download. This file consists of the component files of this library, compressed with the utility pkzip, into a single "zip" file. This saves space and allows a shorter, easier download than if the individual uncompressed files were available. A list of entries can be downloaded separately as an MS Excel v. 4 spreadsheet file that can be viewed with most spreadsheet and many database programs.
Software Compatibility
Libraries made available by the committee primarily designed to be compatible with HP 5970/71/72/73 series instruments that have PC-based DOS/Windows ChemStation operating systems. See the Software Compatibility page for a fuller discussion and the availability of libraries translated for other mass spectrometers.
【地址】http://www.ualberta.ca/~gjones/mslib.htm
【名称】SweeT-DB (糖类化合物数据库)
【资源简介】
Sweet-DB includes:
about 50,000 carbank entries
more than 22,000 carbohydrate structures
15,000 publications about 1,000 pubilcations collected via Auto-Sweet-DB
about 10,000 spatial representations generated with sweet.
【检索途径】
SweeT-DB is the main glycosciences data base which allows glycoscientists to find important data for the compound of interest in a compact and well-structured representation. Currently, reference data taken from CarbBank, which is linked to the NCBI PubMed service, NMR data taken from SugaBase , theoretically calculated MS-spectra and 3D coordinates generated with SWEET-II can be retrieved for a given carbohydrate (sub)structure.
Search is supported by formula, exact structure, author or fuzzy author, Fuzzy title, LinucsID, Classification, Composition and Peak Search, etc.
【地址】
http://www.dkfz-heidelberg.de/spec/sweetdb/【名称】糖类(碳水化合物)拉曼谱图库SPECARB (Raman Spectra of Carbohydrates)
【资源简介】
SPECARB is an experimental database containing Raman spectra of carbohydrates. It is intended to contain solid state Raman spectra of carbohydrates from the monomers and their derivatives to complex polysaccharides. Unless otherwise stated, the spectra are sampled on a Perkin Elmer System 2000 interferometer using a Nd:YAG laser. To obtain comparable spectra they will be recorded using the following parameters
【地址】http://newton.foodsci.kvl.dk/users/engelsen/specarb/specarb.html
