1. Ceramic Filter Balls Loaded with -Fe2O3 and Their Application to NH3-N Wastewater Treatment
Chinese Journal of Chemistry
Volume 26, Issue 3, Date: March, 2008, Pages: 459-462
Ji-Min FANG, Zhi-Quan WANG, Wen-Qi GONG, Hong-Gang YANG, Ya-Wen MENG, Xiao-Zhen ZHANG
2. Phase control and Mössbauer spectra of nano -Fe2O3 particles synthesized by the levitational gas condensation (LGC) method
physica status solidi (a)
Volume 201, Issue 8, Date: June 2004, Pages: 1934-1937
Y. R. Uhm, W. W. Kim, C. K. Rhee
3. Nanostructured Pure -Fe2O3 via Forced Precipitation in an Organic Solvent
Chemistry - A European Journal
Volume 10, Issue 4, Date: February 20, 2004, Pages: 925-932
Abbas A. Khaleel
4. One-Step Synthesis of Stoichiometrically Defined Metal Oxide Nanoparticles at Room Temperature
Volume 15, Issue 2, Date: January 2, 2009, Pages: 440-448
Lan Chen, Ju Xu, David A. Tanner, Richard Phelan, Machteld Van der Meulen, Justin D. Holmes, Michael A. Morris
5. Characterization of corrosion products formed on the surface of carbon steel by Raman spectroscopy
Journal of Raman Spectroscopy
Volume 40, Issue 1, Date: January 2009, Pages: 76-79
Xianghui Nie, Xiaogang Li, Cuiwei Du, Yizhong Huang, He Du
6. Synthesis of Single-Phase -Fe2O3 Nanopowders by Using A Novel Low Temperature Chemical Synthesis Route
Journal of the American Ceramic Society
Volume 91, Issue 12, Date: December 2008, Pages: 4145-4147
Prita Pant Sarangi, Bhanudas Naik, Narendra Nath Ghosh
7. Melt Differentiation Induced by Crystallization of Cement Clinker Minerals in a CaO–SiO2–Al2O3–Fe2O3 Pseudoquaternary System
Volume 91, Issue 12, Date: December 2008, Pages: 4093-4100
Koichiro Fukuda, Tomoyuki Iwata, Hideto Yoshida
